MSI KT4V MS-6712 V1.1 Caps?
  • ShawninTennessee
    • Jun 2004
    • 7
    Hello to everyone,
    I just joined up and have a few questions.
    First let me tell you whats been going on with my board. O.k. I bought this board about a year ago off from Ebay. I got it for an awesome price. Just before that my cousin let me build a new system for him. I have been running this board for about the whole year till amonth ago.
    It started turning itself on and off. So i had figured it was the power supply. Bought a new one and same issue. So i had the money and decided to build myself a new Athlon 64 system. But the other board was still working at the time and booting me to BIOS. Well now it wont even do that. It powers on but now wont even turn the monitor on. The fans spin. But to power off you have to do it from the power supply.
    So ive ordered new Panasonic FC series caps for all the large ones. Does this sound like the Capacitors or CPU? What ive read i believe its the caps. None are broken or leaking. But all the7 G-Luxon 6.3v 1000uf's are bulged.
    Hope this helps..
    Shawn
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16955
    First off, welcome to the forums!
    To answer your questions, I have seen bad caps cause CPU's to die. Strangely, only AMD's. I have several dead AMD processors that have been sent to me in boards with bad caps, and the CPU's were dead. The boards all survived, but obviously needed new processors. This scenario is not likely though, it's only been a few out of many dozens of boards. I've recapped MANY AMD boards that didn't have CPU damage. The only bad Intel CPU's I've ever seen were from failed overclocking experiments. I can say that I've put a few P2 and P3 CPU's into an early grave from overclocking...
    If the caps are bloated and vented, there's no doubt as to the problem and why the board will not POST. Recapping should cure it.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • ShawninTennessee
      • Jun 2004
      • 7
      Cheers mate....
      I was so afraid it was completly dead. You have helped me see that it was cool!!
      So you think my chip is ok? I think so to. I think the capacitors just got a bad load of power. But it would explain the sudden reboots it did...Every 5 minutes it did it. For 2 days straight it did. It's the absolute truth. I thought the devil was coming from my computer....LOL
      Thank God for Tennessee...
      • ShawninTennessee
        • Jun 2004
        • 7
        [quote="ShawninTennessee"]Cheers mate....
        Thank God for Tennessee...[/quote/]
        It's good to know theres still of us country boys around?...lol
        So i am right i believe? If it dosent boot you think its a VRM? Or completly dead? I am praying that it wont be that bad... Never had one go out like this....
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16955
          More than likely your CPU is fine. Give it some new caps, and I bet it's back to tip-top shape...
          Team : 49813
          Join in!!
          Team Stats
          • ShawninTennessee
            • Jun 2004
            • 7
            Awesome...I order some new ones and am waiting on them...Hopefully they come in the mail today...
            I'll keep ya up to date...
            • ShawninTennessee
              • Jun 2004
              • 7
              Well i changed the Caps. No diffrence. So i dont know what to think now?
              Have any ideas? It still fires up. Just wont boot.... I have no clue whats up with it....
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • Dani_2024
                by Dani_2024
                10-28-2024, 05:06 PM
              • black6host
                Replacement caps for Samson Resolv studio monitor 65A Amp board.
                by black6host
                Good day!
                I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                I'm going to replace the caps and I'll be the first...
                02-06-2024, 08:22 PM
              • Noodneek
                Replacing all the caps on the BenQ SW2700pt's power board didn't help...
                by Noodneek
                My 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
                I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...
                08-30-2024, 12:52 PM
