Hello Everyone. I have a question about old capacitors. They are about 10 years old and been setting in the garage. Below freezing in the winter and 120 f+ in the summer. They are rubycon mcz 6.3v 820 uf. They measure about 720 uf with esr of .03 at 120 hz. Should I trust them or pitch them?
rubycon mcz
Re: rubycon mcz
100kHz is the normal test frequency I believe... try with that and test against datasheet... I don't know, but if they look good and test OK... why not? Or at least, you might as well test them on something, and check them to see how they're holding up after a while.
You might want to try reforming them before use, though.
Probably someone else can give a better answer"Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHorn -
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
Re: rubycon mcz
Agreed. Typically a mildly out of spec Rubycon will read slightly higher (but within tolerance) of its rated value. When they're low, especially that much, they're typically bad. Are these "new old stock"? Are they in a device? Are they just caps you've cannibalized from something else? Either way, I don't think I'd trust them.
I do happen to have some very nice and new replacements for them:
https://www.badcaps.net/store/produc...roducts_id=163<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team StatsComment
by chth96Hello
I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor.... -
by khelaneHello
I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
Is there a way... -
by chronic519Hello.
GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
Found issue with a RAM block
Replaced, green lines gone.
Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
Used a good card to test and same results low errors 32+.
I am just search for some form of command to do a full test on the GPU.
I just ran the mats command with my good GPU and passed after roughly 40 min.
The repaired one, ran... -
by hemant_2222Hello Guys,
Greetings!
Hope you all are doing well.
I am looking for suggestion on Yamaha 2064. The problem with this receiver is that it has no sound however when the test tones are activated it does outputs from all the speakers. It is working in two channel stereo mode but when you select other sound modes, it doesn't. The last time it had a problem, I had replaced the DAC
PCM1681DBQR - IC263 and it worked fine.
Other issue with it is one of the STK ICs is getting more heated then the other one but that can be looked at later.
by alltvrepairsHi,
i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
Appreciate your help....2 Photos - Loading...
