X or Y class capacitor for replacement ?
  • nonanche92000
    • Mar 2014
    • 19
    • France
    hi guys,
    I need some advices for capacitor replacement, one of them is slightly cracked at the top , values are 0.1µf 250 VAC for both , they are connected between phase conductors and grounded to the case.
    I think they are EMI Suppression Capacitors , but i'm not sure of it , in the listing part , they are listed as polyester capacitor (C.POL).
    Here is a picture and the schematic (C1 and C16) :
    Main Pc : core i7 2600k @ 4.2 Ghz, ga-z77x up5 th , raptor WD 300Go , 16 Go crucial ballistix 1600 Mhz ,Asus Strix GTX980 DC2OC , Cooler Master storm trooper , Corsair AX860i.
    Laptop : Asus X73SV-TY549V
  • japlytic
    • Oct 2005
    • 2086
    Re: X or Y class capacitor for replacement ?
    Welcome, monanche92000!
    I would recommend X-class for both since they are isolated from the mains.
    X-class units are directly connected to the mains between L-N and Y-class units are connected directly between the mains between L-E and N-E.
    • nonanche92000
      • Mar 2014
      • 19
      • France
      hey Japlytic,
      In the schematic , they are connected between phase conductors and earthed casing and thus by-pass operating insulation, i thought to Y class at the beginning like in this scheme , it is very confusing, what do you think of this scheme, (coming from murata manufacturer).
      • nonanche92000
        • Mar 2014
        • 19
        • France
        Here is a more advanced schematic , the two capacitors are in the red circle,
        just in case...
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          I am nowhere near as experienced as others in this, but I would suggest to do as japlytic suggested: X-class only between L-N lines or L-L lines and Y-class between N-E and L-E, as that's the only way I have ever seen them. Reason why you don't put X-class on N-E and L-E is because they can sometimes short out, thus posing a shock hazard if ground is not proper. Y-class, on the other hand, go open-circuit when they fail, which is good because they are connected to ground.
          Also, I *think* the 0.1uF X-class caps might trip some GFCI outlets if you put them between L-E. Please correct me if I am wrong on this.
          • artvandalai
            Where can I get compatible capacitor for replacement?
            by artvandalai
            Blew the capacitor on my analytical balance scale using the wrong power adapter. I need help finding a replacement compatible capacitor to buy. Will any 100uf 40v capacitor work as a replacement?
            12-28-2024, 10:15 AM
          • r2digital
            klipsch kda-500 amplifier suitable power supply capacitor replacement ?
            by r2digital
            I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
            04-18-2024, 03:50 PM
          • Lee Majors
            Snubber Capacitor Vs Class X2 Capacitor
            by Lee Majors
            Is a snubbing capacitor fine to use in place of an X2 suppression safety? The only real difference I see is that the dV/dt is around 3 times higher than the recommended Class X2. Is this a positive or negative issue in this turntable audio device? See C601...
            10-30-2023, 03:32 AM
          • rwkish
            Discontinued Capacitor looking for Replacement
            by rwkish
            Capacitor has been discontinued (EGXF101ELL331MM20S) all of the replacements I have found have are smaller than 0.709" Dia (18.00mm). I would like to use the same size or at least close to the same size Capacitor. 19mm would be too big as they would touch and not be able to through hole mount. Tia...
            08-18-2024, 06:54 PM
          • Hylax
            Replacement capacitor options please?
            by Hylax
            Hi, I'm super new to this capacitor stuff but I've some basic soldering experience with old cellphones PCBs and headphones. I have this APAQ AR5K 820∆μF 3V Dc Capacitor from a motherboard that I'm looking to replace, photos I've attached. But I'm unable to find a 3V one like I've marked in the spec sheet in red (This is the one currently present in the motherboard). But the 6.3V one I can find (marked in blue) is of similar dimensions but different specs as mentioned in the table. Is it okay to replace it with higher voltage cap, slightly higher ESR, slightly lower ripple current, and double...
            08-09-2024, 11:25 PM
