Scary Trend of Rubycon MBZ failures - No bloating!!
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16955
    I got a batch 30 of IBM/Lenovo Thinkcenter boards in for repair from a great metropolitan newspaper.....Yes, that is true, I just won't reveal the city, as it'll give away the client (and it is a large well known city).
    I've repaired a lot of boards with cooked MBZ and MCZ caps over the years (mostly overheated Dells), but this was the first I've encountered this issue. Their IT guy was pulling his hair out, he told me only a few of them had bloated caps, but all of them either wouldn't POST or wouldn't finish booting the OS before rebooting or BSoD'ing...even the ones with caps that 'appeared' perfect. He already replaced PSU's and eliminated that factor...so they show up here....
    I first took one that actually had a couple bloaters on it, right next to a couple FETs in the middle of the board, and replaced only the bloaters, and then bench tested it. The board would POST, but would freeze under MEMTEST in about 2 minutes....so I tried the same thing with another one, same result. There was one last board left that had a couple bloaters, I replaced the bloated caps only, and that one wouldn't even POST. ...so now what...
    I started pulling random caps of the same value of the bloaters and checking them. I was bewildered at the results!! These are so far out of spec, I thought my Sencore had gone screwy, so I checked it with a new cap just to make sure that wasn't the case, and it wasn't the tester that was out!!
    All these caps datecodes range from 2006~2008. They are genuine, not fakes, and original to the boards. They have never been recapped.
    They were all 1000uF 10v Rubycon MBZ Series:
    You will note that the bung is flat, no leakage or damage:
    Same with the vent, it's pristine:
    Ok, here's where it gets interesting!! The value is SUPPOSED to be 1000uF! it's reading 2.78uF
    LOL @ 27 OHMS ESR:
    I pulled several hundred of these over the course of a couple days, this is just one cap that I profiled in this article. The rest were just as screwy. I found there was no pattern. Some were so far out, the LC102 wouldn't even get a reading, or show an open load. They would come from random/different sections of the board, clearly they didn't overheat, yet they were worse than a teapo as far as being out of tolerance but not leaking/bloated!!
    The aftermath:
    I recapped all the boards completely removing ALL their MBZ's and replacing them with Nichicon HM's of the same value. The boards now run flawlessly, and are back in operation. I did check the other caps on the board, there were some Rubycon YK 220uF 16v and a couple Rubycon 470uF YK's as well. Those were all well in spec, it was just the MBZ's. Scary trend for the recappers that don't have the equipment to accurately check a capacitor. Every failed Rubycon I've ever dealt with in the past had vented/bloated/leaked.....
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Scary Trend of Rubycon MBZ failures - No bloating!!
    maybe I should review my stock and toss any in that range?
    or perhaps a bad batch?
    sigpic
    (Insert witty quote here)
    • c_hegge
      • Sep 2009
      • 5219
      If a machine cooks rubycons, I always try polymodding, and failing that, improving the ventilation. If you just recap it with lytics, you'll be back doing it again in a few years time.
      EDIT: I'd use something like http://search.digikey.com/us/en/prod...710-ND/2207246
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16955
        These are for a client, I dont experiment with client machines (ie, polymodding). I also dont believe polymodding is the holy grail of failing lytics. I've had plenty of failed polymod attempts....but that discussion is for another thread.
        I'm thinking they were a bad run by rubycon. When recapping a particular model of board, especially when I have a lot of the same model, you can detect 'patterns' in the failures.....IE, certain clusters/groups of caps fail, while others don't. These failures were in sporadic places on the board, not in any particular 'trouble spot'. Some of the boards yielded not a single good one, every single one was like this. The cases are also fairly well vented. Not the greatest, but overheating doesn't seem to be the root....I've seen what overheating does to Rubycon caps.... IMO, these were just a junk batch. I'm posting this more as a heads up.....if you run into something similar strange behavior from a system, you may not want to trust some of these age group MBZ's that 'appear' ok. It's the first I've see this in Rubycon.....lets see if it was just a fluke, or if this is going to become the norm...
        Team : 49813
        Join in!!
