Guess what, another post about faulty caps
  • RJARRRPCGP
    • Jul 2004
    • 6304
    The reported symptom is that the motherboard won't stay on. The motherboard will shut down within one second.
    The motherboard appears to have a leaking cap out of the box!!!
    The faulty cap post is at:
    http://emutalk.net/showthread.php?p=231383#post231383
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
  • RoadKill
    • Jun 2004
    • 49
    And here's another...
    http://forums.anandtech.com/messagev...&enterthread=y
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
    • Paxman_Swede
      by Paxman_Swede
      Hello!
      01-14-2025, 09:51 AM
    • captain150
      by captain150
      03-16-2025, 07:34 PM
    • Foetuss
      Gigabyte GA-6OXT :: caps question
      by Foetuss
      Good evening
      I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
      Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
      But I was also suprised about the bigger boys, which are 330µF 25V.
      Could it be they used 25V caps because they were cheaper / available at that time?...
      02-11-2025, 12:22 PM
      by momaka
      03-12-2025, 03:42 PM
