How to test a transformer with only a DMM?
  • drdavidge
    • Jun 2007
    • 11
    Hey, does anyone know how to test a transformer with only a digital multimeter?
  • gastorgrab
    • May 2007
    • 320
    Re: How to test a transformer with only a DMM?
    Test for open circuit?
    1. Test for continuity between the input pins.
    2. Test for continuity between the output pins.
    3. Done!
    • drdavidge
      • Jun 2007
      • 11
      Sorry, never really got into transformers so i'm lost even on the basics. Do you happen to have a pin diagram showing which pins are the input ones and output ones? And would I use the diode test to test for continuity on the multimeter? Thanks for the help.
      • drdavidge
        • Jun 2007
        • 11
        Here are the transformers I want to test. There are four of them but the picture only has 3 in them:
        • drdavidge
          • Jun 2007
          • 11
          Also, how about capacitors? My DMM doesn't have a function for testing capacitance but is there some way to do it without that?
          • gastorgrab
            • May 2007
            • 320
            Sorry, but you've contacted another beginner.
            You could still get away with a continuity test but the reading won't be absolute. For 'go', 'no-go' results you would have to isolate the the transformer. The results now would be 'Almost No Resistance', and 'Some or Infinite Resistance'. (and may still not give an absolute determination)
            You'll need to identify the input and output sides so you can eliminate some possibilities. The transformers shown have multiple pins, not just two pins in, and two pins out. Since i don't see any reason that a circuit would be designed to use separate voltage inputs i would assume the side with the most pins is the output side.
            There should also be some diodes downstream of the output since A/C is so rarely used in these circuits.
            • starfury1
              • May 2006
              • 1256
              OK playing blind mans bluff here
              You would do better to post make model of the device and what the problem is
              That way if there is a common type failure mode for this then someone may know what you need to do to fix it
              From what I can see they appear to be inverter transformers for CL tubes?
              but I am no guru on these
              and as above "go /no go" but you need to know whats what on the windings anyway
              inverter transformer I believe can go shorted turns. not sure if a MM will help you find them
              4 going at once is doubtful.
              there has been posts of failed transistors and electrolytic capacitors depending on make model.
              you can get an idea with a MM on Electro caps but that does depend on failure
              u can also do go no go on transistors as well
              more info would be helpful.
              You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
              • drdavidge
                • Jun 2007
                • 11
                Its actually for a dell e172fpb monitor and there is a whole thread about it here: https://www.badcaps.net/forum/showthread.php?t=1303. Read my last 3 posts there at the very end.. I replaced the transistors and then blew again a few days later so they said it could be the capacitors or transformers, but nobody has the transformer part number so I am shooting in the dark here.
                • starfury1
                  • May 2006
                  • 1256
                  Humm OK thanks, and for linking in the other thread too.....
                  • starfury1
                    • May 2006
                    • 1256
                    Seems the multitude of possible issues with this has been well explored with the above thread.
                    in fact this is what came to mind but not sure how well it works with inverter transformers....(not the guru of inverters here)
                    you may find it via DC resistance measurements but that really depends on how many "shorted turns" I suppose....not conclusive thought, I think
                    So yeah DMM may not be a great deal of help on this
                    Temperature of each transformer may be a guide?
                    like does 1 or 2 seem to get a lot hotter then the others...but not sure how accurate this would be.
                    Iam not really up on how they work ...forgotten info..dont use it tends to be forgotten
                    but for a refresher and for those wanting to know here,see Bob's project LOPT tester...grab the PDF Here
                    (Kit no longer avail)
                    google shorted turns or fly back lopt tester for more info on the subject
                    If Q759 and Q760 are getting very Hot; chances are that one of the switching transformer coils are shorted (T751 or T753). Also check (C754 C755) which lies across the collectors of Q759 and Q760. These caps dampen the voltage and current across the tranny's (V*I=P (Watts=heat)). I am under the assumption that Q759 and Q760 are not failing (have you removed, and metered them individually?).
                    Resistance from Emitter to Collector (Ohm'd out in both directions) should be infinite. Also, to test the switching transformers you will need to perform a "Ringer" test using a special tester (which a TV repair shop or University would have). Be sure to check the primary and ALL (3) of the secondary terminal pairs.