        Team Stats
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          I knew using Fujyuu to recap the motherboard was a good idea!
          /sarcasm
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            /sarcasm
            sigpic
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              Hehe I was joking.
              • smason
                • 1652
                Wow, very interesting! Thanks for sharing.
                Do you think Rubycon/Lenovo would be interested in the failures, or not care?
                • mockingbird
                  • Dec 2008
                  • 5484
                  Those do not look genuine to me... Vent ridge is too deep and printing quality is subpar. I have seen an incredibly good Panasonic FC fake, so I'm not surprised. Open one of the caps up and compare it under a microscope with an equivalent confirmed genuine part...
                  "We have offered them (the Arabs) a sensible way for so many years. But no, they wanted to fight. Fine! We gave them technology, the latest, the kind even Vietnam didn't have. They had double superiority in tanks and aircraft, triple in artillery, and in air defense and anti-tank weapons they had absolute supremacy. And what? Once again they were beaten. Once again they scrammed [sic]. Once again they screamed for us to come save them. Sadat woke me up in the middle of the night twice over the phone, 'Save me!' He demanded to send Soviet troops, and immediately! No! We are not going to fight for them."
                  -Leonid Brezhnev (On the Yom Kippur War)
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16955
                    they're real. The pic is just very close up....but I assure you they're genuine. The odds of IBM using fakes is pretty much nill....they get them factory direct, there is no middleman to the OEM's. I kinda wish this could be blamed on them being fakes, but they are not fakes.
                    here's a pic of one of the boards:
                    Team : 49813
                    Join in!!
                    Team Stats
                      master hoarder
                      • May 2008
                      • 12160
                      That is indeed very interesting. Will definitely keep this thread in mind before reusing old Rubycon MBZ caps (yes, I know I shouldn't reuse caps, but sometimes I don't have new caps in stock and just want to fix the issue ASAP... besides, I reuse caps for only my own stuff). Thank you for the heads-up TC.
                      • mockingbird
                        • Dec 2008
                        • 5484
                        IBM and Lenovo are in cohoots... Lenovo is a Chinese company... Isn't it possible Lenovo had something to do with this?
                        • Topcat
                          The Boss Stooge
                          • Oct 2003
                          • 16955
                          You're reading too far into it. it's no secret that ibm and lenovo are pals.....but on that note, name me one motherboard maker that isn't chinese besides tyan and supermicro.... The point being, the caps are real... There is absolutely no mistake about that. The pics shown are extremely close up with a DSLR camera, it does make them look a little different that close up, but I assure you they're real. I honestly wish I could say they weren't, it would explain this whole strange thread.
                          Team : 49813
                          Join in!!
                          Team Stats
                          • mockingbird
                            • Dec 2008
                            • 5484
                            Yea, but Lenovo is a *Chinese* company... not Taiwanese. The difference being that there is a chance for counterfeit parts to enter the stream...
                            If you saw my Panasonic FC counterfeit (Last one on the left), you would think twice before considering them to be bona fide... You underestimate the counterfeiters... I would love to see microscope photos of the foil etching on them... and even if that matched, who knows about the electrolyte (Though I have to admit, this scenario would be very unlikely).
                            • severach
                              • Aug 2007
                              • 1055
                              When a cap doesn't bloat it means the seal is bad. The seal must be good around the can and the two leads. If the seal is bad then the cap will have a short life.
                              Test the seal on those bad caps. Apply too much voltage to burn the cap up. If the seal is good it will bloat and explode like they do for c_hegge the capacitor seal clubber. Test many burning them out slower and slower. They should all bloat if the seal is good.
                              If c_hegge used voltage instead of fire he would be performing valuable capacitor seal research and having fun at the same time.
                              sig files are for morons
                              • b700029
                                Banned
                                • Sep 2010
                                • 640
                                Would be interesting to see a dissection of a few of them to see how they failed. Dried-up as severach suggests, or something else?
