Sizing substitutes. What's the percentage?
  • dcapper
    • Dec 2013
    • 496
    My Bell ExpressVu receiver is acting up and I found 4 bulged 1200uf 6.3v caps and 2 bulged 820uf 6.3v caps. I have the 820uf caps but they are 35v. I know that is not a problem but can I use a 1000uf 25v cap instead of the 1200uf cap?
    EDIT: The old caps were Teapo's. The 1000uf ones I want to install are Nippon Chemicon.
  • japlytic
    • Oct 2005
    • 2086
    Re: Sizing substitutes. What's the percentage?
    It is most likely that you would have problems fitting in a higher voltage unit in the place of the lower voltage unit.
    I recommend replacing all of the non-Japanese electrolytic capacitors, as some cable and satellite receivers get rather hot inside and literally bake the power supply.
    • R_J
      • 9535
      Most electrolytic capacitors are rated plus or minus 20% going from 6.3 volts to 35v is a bit much, but they will work, I would use 6.3 or 10v to keep the size down.
      • dcapper
        • Dec 2013
        • 496
        The Nippon 1000uf I used were 10v. They fit perfectly. The 820uf ones I had were 25v but taller and the same thickness. I only had one Nichicon 820uf but I had three Sam Young ones. Will they do or should I look at changing those in the future? The receiver is working great so far. The bulged caps I pulled out varied from 400uf to 800uf when I metered them. Where I installed the caps, there was lots of room. It wasn't cramped at all, so the larger caps fit good.
        • Agent24
          I see dead caps
          • Oct 2007
          • 4952
          • New Zealand
          A 20% 1200uF capacitor could be as low as 960uF and still be within spec. If your 1000uF replacements don't measure any less than that, then I don't see there is likely to be a problem.
          -David VanHorn
          • dcapper
            • Dec 2013
            • 496
            I metered the Nippon's before installing them and they read over 1000uf. So I'm sure they'll be fine. I'm more worried about these Sam Young caps.
            • Agent24
              I see dead caps
              • Oct 2007
              • 4952
              • New Zealand
              They'll work for now but I say replace them with something better when you can.
              -David VanHorn
              • dcapper
                • Dec 2013
                • 496
                Thank you so much. I'll order the proper caps from simoncapacitor on ebay just to be safe. Even though the unit is working great right now.
