Printable Panasonic capacitor chart?
  • ron350
    • Feb 2014
    • 296
    I am looking for a Panasonic capacitor chart that is printer friendly.
    So far I have only found this (below) and can't figure out how to print it.
    http://www.panasonic.com/industrial/...BA0000_AM.html
  • mariushm
    • May 2011
    • 3799
    Re: Printable Panasonic capacitor chart?
    US version of the site is ugly.
    Try the EUropean one:
    http://industrial.panasonic.com/eu/p...ectromech.html
    See the center column. For example here's electrolytics:
    http://industrial.panasonic.com/www-...BA0000_EU.html
    • ron350
      • Feb 2014
      • 296
      Mariushm thank you for the help that is what I was looking for.
      Now I can keep up with the conversation here when only the series letters are given, like FC or FK.
      • MORETTIGIAN
        by MORETTIGIAN
        Title:
        Description:
        Procedure performed:
        - Removed backplate
        - Reapplied thermal compound
        - Reassembled card
        09-18-2025, 12:14 PM
      • Prolog
        by Prolog
        12-01-2024, 08:27 PM
      • anty
        Lenovo Yoga 13 mb: Yoga 13 MB Panasonic capacitor identification
        by anty
        Panasonic capacitor identification...
        07-07-2023, 01:06 AM
      • chth96
        by chth96
        12-22-2023, 04:34 AM
      • chth96
        by chth96
        06-02-2024, 07:31 PM
