Help to ID a cap
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Help to ID a cap
    I'm not being lame. I've been diggin' and diggin' trying to find this.
    Then I notice 3 of them in one of your pics where you are talking about Rubyon right there in between the Rubycons. (I dunno how to post pics here.)
    If you will please look in the "The Good Capacitors Photo Thread" at the very first pic (Photo from Intel D875PBZLK motherboard, original caps).
    See the black and yellow caps with the K stamp on top.
    If you look closely on the middle one of the 3 black/yellow caps you can see a trademark of a capital F with a horizontal bar above and below it.
    That's the buggers I'm trying to ID.
    What the heck are they???
    THANKS!!
    Mann-Made Global Warming.
    - Dr Seuss
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Help to ID a cap
    http://jp.fujitsu.com/group/fmd/en/services/capacitor/
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Thank you Sir! ~ That was quick!
      I'm now looking for one with an "S.I." followed by the [circle "R"] symbol.
      [If you know off the top of your head.]
      And in looking for that I discovered that your link in "List of Bad Cap Manufacturers" for su'scon . http://www.su-scon.com.tw/ . .. .. Now redirects to Microsoft.com.
      - Dr Seuss
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        only if you use firefox....
        i am not sure about the S.I. caps. i would recommend they are treated as possible bad ones. the yellow fujitsu are probably ok.
        • Rainbow
          • Aug 2005
          • 1375
          Disabled javascript for that page and it works in Konqueror.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Nope, the yellow fujitsu's are bloating.
            I have two Gateway/GVC Corfu-II, [PCB: MX842] with 5 Fujitsu's each on them.
            3 are bloating on one board and 1 is bloating on the other.
            The Fujitsu's are all 4v 820uf "M" series.
            There are 15 other caps that would need replaced as well.
            (All Teopo on one and all Tayeh on the other.)
            I have to decide if it's worth my time for i815 boards. I have several systems with these boards still in use and I had spare boards for these two but now I'm out of spares. They are NLX in desktop [not tower] cases which I like because I can set the monitor on the case for the right height and the CD drive is right behind the keyboard instead of eye or knee level. ~ But, I have two MSI P4 boards that need re-capped too. Capping party???
            Anyway,,,,
            Thanks for your help!!!!
            - Dr Seuss
            • Rainbow
              • Aug 2005
              • 1375
              Many i815 boards are thrown away because of bad caps - so it's good to fix them as they're not easy to get (at least here - when I get some, they sell out very soon).
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                I haven't found out who S.I. is but I did find another mention of them in here:
                https://www.badcaps.net/forum/showpo...4&postcount=25
                I have 3 boards same make model (FIC FR33E).
                They each have 4 baddie 1000uf-10v.
                Two have S.I., the other has Teapo in those 4 positions.
                The boards zero problems since new but they are going into pain in the butt (to get into) mini cases and those caps are near the Chipset and RAM slots so they are getting changed as a precaution.
                Kinda pisses me off.
                All the other significant caps are genuine Rubycon.
                FIC could'a spent and extra dollar and put good caps it the other 4 spots too.
                The MSI boards I'm looking doing at have the same thing.
                Rubycon by the CPU but Teapo by the RAM, Chipset, AGP.
                The MSI's did quit...
                - Dr Seuss
                • skalaukh
                  Need a photo of the board dag3mpmbce0 rev. E
                  by skalaukh
                  Good day, I need a photo of the board or a photo of the BIOS flash drive binding
                  07-21-2025, 02:51 AM
                • nick3092
                  Mid/late 80's Nichicon Yellow Caps
                  by nick3092
                  I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
                  08-28-2022, 03:56 PM
                • multimesut
                  Dell 2007FPB Yellow Light Problem
                  by multimesut
                  Hello friends,
                  A yellow light was flashing on my monitor. It was like it was constantly cutting power. When I opened it up, I saw that the big capacitor in the high voltage line was leaking. I replaced it. When I turned it on for the first time, it had the same problem again. But then, interestingly, it got better. The yellow light was on steady. But the monitor wouldn't turn on. When I examined them with a thermal camera, I saw that the Fli5961-LF reached 50 degrees Celsius and the EM636165TS next to it reached 100 degrees Celsius and was drawing high current on the motherboard....
                  11-13-2024, 07:00 AM
                • Big Pooka
                  Lg OLED rendering yellow as green, I could use your advice.
                  by Big Pooka
                  Hello all,
                  I just picked up a LG OLED65E6P off of Craigslist (it was practically free). It functions flawlessly in all aspects except it renders yellows as greens. It does so regardless if the source comes through an HDMI port, or streams in through onboard services such as Netflix.
                  I've factory reset all the color options, cleared the panel noise via the onboard option, and waisted half an hour talking to LG customer service.
                  Have any of your dealt with this situation?
                  I understand OLED's are susceptible to burn-in, and looking at the...
                  06-11-2023, 02:39 PM
                • madyoyo
                  Philips 37pfl560: Yellow picture
                  by madyoyo
                  HI.
                  I have a weird problem with an old Philips 37pfl560 TV i put out of storage: the picture have a noticeable yellow hue, and its not caused by the settings (did a factory reset). I've never seen this before. I will try to get a photo with a real camera, with my phone its hard to see because of automatic white balance, but in real live the whites are really yellow.
                  Anyone have an idea of what can cause this? Can CCFL tubes get "warmer" with time? This tv have several analog inputs,so its nice for retrogaming....
                  05-30-2025, 10:16 AM
