Where to buy high quality capacitors?
  • ChaosBlizzard
    • May 2004
    • 32
    I wanted to know if anyone has a link to a good online retailer that can sell me the highest quality capacitors for my abit vp6. I was considering Panasonic, Sanyo, and or RubyCon... Dont know which is top brand..
    Thanks,
    CP
  • ShawninTennessee
    • Jun 2004
    • 7
    Heres a link to a good online resource of Caps...
    http://www.digikey.com
    They have Panasonic caps. I just order some from them.
    • MD Willington
      • Sep 2004
      • 702
      Happen to know what the exact type is, the filter at digikey is a PITA
      MD
      Ya'll think us folk from the country's real funny-like, dontcha?
      The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
      • dragon3x
        by dragon3x
        power on.
        Here are some examples :
        switching supply area).
        than 6.3 V.)
        03-21-2025, 02:46 PM
      • Biruslapio
        Samsung's AU series "high quality" panel internally melting
        by Biruslapio
        I got this 55 inch AU7X00 TV, it was rebooting and showed no image only a blink of the backlights.
        I assumed it was either panel or motherboard. Turns out it was the panel, and after applying some tape on the ribbon cable that goes to the left side of the screen, the TV turned on with image, then I suddenly noticed a dark spot and the pixels were turning black on the left edge, I was sad and thought I smashed the screen somewhere, found nothing visually, it looked in perfect condition and if it was there before it would've been noticeable while I was inspecting the TV the first time....
        07-12-2024, 10:08 AM
      • P4C800
        ASUS P5A and P2B-S recapping. Searching old datasheets.
        by P4C800
        I'd like to recap some of my old mainboards (they are from 1998) before switching them on again for the first time after many years in storage. All caps still look good from the outside.
        There are three mainboards:
        - ASUS P5A rev 1.04
        - ASUS P2B-S rev 1.03 "Rubycon"
        - ASUS P2B-S rev 1.03 "Chemi-Con"
        If you are interested in their specs, The Retro Web has pages for the P5A and the P2B-S.
        They all have many 1000uF 6.3V 105°C capacitors. But there are some differences I cannot figure out.
        P5A
        10-09-2023, 05:55 AM
      • slybunda
        AA and AAA battery charger capacitors?
        by slybunda
        hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
        it has inside:
        2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
        2 x 470uf 16v LZ105c branded as G.Luxon
        not heard of these brands are they any good?
        iv attached photos of the charger and the board inside for an idea on the type of...
        12-24-2023, 04:41 AM
      • link626
        damn. I'm disappointed these high quality caps made my power supply worse
        by link626
        I thought my tv power supply was stable. It's been stable for a few weeks since I swapped in nichicon, united cc, panasonic caps to replace the cheap china caps.
        But today it caused my tv to have a flickering spasm again.
        what a letdown.
        I swapped back my backup power board which has cheap china caps, and the tv backlight stopped flickering.
        Sometimes these high quality caps just don't make things better.
        09-01-2021, 11:02 AM
