Nichicon HD and HM?
    Nichicon HD and HM?
    I just found an old Asus motherboard in my pile. The CPU VRM caps are all hideously bulged. Four are Nichicon HM 3300u 6.3V, date code H0133. (33rd week of 2001?) The others are Nichicon HD 1500u 6.3V, date code H0118 (18th week of 2001?) I was under the impression that only HM/HN was affected by the 2001-2004 defect, so are the HD bulging for other reasons? Some of the HM have a yellow caked-up dust covering the vent...
    Also, one of the coils on the board looks like it has burnt out. The core has turned from green to white and the wire is blackened.
    This motherboard will probably be thrown out as it is so old (looks to be AMD Athlon?) but I'm just curious about what happened.
    I'm trying to figure out the design of this motherboard. I am wondering why there are no 16V caps. Maybe the CPU VRM is generated off the 5V or 3.3V lines?
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Nichicon HD and HM?
    Yes
    There's the other reasons.
    This board either had a short, power surge, or a bad PSU.
    Probably bad PSU to bloat caps like that.
    May also have been recapped with the wrong voltage caps.
    This was common in before about DDR RAM vintage. [Like P3 era].
    That's why old PSU's had more amps on +5v and not much on +12v.
    Mann-Made Global Warming.
    - Dr Seuss
    • DrewPhillips
      Capacitor Diarrhea - Nichicon PL Series
      by DrewPhillips
      Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
      The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
      03-02-2025, 10:18 PM
    • nick3092
      Mid/late 80's Nichicon Yellow Caps
      by nick3092
      I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
      08-28-2022, 03:56 PM
    • chth96
      Is there datasheet for nichicon LXJ series?
      by chth96
      I want to calculate capacitor ESR referring to below guide.
      https://forum.digikey.com/t/calculat...-from-tan/2633
      I must find out dissipation factor(Tan(δ)) for nichicon lxj series(6.3v 1500uf,25v 1000uf ,10v 2200uf)
      I finally found out datasheet which has all series of nichicon capacitor.But unfortunately, It removed old nichicon capacitor.
      Is there anyone who still has old nichicon datasheet which has information of LXJ series?
      11-20-2022, 08:11 AM
    • chth96
      Is there any datasheet for nichicon RT(M) series?
      by chth96
      A few days ago,I destroyed one of my japanese retro game console by pluging it to 220v outlet.
      https://www.badcaps.net/forum/troubl...e-been-blew-up
      and I finally fixed​ this retro game console by soldering varistor and glass fuse.
      But I noticed that When I measure voltage of PSU's 5pin connector, it is 8.80-9.07v, 5.13v,3.40-3.48v,GND,GND instead of its rated voltage of 9v 5v 3v GND GND.
      I have spare console...
      11-28-2023, 03:36 AM
    • megcox
      ASUS PD551LA REV2.0 not booting after one week power off
      by megcox
      Hi everybody
      My ASUS PD551LA (REV 2.0), after a week powered off with power adapter disconnected, is not booting anymore.
      If I plug the adapter, the battery is charging, the power led lights but after pressing the power button there is no sign of life.
      I've found the Boardview file of the motherboard and the schematic of PU551JA (that looks 99% compatible).
      I've disconnected the battery and all devices except screen (I removed also the RTC battery, hope it's not a problem at this stage...) and checked all signals and power rails involved in the power on s...
      10-12-2024, 03:26 AM
