Polymer Capacitor FAQ
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    I will edit in the answers and stuff later
    How do they look?
    Why are they useful?
    When can you subsitute them for electrolytics?
    When can't you?
    Are they better at dealing with hot environments?
    Anything to watch out for when installing?
    What's the point of polymer caps?
  • uligli
    • Aug 2006
    • 139
    Re: Polymer Capacitor FAQ
    Is it a good idea to use an old poly cap? (desoldering from some board) Just in case that i can't find a replacement.
    • c_hegge
      • Sep 2009
      • 5219
      1. How they look: They don't have vent stamps, but some may have plastic sleeves
      2. Why they are usefull: Lower ESR, Higher tolerances to ripple and heat, and thus they generally last longer
      3. When you can substitute them for lytics: On the VRM in and out of motherboards and Graphics cards if you reduce the capacitance. They can be used on other parts of a motherboards, but you don't reduce the capacitance. This can be a problem as 1000uF polys are 10mm but 1000uF lytics are 8mm dia.
      4. When you cant substitute them for lytics: In PSUs
      5. Are they better in hot environments: Yes
      6. Anything to watch out for when installing: Yes. Some of them have thicker legs than normal and sometimes they can be physically bigger than lytics
      7. The point of them: To provide better reliability and heat tolerance than electrolytics
      8. Is it a good idea to use used polys? It can be done and I have done it before, but it is always better to use new ones.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        fujitsu have vent stamps.
        and search polymods for the general rules.
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          Ok. Any other questiins/answers to add before i do the final edit (ill figure out how later)
          • c_hegge
            • Sep 2009
            • 5219
            Not anymore. I havent seen one of those yellow fujitsu hybrid caps for ages.
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              In the last year or two?, Fujitsu sold their Polymer interests to Nichicon so Fujitsu Polymer aren't made anymore.
              Nichicon makes Polymer in the 'typical polymer can' with no vent and no sleeve.
              From what I can tell there are still a lot of the old Black/Yellows left in the supply channels but you aren't likely to see them in new manufactured items from a main stream company.
              Mann-Made Global Warming.
              - Dr Seuss
              • chth96
                Should I replace polymer capacitor?
                by chth96
                a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                Is this ESR value of polymer capacitor correct?...
                11-18-2022, 04:22 AM
              • eccerr0r
                solid polymer electrolytic capacitor go boom?
                by eccerr0r
                Anyone had a solid polymer capacitor fail for whatever reason?
                How do they fail? Do they explode, go open, short out, ?
                How about for different reasons: forcing excessive ripple current, overheating, voltage too high, reverse voltage?
                Just wondering about the causes for a potential shorted solid polymer capacitor... trying to debug a board that has a ~4Ω "short" on a track... it may or may not be a capacitor but was wondering what if it were...
                07-25-2022, 07:12 AM
              • Prolog
                by Prolog
                12-01-2024, 08:27 PM
              • chth96
                by chth96
                12-22-2023, 04:34 AM
              • chth96
                by chth96
                06-02-2024, 07:31 PM
