ASUS Board
  • Magnum12
    • Aug 2013
    • US
    ASUS Board
    My original post: "Howdy.
    I have been chasing a quirky ASUS a7n8x board. Noticed today leaking caps, found this forum, ordered new board but plan on recapping the old board.
    Magnum"
    Wow. I put the new board in. I forgot that my processor was an AMD xp 3000+ because as the caps were failing so was my processor sensing. It had said it was a 2100!
    I am going to get the kit for the old board and see if I can fix the old one unless you think I should order the caps elsewhere. The big ones are the 6.3 v,
    3300mf 's.
    Thanks for your help
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: ASUS Board
    The Asus A7N8X BIOS may call it something else when underclocked.
    Make sure the FSB is at 166 Mhz to get the stock clock back.
    The multi is x13.0. You want 166x13.0 for stock clocks.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • Magnum12
      • Aug 2013
      • US
      Re: ASUS Board
      I tried and be board would not run there. I am thinking the caps are the root cause. What I am saying is that obviously the cpu sensor wasn't working either and it pushed the processor speed down.
      Ordered cap kit.
      Thanks for the reply.
      Magnum
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • DynaxSC
        ASUS STRIX Z490-F GAMING - No POST, stubborn board
        by DynaxSC
        I have this very stubborn ASUS mobo on the bench, and I already face the wall with it. It just refuses to POST, although everything seems to be OK.
        The situation looks like this:
        After connecting the board to the power supply on Nuvoton (SLP_S3#, pin 64), the Low signal (50 ohm resistance) appears immediately. PWRNTN# signal goes through Nuvoton to the chipset (confirmed after removing the chipset). The following conditions are then met for the chipset to generate the SLP_S3# signal:
        1. RTC oscillates normally (32.768KHz).
        07-08-2022, 05:45 AM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • ShadowAi12
        ASUS ROG STRIX B550-F GAMING — Board not powering on properly
        by ShadowAi12
        I recently bought an ASUS ROG STRIX B550-F GAMING motherboard that was listed as "dead, not powering on." However, it does show some signs of life. I've performed several basic measurements and would like to share the results.
        • The board enters a "ready to power on" state after plugging in the PSU.
        • Pressing the power button increases power draw.
        • Sometimes, touching the RSMRST_L pad with a multimeter probe causes the board to shut off and return to standby.
        Measurements:
        (taken after pressing the power button, while the board is attempting to start)
        • H_SKTOOC#
        06-11-2025, 01:05 PM
