CEC Capacitors
  • rhomanski
    nowhere man
    • 5157
    • U S of A
    #41
    Re: CEC Capacitors
    Yes you amplify the voltage and the currant. More voltage means more currant.
    Keep in mind now, I'm generalizing from what I was taught more than 40 years ago, I might make a mistake and mispeak here and there. I haven't used any of this over the years. I've worked systems not board level stuff.
    When I was in the military going to school in Memphis, they told me I picked it up quicker than anybody they had ever seen. I told them I had already had it in High School, I took Electronics class for three years. The first year was tube theory, the second year they transitioned the whole class to transistors and dropped tubes.
    I hope Mockingbird isn't upset that we've hijacked his thread like this.
    sigpicThe Sky Is Falling
    • Spork Schivago
      • Mar 2012
      • 4734
      • United States of America
      #42
      Re: CEC Capacitors
      Rhomanski,
      Oh man, I totally forgot this wasn't my thread! I should have created my own, asking for help on how they work. I wonder if a moderator could move my posts about the transistors to a separate thread? I wasn't even thinking about that! I feel horrible now!
      Sorry Mockingbird!!!!!!
      -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
      • dragon3x
        by dragon3x
        power on.
        Here are some examples :
        switching supply area).
        than 6.3 V.)
        03-21-2025, 02:46 PM
      • slybunda
        AA and AAA battery charger capacitors?
        by slybunda
        hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
        it has inside:
        2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
        2 x 470uf 16v LZ105c branded as G.Luxon
        not heard of these brands are they any good?
        iv attached photos of the charger and the board inside for an idea on the type of...
        12-24-2023, 04:41 AM
        After all of...
        07-13-2024, 08:14 PM
      • Cama
        Solar Inverter - SMH-II - 2 missing capacitors
        by Cama
        I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
        My model is : EASUN SMH-II 7 KW
        Mother Board : P/N 18947-002401250250
        Maybe the EASUN SMH-II 4.2 KW have the same capacitors
        Thank you...
        09-12-2025, 02:50 AM
      • Ady2017
        Are there any datasheets available for Elna RJG capacitors?
        by Ady2017
        I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
        05-25-2025, 02:19 PM
