LCD colour distorted after capacitor change
  • yodude010
    • Feb 2009
    • 6
    Hello guys!!
    I need some help.
    I've HP 1702 17" LCD Screen. Few days back it started flickering on startup. So I decided to change the capacitors. After opening the lcd panel, i found that one capacitor(1000uf 16v) had become fat and the other one(470uf 16v) had popped. I decided to put 1000uf 25 and 470uf 25v. After capacitor change, my lcd became reddish. I've attached some photos.
    I thought it might be due to voltage increment, therefore I decided to put 1000uf 16v and 470uf 16v but the result is the same.
    The capacitors were located near power supply(on yellowish type board).
    Could you please give an idea on what's wrong? the flickering thing has gone, but lcd colours are like you don't have vga drivers installed.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: LCD colour distorted after capacitor change
    reseat the lvds cable.goes to the panel.
    • yodude010
      • Feb 2009
      • 6
      I've double checked. All the connecters are fitted properly. I tried to change the lcd ribbon direction by fitting it upside down, but it doesn't work. I'm unable to locate the problem. All others caps are looking fine to me.
      • mockingbird
        • Dec 2008
        • 5484
        No, voltage increase is a GOOD thing, because it's only a rating and will extend the life of the recap. Always use more voltage where you can fit it in.
        Things you need to do:
        1) Change ALL the capacitors (Except for the main primary)
        2) List the series of the capacitors. You can't just replace capacitors with anything of the same value. It has to be the same series.
        • yodude010
          • Feb 2009
          • 6
          ^ Thanks dear. I'v to travel out of city for a few days. I will try to do it after coming back. I will also post the lcd board images so that you can suggest me which ones to change.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            Then clean them with a cotton swab wet in isopropyl alcohol and try again. That reddish tint is a typical symptom of a improperly seated/dirty cable.
            A working TV? How boring!
            • Badcappy
              Banned
              • Aug 2007
              • 52
              Is it the panel that's turned red or the backlight? If it's the latter, you might be due for a CCFL replacement.
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                It's the panel, i've seen that issue before when i put my PDA back together with sweaty hands. Once i cleaned the cable and reseated it, the reddish tint went away.
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  maybe you damaged the cable when you pulled it apart the first time?
                  had 2 visio lcd tv's with that issue.one red one green.bad crimps in the panel end of the lvds.easy fix.
                  • yodude010
                    • Feb 2009
                    • 6
                    Hello guys, sorry i was away.
                    I checked the cables. All cables are fine. I'm attaching some photos of the board.
                    @badcappy
                    When the pc is disconnected, while showing "monitor is going to turn off" the back screen is also reddish. Does that mean the backlight is dead?
                    • yodude010
                      • Feb 2009
                      • 6
                      any help?
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4959
                        • New Zealand
                        I'm not 100% sure what you mean by this, but cables go in the way they are supposed to go in for a reason.
                        Putting cables in backwards is a good way to cause even more problems.
                        I can't help you much either, but I do have a monitor with faulty CCFLs and the whole screen is very red, it makes a bad hissing noise and then shuts down.
                        If that doesn't happen to you then your CCFLs are probably fine.
                        Oh and please don't post your photos in-line in your posts (unless you resize them).
                        Just attaching them is OK.
                        Not everyone has a 50" widescreen monitor...
                        -David VanHorn
                        • Pyr0Beast
                          • Feb 2009
                          • 406
                          Let LCD warm up and see if reddish tint dissapears. Old cold cathode tubes often turn a bit pink but work well anyway.
                          • tonyny
                            • Dec 2010
                            hello, I'm new but I seem in another site that your problem is the backlight I don't know if I can post a site name were you can get that information and buy the parts
                            • l3igl3ang
                              • Dec 2012
                              • usa
                              Hi guys my 42" sanyo lcd is doing the same thing and i checked all the cables and cleaned them. How did u guys ever fix the problem?
                              • swgaspidey
                                • Jul 2012
                                • 5
                                bad ccfl backlights can also cause a color change
                                • Prolog
                                  by Prolog
                                  12-01-2024, 08:27 PM
                                • chth96
                                  by chth96
                                  12-22-2023, 04:34 AM
                                • reessi
                                  ACER BM320 Monitor - Horizonal Flickering Lines After a While
                                  by reessi
                                  The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
                                  They are black on the right and gradually fade to nothing on the far left.
                                  They start either after 5 mins or up to 2 hours after so annoying for testing.
                                  They flicker continuously very fast! With a slight pause milli-second every second.
                                  Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
                                  I tested each half by removing the first the left flex from...
                                  06-03-2025, 09:58 AM
                                • chth96
                                  by chth96
                                  06-02-2024, 07:31 PM
                                • chth96
                                  Is it no harm to replace with capacitor without ripple current rating?
                                  by chth96
                                  When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                                  Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                                  But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                                  Rubycon YK DataSheet (b...
                                  04-19-2024, 05:19 AM
