Can anyone identify the value of the damaged capacitor in the photo of the HP9115C 6kVA UPS? The UPS turns on but displays an error, and the battery won't charge. The specific capacitor value is crucial for troubleshooting, . Please help to fix this problem
How To Find This Damage Capacitor Value
6(microfarads) 5% tolerance(J) 275V ???
Left to 6 could be a 0.............so my bet goes for a 10 microfarad capacitor there.Last edited by Francesc V.; 11-30-2023, 06:18 AM. -
275 VACPeteS in CA
****************************Comment
by MORETTIGIANTitle:
Description:
Procedure performed:
- Removed backplate
- Reapplied thermal compound
- Reassembled card
- GPU powers on and operates normally under...11 Photos -
by chth96I usually tried to find datasheet which contains Maximum ESR value like KME datasheet.
https://www.westfloridacomponents.co...0RM10X20LL.pdf
As far as I know,Maximum ESR means boundary ESR value for bad capacitor.
But,In many case,there is no ESR value in datasheet like below links.
SAMWHA-RG Series (mediafire.com)
samyoung_SMS_Series (mediafire.com)
GF-SAMXON (mediafire.com)
So If there is no information about ESR value but only Loss tangent value in datasheet ,I always calculate maximum ESR value by using below...-
by esben72TL;DR at bottom
**Picture called Overview points out the cap in question***
I have this RTX 2070 - It boots into bios but smells really burnt, so I opened it up I and saw the culprit:
An SMD component with "100 C85" written on it.
I want to find a replacement, and put it in to see if that fixes the card,
but I have no experience in finding electronic components,
and I dont even really know what a capacitor does in detail.
Can some one help me, I have no real knowledge of electronics,
but I have... -
by PrologHi people, I hope this is the correct spot to post this, I'm new to the forum.
I have found the board schematic (attached), but there does not seem to be a boardview available. I have never... -
by SluggerBHaving a hard time finding one of these in stock anywhere....
- Loading...
