Replacing Mode Indicator LEDs
  • VitalComputing
    • Dec 2021
    • 29
    • Ireland
    I have what should be a simple job but is causing me issues. There are three LEDs (yellow, green and red) on the indicator panel of a solar PWM controller and these have broken off. I need to replace them but I am unsure of the voltage drop across these. I don't want to replace with random LEDs in case they blow.
    I took one of the LEDs out of circuit, put 19V across it with a 500 ohm resistor in series and there is a drop of about 13V across the LED, and this seems to increase as I increase the input voltage.
    I thought I could just put a resistor in series with the LED and the LED would drop it's rated voltage. Should I just replace with a 12V LED?
    Edit: I dont have any schematic
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Replacing Mode Indicator LEDs
    photo of the circuits involved would be helpful.
    probably, a regular T1 or T1¾ LED probably would fry with 19V and a 500Ω dropping resistor.
    Why did on whim did you test with a 500Ω resistor in case it was a regular ~1.7V LED? Not safe! Might have been able to solder jumpers!
    • VitalComputing
      • Dec 2021
      • 29
      • Ireland
      Originally posted by eccerr0r
      photo of the circuits involved would be helpful. probably, a regular T1 or T1¾ LED probably would fry with 19V and a 500Ω dropping resistor.
      I set it up originally with a 9V battery and 500 Ohm resistor, and tested with a spare LED and it worked fine - 2.6V drop across LED, remainder dropped across resistor.
      When I swopped in the indicator LED from the board, it would not light up at all, so I had to increase the voltage. Only after I put about 14V across it, did the indicator LED from the board start to light up.
      I'll see if I can remove the giant heatsink to view the other side of the board.
        • 31055
        500ohm is better suited to maybe 5v
        for 19v use atleast a 2k2
        https://ohmslawcalculator.com/led-resistor-calculator
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          Well should always start with 2k2 and go down, those built-in resistor LEDs can be tricky.
          However I think most of the built-in resistor LEDs I've run across actually mark on the body that they are indeed 12V or whatever voltage they were designed for. However assume standard voltages if not marked.
          • VitalComputing
            • Dec 2021
            • 29
            • Ireland
            Okay I carried out a little experiment with the one LED that is still fully intact. I measured the 500 ohm resistor and it is actually 462 ohm to be exact. I started at 10V and worked my way up to 22V.
            Any opinions would be welcome.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              tbh perhaps a CC PSU at 5mA-10mA to pass through the LED and measure the voltage across it will be the easiest way to figure out the voltage.
              strange though, looks like 14V is best, alas these things are annoying if one has to stock different voltage LEDs. Easier to stock regular ones and a bunch of resistors since likely you'll need resistors for other things anyway.
                • 31055
                i would use regular leds.
                if these leds have a linear regulator in them your gonna get them hot!
                i dont know if that is whats in them - but it probably is.
                • VitalComputing
                  • Dec 2021
                  • 29
                  • Ireland
                  Okay I thought there must be something else other than just an LED going on, so I hooked up directly to the voltage this time.
                  I'm gonna just buy a few different 14V through hole LEDs with built in resistor, see which performs closest to this and use it. I will just use the one colour and put labels beside each LED.
                    • Jul 2011
                    • 6040
                    You need to know what the current requirements are for the type of LED lights you are using and try to stay a little bit lower than that for longevity of the LED lights you are using
                    They range from 2 milliamperes to 20 milliamperes
                    When I have used the 10 milliamperes versions I try keep them to the brightest that is need for the application but below the 10 milliamperes most of the time around 5 milliamperes
                    • edugimeno
                      About replacing individual LEDS on BL strips
                      by edugimeno
                      Hi There!
                      Having fixed 5-6 TV sets by replacing full LED strips, and having watched other people fix that by replacing just one LED in the strip, my question now is what should I consider before doing so.
                      At this time I have some old strips removed from TV's with all but one LED working. Are there different voltage/current LED on different strips? Are 99% of them just the same and interchangeable?
                      How do you find which specific model is needed for each strip? When I check if a LED is OK by attaching the multimeter leads to the individual led pads on the strips I...
                      11-07-2022, 11:12 AM
                    • Pipolups
                      Corsair K70 LUX RGB dying LEDs
                      by Pipolups
                      Hi there !
                      I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                      Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                      10-08-2024, 11:58 AM
                    • code share
                      Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
                      by code share
                      I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
                      Here's what I've tried so far:
                      • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
                      • Booted successfully on AC power only with the battery disconnected
                      • Visual inspection of the battery — no swelling, burn marks, or connector damage
                      • Battery
                      04-21-2025, 12:50 PM
                    • THE GTC
                      Insignia NS-37D20SNA14 intermittent LEDs
                      by THE GTC
                      So I use this TV daily as a second monitor for my PC or my Playstation - at one point a few months back I tried to fix the problem - but in the process, I figured out something that works so I haven't posted this for awhile. It is an annoying trick to have to do though, so I decided to post about it to see if anyone could spot what's wrong. It baffles me because it works on it's own half the time.
                      When I first got this TV, I was told it wouldn't turn on, and of course I did the flashlight test, and the image was there. Also, the red LED on the front indicated that it had power (it...
                      11-03-2020, 02:40 AM
                    • fharris1977
                      Replacing LEDs on LED strip
                      by fharris1977
                      Does anyone know of a ptc heater that does not burn the LED strip when replacing single LEDs? I'm trying to refurb LED strips and I want my strips to stay as white as possible. On the youtube videos their ptc heaters don't burn the strip at all hardly. Any help or methods would be greatly appreciated.
                      06-23-2020, 07:44 AM
