which are the most common motherboard cap sizes?
  • theOracle
    • Nov 2012
    • 163
    I am setting up an electronics repair space in the man cave, and want to place a stocking order for the most common low-ESR caps to have most sizes I will ever see on motherboards, etc. already here and not have to always order up and wait!
    could someone give me a top 10 or top 20 most common capacitance & voltage list?
    like what would be someone like topcat's or willawake's or PeteS in CA's 25 most utilized cap sizes that they would keep on the workbench?
    __________________
    the BIG 4
    ~~~ the top tier of low-ESR electrolytic capacitors ~~~
  • retiredcaps
    • Apr 2010
    • 9271
    Re: which are the most common motherboard cap sizes?
    Ironically, right on the front page of badcaps.net
    January Specials:
    Motherboard Value Pack, only $59.95!! Sale ends January 31st, 2013!
    https://www.badcaps.net/store/produc...roducts_id=171
    This kit is tailored for PC motherboard servicing, containing a lot of the common values you will encounter when repairing a motherboard with bad capacitors. If you do quite a bit of motherboard component level repairing, this is the way you will want to go, it will save you time and money! There's nothing worse than needing a particular value, and there be none in the bin!! This Value Pack makes that problem pretty much non-existent!!
    --- begin sig file ---
    --- end sig file ---
    • J_T
      Operating frequency for motherboard common mode inductor/filter
      by J_T
      I have a question - I have replaced the PSU on my own iMac Pro. However, when removing the motherboard I knocked of a 120 OHM 30% 0.3A small surface mount common mode inductor/filter (~0602 size) in the ethernet circuit near the female RJ45 port.
      The closest match I can find on Mouser is 120 OHM common mode inductor at 100MHz - my question is this frequency correct for a motherboard? The schematic for the motherboard only provides '120 OHM 30% 0.3A' and the TDK part number does not return anything in google.
      Sorry, I am not experienced hence a basic question.
      01-04-2025, 05:54 AM
    • glovecaps
      by glovecaps
      11-25-2024, 04:23 PM
    • Docus
      Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
      by Docus
      Hi everyone 😀,
      I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
      To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
      Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
      1. I already own the exact same model, but its plastic chassis is badly damaged.
      06-10-2025, 04:24 PM
    • Archimedes
      HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
      by Archimedes
      Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
      Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
      Fans are spinning. Blindly could install windows11 and got the device manager...
      07-30-2024, 05:14 PM
    • dragon3x
      by dragon3x
      power on.
      Here are some examples :
      switching supply area).
      than 6.3 V.)
      03-21-2025, 02:46 PM
