Need help identifying this special capacitor
  • Anndy
    • Aug 2012
    • 10
    Hey all. I need to replace an aluminum smd capacitor on a video card and I'm quite puzzled as to what it's value actually is because it's kinda cryptic.
    All it says on it is:
    100
    16G
    572
    Anyone have a clue what this means?
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Need help identifying this special capacitor
    A picture always helps is there no sort of logo what colour is the print
    My best guess would be
    100uF
    16volts....... (Series G)
    572 Manufacturers code
    • Anndy
      • Aug 2012
      • 10
      There is no logo and that's the only text appearing on it.
      It's a short, surface mounted aluminum capacitor with black on the left side and it looks similar to this one:
      Thanks for the quick reply btw.
      Edit: That sounds like a good guess to me, Makes a lot of sense. But I'll wait to see if anyone got any other ideas before I make the purchase.
      • Duncanbest
        • Jul 2012
        • 81
        • Taiwan
        http://www.yageo.com/portal/product/...uct/Ecap/E-Cap
        Yageo SMD capacitor CA or CB series
        100 100uf
        16G 16V g for general purpose
        572 data code
        • Anndy
          • Aug 2012
          • 10
          Thank you very much Duncanbest!
          I guess that settles it.
          • Prolog
            by Prolog
            12-01-2024, 08:27 PM
          • Ambro
            Help identifying missing smd capacitor for HP elitebook 840 g3
            by Ambro
            In an unfortunate mishap while attempting to read from the bios chip, one of the smd capacitors took flight and disappeared.
            I'm not sure how crucial this smd capacitor is, but it was a brown possibly ceramic one with no notable markings on it anywhere.
            I've attached a picture of where it's located on the board.
            Does anyone have an HP elitebook 840 g3 who might be able to aid me identifying this component. I'm not sure how crucial it is, but didn't want to risk it.
            Thank you for any help you can provide....
            09-09-2023, 06:21 PM
          • grimacelord
            Need Help Identifying Capacitor On Kar-Tech Versa Remote
            by grimacelord
            I have sort of a weird one here. This is the circuit board for a Kar-Tech VERSA remote. It's a wireless transmitter for crane and other heavy equipment.
            One of the capacitors have blown and I need help finding a replacement. The capacitors are 11.4mm x 6.6mm in size and the only imprint on them is "200mΩF", which I am assuming means 200 microfarads. There is no other markings on them. I have tried doing some searching on digikey and mouser, but I can't seem to find anything like this on there or I am inputting the wrong search parameters....
            09-08-2023, 09:28 AM
          • krob80
            PS5 Edm-010 No Power - Help identifying missing capacitor
            by krob80
            Hey everyone. I recently acquired a PS5 that is not turning on (no beep/power). PSU is good and there is no shorting on the 12V rail.
            It came with a Gen3 SSD installed so I feel that things went down hill for the previous owner when it was installed. F7003 was blown but there was nothing shorting to ground. I replaced the fuse but still no power (new fuse is still good for now).
            When connecting it to a bench power supply, it only pulls 10 mA (doesn't spike when first connected).
            I noticed that there are a couple capacitors missing from the Vcore power regulator (pictures attached)....
            05-15-2025, 04:24 PM
          • chunk69
            Looking for help in identifying Kuang Jin capacitor from PSU
            by chunk69
            Hi friends,
            I recently acquired an old PC power supply (along with several vintage motherboards from late 90s/early 2000s). The PSU was dead upon first test, but quickly identified the internal fuse had blown. I fixed that, re-tested and i'm pleased to report it seemed to work great after that - no obvious issues or reasons for the fuse to blow.
            Afterwards, I inspected the capacitors more closely and noticed one pair required replacement. They weren't in bad shape by any stretch of imagination, but one was slightly bulged, and I wanted to swap them out for good measure....
            12-06-2023, 04:35 PM
