A8N-Sli Premium Caps
  • leezer3
    • Aug 2012
    • GB
    So, I've got a socket 939 A8N-Sli Premium board that has lived happily in my server for three years, and in my desktop before that.
    Pulled the board for a look due to random crashes and loosing a disk on cold boots, and I've found three bad caps.
    All of these are 820μF 6.3v KZG caps, all of which appear to be PCI-Express related (PCE12, PCE21 & PCE29)
    Can anyone suggest suitable replacements please?
    The rest of the board has these other KZG caps on too:
    14 more 820μF 6.3v KZG caps
    6x 1500μF 6.3v KZG caps
    2x 1000μF 16v KZG caps
    1x 470μF 16v KZG cap (Some of the 820μF ones may actually be these, it's very hard to read the cap ratings inbetween the PCI slots and around the CPU socket)
    No bulges or anything I can see on these others.
    Cheers
  • mockingbird
    • Dec 2008
    • 5484
    Re: A8N-Sli Premium Caps
    Look at Topcat's Nichicon stock:
    https://www.badcaps.net/pages.php?vid=23
    You need to replace all the KZG. I've done an A8N non-premium board. Look again for the 16V 1000uF 8mm caps, I think there were more than just two. The main caps you want to replace are the 8mm 16v 1000uF and 6.3v 1500uF KZG caps around the VRM and if my memory serves me right, there's also a single 16V 1000uF cap near the memory near the edge of the board.
    You'll want Nichicon HM/HN from the store as a replacement for the KZG you can use HZ, but it's worth noting that their ESR is a little lower, but that shouldn't be a problem. Make sure the caps are 8mm, 10mm caps will not fit.
    • leezer3
      • Aug 2012
      • GB
      You're probably right about the cap numbers TBQH. The ones round the CPU socket and those in between the PCI slots are only best guesses based on size and what I can read until I pull them.
      Being in the UK, I'd semi rather-not order caps from the US.
      I can find these part numbers (Assuming Nichicon caps) which look right:
      820μF 6.3v- UPW0J821MPD
      1500μF 6.3v- UPW0J152MPD
      1000μF 16v- UVY1C102MPD (10mm diameter, but these can be splayed a little I think)
      470μF 16v- UVY1C471MPD
      Definitely no 1000μF near the memory though, that one's a 1500μF
      Having said all that though, it almost looks more cost-effective to junk the board and start again
      I seem to be looking at about £20 or so worth of caps, for which I can pickup a 775 board.
      Shift on the CPU, cooler and memory from this machine, and I'd almost break even.
      Decisions, decisions.......
      • mockingbird
        • Dec 2008
        • 5484
        No, those caps are inadequate for the job.
        That's PW and VY series you listed there. PW is not good enough for the VRM here and Nichicon VR/VY/VZ are general purpose caps which are also not meant for this kind of thing.
        Send me a PM.
        • c_hegge
          • Sep 2009
          • 5219
          For the 820uF 6.3v caps use http://www.digikey.co.uk/product-det...MPD-ND/2428119
          For the 1500uF 6.3v caps use http://www.digikey.co.uk/product-det...PD6-ND/2428126
          For the 1000uF 16v caps use http://www.digikey.co.uk/product-det...397-ND/2433531. They aren't quite as good spec wise as the original KZGs, but they are the only reliable 8mm cap I can find at digikey, and they should be close enough.
          For the 470uF 16V caps use http://www.digikey.co.uk/product-det...019-ND/1136109
          • mockingbird
            • Dec 2008
            • 5484
            Digikey takes 12 quid to ship to UK.
            • c_hegge
              • Sep 2009
              • 5219
              Well, that's still cheap enough
                by momaka
                03-12-2025, 03:42 PM
              • eryjus
                by eryjus
                05-10-2023, 11:21 AM
              • Paxman_Swede
                by Paxman_Swede
                Hello!
                01-14-2025, 09:51 AM
              • captain150
                by captain150
                03-16-2025, 07:34 PM
              • Foetuss
                Gigabyte GA-6OXT :: caps question
                by Foetuss
                Good evening
                I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                But I was also suprised about the bigger boys, which are 330µF 25V.
                Could it be they used 25V caps because they were cheaper / available at that time?...
                02-11-2025, 12:22 PM