                                • PeteS in CA
                                  • Aug 2005
                                  • 3576
                                  • USA, Unsure of Planet
                                  Just some stupid (but maybe on-point) questions. Are these mobos in machines that are active 24x7x52? And what is the rated life for these caps, at full ripple current, 105C? The reason I ask is that these caps are 4-6 years old (1 year = ~10000 hours). If they are a 2000-hour series, it may be that you are seeing end-of-life failures. IIRC, HMs are a 2000-hour series, IIRC, but those mobos may be replaced before 4-6 years pass.
                                  PeteS in CA
                                  • PeteS in CA
                                    • Aug 2005
                                    • 3576
                                    As for testing for dry-out, remove the shrink wrap and use a pair of small diagonal cutters to pry up the lip of the can that retains the bung. The peel the can down a little and the guts should pull out easily. Done it scores of times, though with larger caps (18mm, 16mm and 12.5mm cans).
                                    PeteS in CA
                                    • Topcat
                                      The Boss Stooge
                                      • Oct 2003
                                      • 16955
                                      I saved a handfull of them. Autopsy to follow.
                                      Team : 49813
                                      Join in!!
                                      Team Stats
                                      • PeteS in CA
                                        • Aug 2005
                                        • 3576
                                        Taking caps apart at my former job was always fun, except for some cheapies that smelled like rotten fish. Those thing stunk even before opening the box in which they were shipped!
                                        PeteS in CA
                                        • bjs59
                                          Infamous Rubycon MFZ... Current recommended replacements???
                                          by bjs59
                                          What we have here today is an Intel DG33FB motherboard, circa 2007... I need to replace some of the caps on this board... From what I have found, one of these caps was sort of well known here back in the day as they were used in XBoxes and XBox 360s as well....They are the Rubycon MFZ series, in particular the 6.3 v 3300uf 10mm X 20mm... I have found a seller on Amazon, The Capacitor Store, that has them listed but I have a hard time believing these are genuine pieces... The original recommendation was to replace any bad ones with Nichicon HZ series since the Rubycon MFZ's were a custom product,...
                                          12-10-2020, 10:47 AM
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • DXseekerMO
                                          Failed UCC and Rubycon replacement on a Dell XPS410, equivalent?
                                          by DXseekerMO
                                          Hello, I'm working on an old Dell XPS410 with burst capacitors. I'm trying to source either an equivalent replacement, or a replacement that will work. It's been suggested to me to use Poly caps as a replacement, but I have no idea what to order or what will work.
                                          If anyone has a link to where I can buy what I need that would be even better.
                                          These are the caps that have burst:
                                          Board location: C8BV, C26BV, C43BV
                                          Brand: United Chemi Con
                                          Series: KZG
                                          Size: 10mm dia X 25mm height
                                          Impedance: (ohms max/20c, 100kHz) .012
                                          Ripple: 2800...
                                          02-04-2022, 04:48 PM
                                        • blub0815
                                          Replacement of Chemi-Con KZG with Rubycon ZLJ
                                          by blub0815
                                          is the replacement possible? There is a difference of factor 2 between the ESR/Impedance.
                                          The caps are located on a motherboard.
                                          KZG:
                                          https://www.digikey.at/htmldatasheet...zg-series.html
                                          ZLJ:
                                          https://cdn.badcaps-static.com/pdfs/...a472c7fe84.pdf
                                          BR
                                          05-07-2023, 11:28 AM
                                        • Y. Signal
                                          Replacing Rubycon CE W with Rubycon YXF
                                          by Y. Signal
                                          Hello. I'm looking for the best modern long-life replacement for Rubycon CE W capacitors found in some old consoles and computers (Sega Genesis/Mega Drive and ZX Spectrum). In these machines I've also found (and replaced) Nichicon VX(M), TK C-8Z1 and FDS K002.
                                          I've used Panasonic FR (and Rubycon YXJ for the 1 uF 50V) but the Sega Mega Drive became unstable after one hour of use, so I switched to Panasonic FC / Rubycon ML and it works apparently fine. I need more capacitors, so I'm planning to order Rubycon YXF instead of ML this time, is it a good idea?
                                          ML does not especify...
                                          05-06-2018, 11:32 PM
