what's wrong with long leads?
  • theOracle
    • Nov 2012
    • 163
    I do jobs recapping things and I am in the habit of leaving long leads (not on the boards backside, but between cap & motherboard.)
    the reason I do this is that sometimes I feel that it can take too long of heat exposure to get a good solder flow, and I want the caps as far away from the heat as possible, to minimize any heat damage.
    what's wrong with just folding my long leaded caps out of the way when I am done?
    __________________
    the BIG 4
    ~~~ the top tier of low-ESR electrolytic capacitors ~~~
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: what's wrong with long leads?
    Quote from another thread:
    "it's to minimize the impedance of the capacitors, which is important in switchmode power supplies. When working at high frequencies, you need to think of any length of wire as a coil (inductor). The longer the leads, the more trouble they can make."
      Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
      The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
      Securing a good thermal interface between...
      10-07-2024, 04:35 AM
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • edugimeno
      Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
      by edugimeno
      Hi There!
      I'm trying to help my friend who owns a restaurant be just bought.
      He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
      It's stuck using, I guess, the 2 sided tape that comes with the strip
      The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
      09-05-2024, 09:34 AM
    • Victor Moreira Silva
      Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
      by Victor Moreira Silva
      I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
      Well, my decice specs are the following:
      Model: Acer Nitro 5 AN517-54-55T5
      CPU: Intel Core i5-11400H
      GPU: NVIDIA GeForce GTX 1650
      Motherboard: GH51G LA-L181P Rev:1c
      The symptom:
      When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
      05-26-2025, 10:49 AM
    • karatzdi
      Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
      by karatzdi
      I know some might say... just buy another one. Sell it as parts..!
      So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
      Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
      Spent some time downloading the Service...
      06-11-2024, 08:38 AM
