My first replaced capacitor
  • Dodo
    • Dec 2003
    just want to share my success at my first capacitor replacement. it was an old pentium2 board (gigabyte ga6bxc) . i removed the capacitor and then attatched 2 wires on the underside of the board where the capacitor was sodlered on. i taped those down, taped the other ends to a capacitor (same ratings as old one) and taped the capacitor to the cpu. its rather ghetto, if you know what i mean, but it works.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Ghetto huh.... :roll:
    Well... back in the days of yore, I'd rig up a car stereo on occasion with methods such as tape and bare twisted wires...
    Wel all have to start somewhere, now ya might get a little more daring and get the 'ol soldering iron out...
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • MORETTIGIAN
      by MORETTIGIAN
      Title:
      Description:
      Procedure performed:
      - Removed backplate
      - Reapplied thermal compound
      - Reassembled card
      09-18-2025, 12:14 PM
    • im_trying
      Dell Latitude 5310 2 in 1 Laptop does not power on, shorted capacitor replaced but not solved
      by im_trying
      Laptop does not power on but has a fix white light on power button, when connected to power.
      I found, while trying to diagnose, a hot spot in the motherboard and found it to be a shorted capacitor (see photo below) on the 2.5v (2D5V_S3 on schematics). After replacing it with one from a donor board, still, the board does not turn on...
      The usb-c meter reads upon connection 20.1v and 0.00a, with some occasional flashes to 0.03amps. After 10/15 seconds circa, it goes to 5.2v and draws an almost constant 0.07amps. (same behaviour as before)
      To my fingers, nothing seems...
      05-08-2025, 12:01 PM
    • Prolog
      by Prolog
      12-01-2024, 08:27 PM
    • chth96
      by chth96
      06-02-2024, 07:31 PM
    • chth96
      Is it no harm to replace with capacitor without ripple current rating?
      by chth96
      When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
      Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
      But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
      Rubycon YK DataSheet (b...
      04-19-2024, 05:19 AM