                    See the attached schematic which I made based on my inverter board. Keep note that this schematic is NOT complete. There are many other subsidiary circuits indicated by ">>". It does however show the critical aspects required for proper operation. Best of Luck!!!
                    See UMD_EE post (thanks UMD_EE)
                    PAGE 7 of thread, he has also posted a basic PDF odf the circuit he has drawn up
                    This does show the Transformers and windings.
                    Fix advice, range from reflow PCB to transistor capacitors and inverter transformers.
                    By the sounds of it all four and hope it stays working!
                    there is a bit on monitoring a diode thats seems interesting I have to find it again re read it
                    dry joints are always a problem and a resoldering of heat stress joints is always a good idea...I think anyway
                    The whole thread should be condensed into a trouble shooting guide
                    As this seems to be a real issue out there for this model.
                    Goodluck with it , its sounds like you are going to need it
                    • drdavidge
                      • Jun 2007
                      • 11
                      Thanks for the help so far. Any idea how I can check capacitors? My DMM doesn't have a capacitor option.. know of any tricks? I heard of something with 555 timers and I have some of those lying around.
                      I really just want to find out of those transformers are bad or not and check the capacitors too.
                      • starfury1
                        • May 2006
                        • 1256
                        the old analog meters used to be good for checking, go no go (more or less) on caps you can with a DMM
                        Electrolytic capacitors are a little easier cause they take time to charge up.
                        but you need to make sure of the polarity of the Resistance range on the meter
                        (see URL below)
                        You will find in this page has how to use a Multimeter to check caps
                        but its not going to be the best way to check caps
                        Sure you can build a little capacitance type meter or a circuit to hang off your DMM
                        these are out on the net but you may have to do some searching...
                        I couldn't quickly find one as an adapter for the DVM but I know many have designed and build circuits for this
                        The only 555 circuit I found used an analog microamp meter Here and doesn't go above 10uF tops
                        Here's one its stand alone and yeah some what complex
                        Anyway if I find a simple one I'll post it...they are not that expensive to buy but not worth it if you not intending to use it a lot either
                        found one circuit Here but not much in the uf again.
                        HTH
                        Cheers
                        • drdavidge
                          • Jun 2007
                          • 11
                          Thanks.. I was able to build a simple 555 timer circuit on a breadboard and use the capacitors in the circuit to test to see if they worked, and them seemed to work fine. I am guessing one of the transformers are bad but I am still not sure how to be positive about this. I also can't find a part number for replacement transformers either. Maybe I should just get a new additional monitor when it finally dies again, haha.
                          • dj8452000
                            How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                            by dj8452000
                            I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                            02-18-2025, 08:28 AM
                          • jinu_j
                            How to test Subwoofer Amplifier with only a multimeter
                            by jinu_j
                            Hi Folks
                            Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
                            Problem
                            I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
                            Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
                            Any advice would be appreciated...
                            08-29-2024, 02:05 AM
                          • F-18
                            MSI twin frozr GTX 750 not shown in device manager
                            by F-18
                            Hello Newbie here..., few years ago i bought a broken twin frozr gtx 750, seller said that theres heavy stutter issues in every game tested. i inspect it a little and find two tiny capacitor torn out near the pcie x16 gold pins, i assume it will be running in 8x ? the furmark-like gpuz test showed that there's indeed a heavy stutter and low fps but i tried this with EXP GDC and a laptop.
                            Few months ago i bought a broken Twin frozr gtx 750ti with unknown issues, i didnt test it and jump straight to thinking that i probably need to solder everything that the gtx 750ti have but gtx 750 didn't...
                            11-07-2025, 11:12 AM
                          • learnmore
                            Help choosing replacement transformer for Levoit 600S SMPS
                            by learnmore
                            Hello Community,
                            I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                            Peace
                            LM...
                            11-04-2025, 09:35 AM
                          • Jane
                            How do you test MOSFET in laptops ?
                            by Jane
                            I tried to use this method:
                            Testing an N-channel MOSFET:
                            Step 1: Discharge the Gate (turn off the MOSFET)
                            Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                            Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                            Step 2: Charge the Gate (turn on the MOSFET)
                            Now, place the red probe on the Gate (G) and the black probe on the
                            09-27-2024, 03:31 AM
