My first re-capping mistake and advice
  • jpyerry
    • 94
    So I recently performed a recapping on an Antec Smart Power PSU. I chose to replace all electrolytic capacitors, I used mostly Panasonic FC series and a couple of Nichicon HE's. I finally reassembled it into the case and fired it up, the 12V rail was fluctuating pretty extensively, but the 5V rail was rock steady. I thought that I just needed to apply a load and maybe it would even out. But as I was contemplating my next step, steam started pouring out of one of the two Panasonic FC 3300μF 16V capacitors, it almost looked like the steam coming out of a tea kettle, and surprisingly it did not smell as bad as I was lead to believe, it almost had a toasted almond aroma to it (perhaps there is some cyanide ion in the electrolyte?). So I immediately cut the power once I realized what was happening.
    I did a little investigating and discovered that I had indeed reversed the polarity, I couldn't believe it, normally I am not that careless. But there it is, I got to see my first capacitor venting right in front of me, I guess it was kind of neat to see, but I would have rather not had it happen to such an expensive capacitor or to a device that was such a pain to both disassemble and reassemble.
    So my question is, should I replace both of Panasonic FC 3300μF 16V capacitors, or just the one that failed? They both got quite warm, of course the vented one was much warmer than the other. What do you guys think? This is the first time I've made this stupid mistake.
  • u271D
    • Sep 2013
    • 59
    • Ukraine
    Re: My first re-capping mistake and advice
    If they where both in revers then replace both; check the ESR on all the others and compare to the spec sheets.
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      I would just replace the one that was in backwards, I'm sure the other ones are fine
      • PeteS in CA
        • Aug 2005
        • 3580
        • USA, Unsure of Planet
        Watching a 16x35 or an 18x40 venting is pretty cool, as they blow off steam for a while. 12.5x20s and x25s, mehhhhh.
        PeteS in CA
        • jpyerry
          • 94
          Thanks for the advice, I will probably order two new ones, just in case. But I will only replace the one.
          • mariushm
            • May 2011
            • 3799
            My advice would be to replace both.
            Even though the second may show no signs of damage, you have no way of telling how damaged the capacitor is inside.
            This can in turn cause a sort of cascade effect, making the other capacitor work harder and lose its performance/degrade faster. Is less than half a dollar worth gambling with that thing?
            • jpyerry
              • 94
              Is it feasible that approximately 90 seconds ... two minutes tops in my circumstance, would have caused the kind of damage you are talking about?
              Both Mouser and Digi-Key sell EEU-FC1C332's for close to a $1.50 apiece, if you have a source of them for less than a 50¢ apiece, I want to give them my business.
              Regardless, I was thinking about replacing them both anyway, taking the thing apart is a real pain, and I don't ever want to have to do it again.
              • goodpsusearch
                • Oct 2009
                • 2850
                • Greece
                I have reversed the polarity of a primary cap! The cap was Teapo 200V 470uF. It sounded like a water-boiler and became incredibly hot to touch. I unplugged the psu after just 1 minute of operation. Fortunately the cap did not bulge and its esr/capacity were measured normal with my esr micro meter. The psu works without a problem till today, so I would just replace 1 of the 2 caps and observe the cap that got reverse polarity. You would like to check its esr and capacity first though.
                • theOracle
                  • Nov 2012
                  • 163
                  Absolutely replace both of them, when a cap is installed backwards, immediate damage is done, even in the very first 2 or 3 seconds!
                  __________________
                  the BIG 4
                  ~~~ the top tier of low-ESR electrolytic capacitors ~~~
                  • jpyerry
                    • 94
                    Just to bring a little closure to this thread, I got the replacement capacitors in today, soldered them in place (I did replace both the vented one and the non-vented one). The power supply now works perfectly.
                    Justin
                      ALIENWARE Steam R2 i7-6700T Specification for Upgrade or Repair
                      This specification for the ALIENWARE Steam R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam R2 boardview and Steam R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ALIENWARE Steam...
                      09-12-2024, 03:28 PM
                      ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
                      This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                    • Gwynz
                      First time recapping a motherboard, need advice!
                      by Gwynz
                      Hey guys, I just picked up an old Athlon motherboard (Chaintech 7AJA2) to build a vintage PC system around and noticed it had a leaking cap and a few others that appear to be bulging
                      It does boot up fine though, just finished installing Windows XP and it ran through a few 3dfx demos successfully (using a Voodoo3 3000 AGP card) but it does seem to have issues when I have more than one stick of RAM installed, should I also change out the little squat capacitors that are around the DIMM slots even though they appear fine?
                      04-04-2022, 11:44 PM
                    • JayPoorJay
                      Steam Generator - To Be or Not To Be - And 1000 Other Questions
                      by JayPoorJay
                      Good Morning All.
                      Now I've gone and done it! Wife and I bought a big old "new" 100yo colonial house and a guy can dream, right??? I'm building a sauna and a steam shower in the basement.
                      At this point, because of y'all, I've fixed a couple TVs, replaced a few capacitors and resistors, repaired some E ribbons, ALL with y'all's help and reading here. Next challenge,,,, I am still and perhaps will ALWAYS be at bottom of a steep learning curve with electronics... Anywho,,,
                      These things (Thermosol Steam Suite ASD450) NEW are in the thousands. That plus...
                      11-26-2024, 06:18 AM
                    • proxneo
                      Recapping Sony ICF-SW55 - verifying cap values
                      by proxneo
                      Dear reader
                      I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
                      At the moment, I have selected replacements based on the following list of values:
                      3 x 470uF 10VDC
                      3 x 4.7uF 35VDC
                      4 x 47uF 50VDC
                      8 x 22uF 6.3 VDC
                      1 x 220uF 6.3VDC
                      5 x 100uF 6.3VDC
                      Which...
                      06-21-2023, 12:38 AM
