Capacitor compatibility - noob
  • CivicSpoon
    • Dec 2013
    I recently had my LG L204WT monitor fail on my, and it's clear that at the very least some of the capacitors are bad (bulging/bloated). So now I need to find some replacement ones, which is where I'm having problems.
    This is what it listed on the side of the capacitors {they are all Samxon GF(M) 105°C8}:
    V7A 1000uF 16v
    V8A 1000uF 16v
    V5A 1000uF 25v
    V8A 680uF 25v (Two of these)
    I've tried searching for these, but haven't come up with any specific details, as to what it directly compatible. I have seen quite a few full kits, specifically for this monitor, but they list the V7A and V8A, as the same. I say they list them as the same, only because they specify a difference between the 25v and 16v ones, where it includes two 16v ones. Seeing as the part number is clearly different, I'm assuming they should in fact not be the same if I purchased new.
    Via a Sticky on here, I found the technical info on the Samxon GF series of capacitors (Here), but it's way over my head. I suppose what I'm really wondering is if anyone has any specific experience with this brand and series or capacitors, and could point me in the right direction, to find replacements. Even a company name and series, would be very helpful.
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Capacitor compatibility - noob
    Try digikey look for panasonic FR FM FC series (best to worse )
    Or try badcaps.net
    https://www.badcaps.net/pages.php?vid=26
    You will need to be careful on the physical size
    • CivicSpoon
      • Dec 2013
      Ok, so I just have to match up the uF, volts, size, and shape? Then just pick the brand and series, and that's it?
      Thank you very much for the response.
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Almost - you must get low esr caps from a reliable seller. Panasonic FR FM FC from digikey.
        Badcaps.net only sells low esr caps. so guess its safe to say any he has with the
        correct voltage uf and size will be good.
        You can also go smaller in size with the same V and uf (Some newer caps are smaller)
        • MORETTIGIAN
          by MORETTIGIAN
          Title:
          Description:
          Procedure performed:
          - Removed backplate
          - Reapplied thermal compound
          - Reassembled card
          09-18-2025, 12:14 PM
        • Prolog
          by Prolog
          12-01-2024, 08:27 PM
        • chth96
          by chth96
          12-22-2023, 04:34 AM
        • chth96
          by chth96
          06-02-2024, 07:31 PM
        • chth96
          Is it no harm to replace with capacitor without ripple current rating?
          by chth96
          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
          Rubycon YK DataSheet (b...
          04-19-2024, 05:19 AM
