Netgear WNDR3700 Whining Sound
  • shpitz461
    • Nov 2012
    • 10
    I got an issue with a WNDR3700 that recently started whining. I've read about the capacitors issue so I figured out that must be the problem.
    I opened it up, and even though none of the capacitors seem to be bad, I still replaced them.
    Back:
    Front:
    The caps I replaced are marked in Red.
    I put my ear to the board, and i think the sound is coming from the area marked in green. I think it's under that silver protective cover.
    Any idea how to remove that cover? what else can cause the whining sound?
    Thanks!
  • mockingbird
    • Dec 2008
    • 5484
    Re: Netgear WNDR3700 Whining Sound
    You'd think Netgear would use decent caps on their top of the line $100+ router...
    What did you use to replace them?
    That silver cover is a shield. There's silver foil tape on the right side, and then there are what I would call tabs around the shield. It should be pretty easy to remove if you take your time. I'm pretty sure it's not soldered. I doubt you're going to find anything there.
    Besides double-checking which caps you used to replace the stock caps, I suggest you take a good look at the AC Adapter...
    • shpitz461
      • Nov 2012
      • 10
      Thanks for the quick reply!
      I've replaced them with the following:
      Lelon 470uF 16V High Temp Radial Capacitor
      Lelon 470uF 25V High Temp Radial Capacitor
      I'm at a total loss as to where the fault is causing the whine sound.
      • mockingbird
        • Dec 2008
        • 5484
        From the fire into the frying pan...
        Don't use Lelon caps. What were the originals? Also, did you crack open the Adapter?
        • shpitz461
          • Nov 2012
          • 10
          I threw away the original caps, they had a light blue casing, and all I remember is that they had a 6-digit number, but no brand that I could see.
          You think the A/C adapter might be causing this?
          • mockingbird
            • Dec 2008
            • 5484
            First I would put some high quality caps in there to eliminate the possibility of them being the problem.
            Yes, the adapter could also be causing it.
            • shpitz461
              • Nov 2012
              • 10
              Can you point me in the right direction?
              I'll look into the A/C adapter as well.
              Appreciate it!
              • mockingbird
                • Dec 2008
                • 5484
                Depends where you want to order from. See what caps the adapter needs, and then I can check which supplier has the best selection because those adapters often use caps which have odd sizes that are not universally stocked.
                • shpitz461
                  • Nov 2012
                  • 10
                  Sounds good, thanks!
                  I will check the A/C adapter tonight or tomorrow and get back to you.
                  • redwire
                    • Dec 2010
                    • 3910
                    I'm in the middle of recapping my WNDR3700 V1. It's a great router, works fine but the 2.4GHz RF range is poor, so I am also doing the quad external antenna mod. Many people report "radio death" on these routers which I'd guess are due to failing capacitors. I have good Lelons but swapping them out. Upgrading to OpenWRT (wiki with lots of info) firmware seems to change the power drain. Again, guessing the RF section regulators get unstable and weak caps cause it to whine.
                    Measured (router works):
                    C118 (12.2VDC IN) 470uf 25V; 10mmOD x H=17mm, 5mm/0.2" LS
                    C73 (5.26V RF) 470uf 16V; 8mm OD x H=16mm, 3.5mm LS
                    C276 (5.44V RF) 470uf 16V; 8mm OD x H=16mm, 3.5mm LS
                    C142 (1.23V CPU) 470uf 16V; 8mm OD x H=16mm, 3.5mm LS
                    I'm going with Nichicon long life HE series:
                    470uf 16V; 8mm OD x H=15mm, 3.5mm LS; UHE1C471MPD Digikey 493-1522ND $0.53 ea.
                    470uf 25V; 10mm ODx H=16mm, 5mm LS; UHE1E471MPD6 Digikey 493-1553ND $0.78 ea.
                    The AC adapter measures 12.2VDC with no load and under load, it's still working. I feltpenned the LED's- they were too bright.
