Noob with question on cap.
  • muskin
    • Nov 2011
    • 64
    Hi I was wondering if someone could give me some information on the cap and how to read it and where to find good replacements for it. This is from an LG logic board, sorry for posting in both areas. I thought I would get more responses here in the right section.
  • ant3202
    • Jun 2006
    • 275
    • Singapore
    Re: Noob with question on cap.
    look like samwha capacitor ...
    http://www.samwha.co.kr/SW_catalogue...log.asp?Dir=19
    just need someone to confirm
    • mariushm
      • May 2011
      • 3799
      ftp://helpedia.com/pub/temp/datashee...et%203/Samwha/
      More to the point:
      I don't see any series there that would have the codes arranged like in your picture.
      Yeah... not helping much, I know.
      • slybunda
        Gemcon capacitor replacements?
        by slybunda
        taken from my thread about car alarm siren here: https://www.badcaps.net/forum/troubl...rm-siren-issue
        there are 2 caps which im looking to get replacements for.
        Branded as Gemcon
        single 100uf 16v 6.5mm x 11.5mm
        single 100uf 50v 8mm x 11.5mm
        lead spacing is around 3mm
        there is space for 16mm tall caps
        rs components is good place for me to go since its close by, what replacements do you suggest and do these need to be low esr?
        the caps have...
        02-05-2024, 03:36 PM
      • Guest
        A noob needs help for Apple Macbook Air M1 2020 A2337 - logic board short circuit
        by Guest
        Hello all!
        Recently I've got a broken Macbook Air M1 2020 A2337 of eBay with a broken screen and not turning on issue.
        After some tinkering I've found C5201 capacitor to be blown. This is where I hit a wall since I am a total noob in this area and have no idea what else to look for. C5201 is on one line with 3 more capacitors which visually seem ok, but beep on continuity mode and also both sides of all capacitors beep when tested with ground from the board. This to me sounds like a short, but I am not able to find what component is before the capacitors to test it....
        09-26-2024, 03:31 AM
      • burom
        Xbox 360 Xenon Modern Capacitor Replacements
        by burom
        I found my old Xbox 360 in storage and opened it up to see if there was anything that broke since it was built in 2006 (launch era Xenon revision, never red ringed, never been serviced) and didn't want to find out by releasing magic smoke. Upon moving the dust bunnies out of the way I was greeted by a bunch of capacitors with crud coming out of the top; it doesn't seem to have leaked onto the board so at least I have that going for me.
        I'm posting here because I want to try to source replacement caps myself from Mouser or Digikey instead of braving eBay or waiting for places to have...
        06-07-2024, 05:10 PM
      • прямо
        Help me decide which MOSFETs are suitable replacements
        by прямо
        Friends,
        I need help. I'm having a bit of difficulty in deciding what would be the compatible replacement for these MagnaChip N-Channel Trench MOSFETs on a VRM circuit because they seem to have a much faster switching times compared to most N-Channel Trench MOSFETs out there that have the same (more or less) current rating and Rds(on)
        MDD1502 (high side), 48.5A 7.8mOhm
        MDD1501 (low side, 2 in parallel), 67A 5.6mOhm
        VGS is 10V High side drain is 12V. Low side drain is from PWM controller (Richtek RT8120A) phase output 1V.
        Here are the ones...
        02-01-2024, 09:06 PM
      • withalligators
        Looking for best replacements for Capxons, but can't find data sheets
        by withalligators
        Recapping the power supply board for a Samsung 305T monitor, everything is Capxon except 2 Rubycons. I can't find data sheets matching these online, so don't know what ripple numbers, impedence, etc, to look for. There are a few different looking GL series data sheet PDFs, but the listing that matches the capacitance and voltage is a much bigger case size. I've narrowed down selections with lead spacing and case diameter, and what's in stock at Digi-key
        1 x Capxon 1000uf35v GL C720(is this a part number or batch number, can't find it anywhere) 105c
        1 x Capxon 1000uf35v...
        03-25-2022, 02:30 PM
