Help finding a thread
  • bLoodMaN
    • Apr 2007
    I just saw this thread with a bunch of pictures of capacitors, and I'm tryn to find the ones that I need for my amplifier for my car but I lost the page it was on. Anyone know of this page I'm looking for?
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Help finding a thread
    theres shitloads of them. what else did it say?
    • bLoodMaN
      • Apr 2007
      I got it, it was the video capacitor thread or something. I have an amp for my car stereo and I blew a couple capacitors. I think I can soder new ones to the board but I'm tryn to find which ones they are. I'm lookin for my camera I'm goin to post a picture up since this forum seems very helpful hopefully somebody can reconize them and help me find replacements.
        by Vesko356
        08-11-2023, 03:27 AM
      • Nevillet
        Dummy loads for amplifier fault finding
        by Nevillet
        Hi All,
        I'm looking at upgrading my load resistors for power amplifier diagnostics and have a few questions:
        1. is it possible to use e.g. a kettle element as a load?
        and at the other end of the financial spectrum..
        2. Electronic loads - would they work?
        3. What's the gold standard method?
        Many thanks.
        05-25-2022, 12:42 PM
      • danielgerman681
        ENCONTRAR DATOS DMI EN EL CHIP BIOS IDEAPAD5 15ITL05 / FIND DMI DATA ON IDEAPAD5 15ITL05 BIOS CHIP
        by danielgerman681
        Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
        08-27-2025, 01:17 PM
      • jinu_j
        How to test Subwoofer Amplifier with only a multimeter
        by jinu_j
        Hi Folks
        Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
        Problem
        I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
        Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
        Any advice would be appreciated...
        08-29-2024, 02:05 AM
      • corrize
        Where to find a very small fpc connector 0.3mm between 2 pins ?
        by corrize
        Hello, I search this connector (oxydated).
        It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
        I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
        I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
        Do you know how to find this connector please ? What is the exact name for find it ?
        08-06-2024, 05:25 PM