                    • PeteS in CA
                      • Aug 2005
                      • 3581
                      • USA, Unsure of Planet
                      If Lelon's quality were as good as their aggressive/tenacious marketing people they'd be world beaters. But their quality is not good enough for stressful applications. Nichicon HE series is good stuff - not the utterly lowest impedance, but still quite low, and tough enough for stressful applications. UCC's KZE series and Rubycon's ZL series are about the same performance and quality/life.
                      Lelonian (and others') crap may be cheap up front, but how much does flaky equipment performance and two years' shorter life cost (or POed customers)?
                      PeteS in CA
                      • PeteS in CA
                        • Aug 2005
                        • 3581
                        Addendum: even in commodity products, like much computer gear, brand familiarity/loyalty is highly significant in purchase decisions. If you save a few cents apiece by using crapacitors it adds up to big $$, BUT you have to sell a LOT of routers or computers or motherboards to make up for a few thousand highly POed former customers telling tens of thousands of friends not to buy XYZ Brand whatevers because their quality is terrible!
                        PeteS in CA
                        • shpitz461
                          • Nov 2012
                          • 10
                          I'm struggling in opening the A/C adapter, can you show me how to open its case w/o breaking it? I don't see any screws holding it together, how do I separate the plastic cover?
                          • mockingbird
                            • Dec 2008
                            • 5484
                            Dremel tool. Don't cut too deep.
                            • shpitz461
                              • Nov 2012
                              • 10
                              Got it, used a utility knife for starters, then a flat screwdriver and a plastic prying tool to open it, was tough to do since it was glued pretty good.
                              I'm not seeing anything wrong with it:
                              But it smells pretty bad, I wonder if it's just defective and is what is causing the router whine, what do you think?
                              How can tell if the adapter is good? What should I check for? It is rated 12v@2.5A, I do have a digital DMM.
                              Thanks!
                              • ben7
                                Capaholic
                                • Jan 2011
                                • 4059
                                Thanks!
                                It's typical for some of them to smell bad. The smell comes from the tape, glue, or plastic, etc...
                                Try replacing the output capacitors with a good brand.
                                Muh-soggy-knee
                                • shpitz461
                                  • Nov 2012
                                  • 10
                                  You mean those two blue ones?
                                  I also don't think the plates were connected that well to the transistors, they are held by a screw.
                                  • ben7
                                    Capaholic
                                    • Jan 2011
                                    • 4059
                                    Yep!
                                    Muh-soggy-knee
                                    • mockingbird
                                      • Dec 2008
                                      • 5484
                                      I disagree. I am familiar with the smell he's talking about. I think it's from electrolyte vapor reacting with some of the components in the sealed adapter. I know that smell from many adapters I've opened up with Chinese caps.
                                      Change -ALL- the capacitors, including the primary cap... Small primary caps from unreliable brands should be treated the same as secondary caps. They don't typically last like the big off-brand input caps. Don't forget to change that small cap near the large input cap that's covered with silastic.
                                      If you want to test it, put your multimeter on AC mA setting and see how much AC is leaking through.
                                      Post the brand, diameter, series, and dimensions of each cap.
                                      • redwire
                                        • Dec 2010
                                        • 3910
                                        I would measure no-load voltage and then load test it, with something like a car taillight bulb, that's about 1.5A or use a big resistor.
                                        What value are the two blue caps?
                                        The soldering on the output inductor (donut) looks weak and I would touch them up.
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • LEECH666
                                          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                          by LEECH666
                                          Good day ladies and gentleman!
                                          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                          01-19-2024, 05:46 PM
                                        • Christos Tsiligiannis
                                          Marian Trace Alpha sound card repair help
                                          by Christos Tsiligiannis
                                          Hello to the forum.
                                          My name is Christos, I am new to the forum here and i am posting from Greece.
                                          So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                          To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                          So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                          11-18-2024, 05:26 AM
                                          HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:30 PM
                                          HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
