ABIT VL6 problems....
  • sphing
    • Apr 2006
    • 3
    I recently started having strange behavoir out of my system. It started when the system would go into standby and I would try to wake it. All I would get was a "click,click,click,click,etc... reboot"
    Then it started happening when I would let the system sit idle for a while but try to access it before it actually went into standby. The same thing would happen as soon as I touched the mouse or the keyboard. "click,click.....reboot"
    Then it started happening anytime I let the system sit idle for about a minute. If I was typing and stopped to think... it would go into its click-reboot.
    Then it started happening even while I was actively using the system.
    Most recently... I get no power on startup to the CPU or the CPU fan. The APG port is getting power because the video card fan will run. Other devices connected to the power supply start up. you can hear the HDD turn on.
    I started looking over the VL6 and several capacitors seem to be either bulging or are outright leaking something. I have seen on other posts in this forum that this could be exactly what is causing my problem.
    Amazingly some of the photos of bad capacitors for the VL6 shown in this forum are the exact same ones that appear bad on mine.
    I have attached a photo of one bad capacitor near the power connector. what does this one do in particular?
    Do my reboots sound like bad capacitors? Should I consider replacing them or just buy a new board? I would like to fix this board if its possible.
    what do you guys think?
    thanks in advance, John
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: ABIT VL6 problems....
    Those caps are defintely toast. The brown crap all over the board is dried electrolyte. It'll come off fairly easy. Replace all caps 1000uF and up, and I'd be willing to bet the board works like new. I've recapped quite a few VL6's, and never had one end up a dud.
    Good Luck.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      the electrolyte will clean off nice with cotton buds/q-tips and alcohol. you will want to do that after removing caps around the electrolyte because some will be underneath the caps.
      post some pics when you succeed recapping the board.
      • sphing
        • Apr 2006
        • 3
        Would you say my reboot symptoms fit the problem of bad capacitors?
        Is what I'm experiencing exactly what you would expect?
        next big question.... Can someone provide me with a BOM and Schematic for the VL6? What are the capacitor designators I should change out and could you recommened the best replacement parts to use? (...by value and mfg ...I'm not a EE but a friend of mine is.) Also, where do I purchase these components?
        thanks,
        John
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Your reboot symptoms are very commonly seen with badcaps, but you should check your powersupply also, failed caps in it could have hasted the failings of the crapcaps on your mainboard...
          You should exchange all caps of the same manufacturer to begin with
          And if there is more than one manufacturer replace the others also if it is not made by one of the good caps manufacturers...
          You can leave all caps below 1000uF unless they actually are bulging, most oftenly they will be ok because they see much less stress than the larger rated caps do...
          "Where can I buy replacement capacitors": https://www.badcaps.net/forum/showthread.php?t=613
          "The GOOD Capacitors Thread": https://www.badcaps.net/forum/showthread.php?t=414
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            • chaos-theory
              Nitro rx580 very weird problem, VCORE and EN
              by chaos-theory
              Hello!
              I have this very weird problem, I got this rx580 nitro saphire and the fans don't even spin but the saphire logo is lit.
              All voltage rails are present except for VCORE at the coils, then I started checking NCP81022 and it has voltage but vdd pwrgd is missing, enable EN is missing it shows 2.5ohm, everything seems fine, i tried checking the back of the card, to see where the enable pin goes, i dont have a schematic so i started touching randomly until i measured a resistor on the back and the fans started spinning, now I was amazed like what is wrong here? So I thought it's a...
              08-17-2024, 04:56 PM
            • jean luc ferre
              laptop hp g72 b52sf screen problems
              by jean luc ferre
              on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
              the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
              i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
              i don't understand the reasons of the white stripe at the bottom of the screen below the task...
              06-07-2025, 03:27 PM
            • Rayblaster
              HP RP7 RP7800 from 2012/2013 worst fault - has "character"
              by Rayblaster
              Hello friends, I've got a nice toy to play with - it is an HP RP7800 All-in-one POS system. I got it for free and it has one problem - it turns on very rarely, and just for a few seconds. After that it dies and doesn't come on if I don't leave it unplugged for at least 2 hours. I've repaired motherboards before, this is not my first one, but problem with these types of faults is that everything you check on the board will usually be fine. This is the case for me here.
              I dissassembled it completely, and got my hands on the motherboard. Model No. is PIQ67H/Higgins 11047-I 48.3GD02.011....
              12-30-2024, 06:28 PM
            • Hondaman
              USB problems?
              by Hondaman
              Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
              (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
              I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
              08-12-2024, 03:26 PM
            • clabr
              Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
              by clabr
              Need help to solve some problems with this laptop.
              After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
              After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
              Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
              Before this had happened I observed some other problems:
              When I tried replacing original mecanical HDD with a SSD HDD could not get them...
              12-02-2021, 08:09 AM
