Need some advice on which caps to replace.
  • Vinhlol
    • Aug 2013
    • Netherlands
    I stumbled upon this forum after searching for a way to fix my old monitor.
    It used to flicker a lot but nowadays it randomly shows a black screen for a few minutes before turning back to normal. (sometimes the green led is blinking)
    I'm guessing I need to replace the caps because I disassembled the monitor and found out that all the caps are from Capxon and I found a vid about the same monitor on youtube: http://www.youtube.com/watch?v=fT9H2bn0Lio (the board does not look the same though)
    Do I need to replace all the caps including the purple ones? because I can't seem to find any good replacement caps with the same size for those.
    And if I have to replace them all, does someone know how to easily remove the white stuff?
    Pictures:
    Overview: http://i.imgur.com/TcRcRij.jpg
    Purple caps: http://imgur.com/GOmup3C
    White stuff: http://imgur.com/yLUEgTu
    Capxon SZ series
    150uf 25v 8x7 340 ripple 0.40 impudence
    Replacement:???????????????????
    Capxon KF series
    470uf 25v 10x16 1200 ripple 0.076 impudence
    Replacement: http://nl.rs-online.com/web/p/alumin...itors/7497202/
    Capxon KF series
    100uf 25v 6.3x11 370 ripple 0.35 impudence
    Replacement: http://nl.rs-online.com/web/p/alumin...itors/7497199/
    Capxon KM series
    470uf - 10v - 8x11.5 - 290 ripple - ??? impudence
    Replacement: http://nl.rs-online.com/web/p/alumin...itors/7442000/
    Please confirm if the replacement caps I found are good.
    Cheers
  • mariushm
    • May 2011
    • 3799
    Re: Need some advice on which caps to replace.
    The white stuff is glue, you can scrape it away.
    The Capxon capacitors are bad but they don't look like they're breaking down. Still, I would replace them
    Don't worry too much about the size, as long as you can safely put the lid back, you can use taller capacitors. Just make sure the diameter of the new capacitors is not too large, so large that they wouldn't fit in the place you have there. You could even put capacitors on their side on the pcb if they're too tall.
    The capacitors you selected are decent but I'd go for panasonic FM or FR just because they have better tolerance to heat. They're much better in specs but they should still work fine.
    The transformer on the top left seems like it overheated or heats up more than the other one during use.
    This could be a sign of a bad capacitor (the pink one below it) but could also be a sign of dying cfl tubes which pull more current from the transformer.
    Double check the area around that hot transformer and if you see something that looks like it may not be soldered properly, it might be worst touching up that spot by adding a bit of solder to make sure it's soldered properly.
    ps. You can use capacitors rated for 35v or 50v for those 150uF 25v capacitors. In general, you can choose capacitors rated for higher voltage. I also think it would be safe to use 180uF-220uF capacitors instead of 150uF for those 2 particular capacitors, it shouldn't affect the monitor negatively.
    For example this looks ok : http://nl.rs-online.com/web/p/alumin...itors/5261632/
    ps2. If you have room on the board, just use 470uF 25v instead of 470uF 10v - get a pack of 5 or 10 470uF 25-35v and you're done. No need to get two different ones unless you really can't fit a 25/35v rated one in that place.
    ex :
    http://nl.rs-online.com/web/p/alumin...itors/7083721/
    http://nl.rs-online.com/web/p/alumin...itors/5261553/
    http://nl.rs-online.com/web/p/alumin...itors/7396822/
    http://nl.rs-online.com/web/p/alumin...itors/7083945/
    • Vinhlol
      • Aug 2013
      • Netherlands
      So I finally managed to replace the caps using my sloppy soldering skills (1st time using a solder) and it seems like my monitor is working again!
      (ignore the yellowish tint. it's from f.lux)
      Let's just hope it doesn't randomly show a black screen again.
      Thanks for the advice Mariushm!
      • Vinhlol
        • Aug 2013
        • Netherlands
        Hey guys,
        It seems like replacing the capacitors did not fix the problem.
        The monitor works but after using it for a while it randomly goes to a black screen with the green power led blinking.
        Then after a while the monitor goes back to normal.
        Anyone has a clue what the problem could be? Should I just get rid of the monitor?
          master hoarder
          • May 2008
          • 12175
          Given the pink hue, either the CCLFs are at the end of their life or the inverter isn't working properly.
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            Um no, read his post.
            http://justgetflux.com/
              master hoarder
              • May 2008
              • 12175
              Ah okay, I see. I thought that f.lux was typo or something and so I read over it. (And I have a CRT monitor, on which I can turn the brightness down quite a lot for night viewing, so that f.lux stuff is irrelevant for me ).
              • rewease
                Replacement for the Siemens Bakelite caps in an early 1980s SMPS
                by rewease
                There actually was a time when early SMPS and late bakelite housed electrolytic caps coexisted in high end industrial gear. A friend of mine just got himself a CNC milling machine form that time with its first set of now 41 year old caps still installed in the PSU... and it's malfunctioning.
                Two of the caps have already leaked slightly onto the board. I have not desoldered or measured any so far but they should qualify for replacement.
                Now I'm wondering what to put in there as a replacement. First idea was state of the art low-ESR Nippon KY,...
                09-17-2023, 12:53 AM
              • SwedishDiesel
                Dell Optiplex GX260 - Advice Needed for Polymodding Motherboard
                by SwedishDiesel
                Howdy folks,
                I have an Optiplex GX260 that blew a couple of those troublesome Nichicon HM series (ultra low ESR) electrolytic capacitors. Because said caps are obsolete, they are pretty much impossible to find on the market; I did find a listing for some but I believe they are counterfeit. I feel the easiest thing to do would be to replace all the blown caps with polymer ones. I am by no means an expert in electronics, and I've found a fair bit of conflicting information, so any guidance or confirmation would be greatly appreciated. While from a practical standpoint it's not worth...
                10-30-2021, 12:47 AM
                by momaka
                03-15-2023, 10:17 PM
              • Techboxcomputer
                XBOX One S caps value and replacement
                by Techboxcomputer
                Hi -
                I saw there was another post similar to this, but I do not believe he was referring to the same caps I am seeking.
                These caps are in the “B” section of the board and the board is marked C9C11, C9C4, C988. The caps appear to be aluminum sheathed and are marked “FP 95 CD 271 16” The Digikey tech's best guess was Nichicon 16v 271 uf but I don't want a guess and solder in the wrong cap. Do any of you know exactly the value of these caps and a good replacement for them?...
                12-21-2022, 08:35 AM
              • cloppy007
                [MSI KT3 Ultra ARU] Advice on capacitor choice
                by cloppy007
                I've found out that the all the Nichicon HM(M) caps on this board are faulty and need replacement. However, I didn't plan in advance and I don't have good replacement caps.
                The original values are 2200uF, 6.3V, 5mm pitch. According to the datasheet, the rated impedance should be around 13-18 uOhms.
                There are 8 of them, 3 to the left of the CPU socket and 5 on the bottom, very close to the northbridge. They are all connected, according to my multimeter.
                I think I recall hearing that I don't have to use the same capacitance for in series...
                08-21-2023, 03:18 PM
