Electrolytic capcitor electrolyte corroding the aluminium can
  • japlytic
    • Oct 2005
    • 2086
    I've seen electrolytic capacitors which had a chemical which gradually ate through their aluminium cans under the plastic label, eventually causing it to become rough.
    Have you ever seen something like this?
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Electrolytic capcitor electrolyte corroding the aluminium can
    Some caps have vents in the side of the can under the sleeve.
    Probably most common in 5 or 6 mm caps with no top vent.
    Not something I ever actually look for so I dunno how common it is but I've seen it.
    Mann-Made Global Warming.
    - Dr Seuss
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      Huh?
        • 31213
        i'v seen caps with rough sleeves - it's caused by the cap getting seriously fucking hot because it cant handle the ripple!
        • Quasar
          • Sep 2010
          • 132
          Wasn't the bad electrolyte era the cause of that? Are these new(er) caps or from back in 2000-2005?
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Got new for yah.
            The bad aluminum era has been around for decades and still is.
            It does the SAME thing as bad electrolyte you are referring to, it's just a little slower.
            - Dr Seuss
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Originally posted by shovenose
              Huh?
              Which word did you need help with?
              - Dr Seuss
              • Quasar
                • Sep 2010
                • 132
                Originally posted by PCBONEZ
                Got new for yah.
                Oh, ok. I thought the question was about electrolyte eating through, so it doesn't matter. Bad alum or bad elec.
                Could it be something in the label reacting with the alum.?
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  I didn't mean it that way.
                  My point was there is more than one plague.
                  The 'stolen electrolyte plague' [2001-2005?] and the 'low purity Aluminum plague' [anything from Taiwan or China since forever] 'plagues' are indistinguishable without actual chem lab tests.
                  Additionally Taiwan or China manufacturers no doubt have other marginal electrolytes that don't have anything to do with the famous stolen formula story.
                  They don't need to buy bad electrolyte, they can make their own bad electrolyte.
                  There is also that all the 'stolen electrolyte plague' caps also suffered from the 'low purity Aluminum plague' meaning they got a double whammy.
                  Hard to say which of those two problems would be the root cause of corroding Aluminum.
                  CALCE [Center for Advanced Life Cycle Engineering] is a Failure Analysis Lab at the University of Maryland.
                  They went looking for the bad electrolyte issue and tripped over the impure Aluminum issue.
                  - Dr Seuss
                  • japlytic
                    • Oct 2005
                    • 2086
                    The capacitors I was mentioning were around the late 80s-early 90s.
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      I haven't seen it but I hardly ever see anything that old.
                      Some particular brand or something you see once in a while generally?
                      I can see a couple few different ways that might happen.
                      Too thin or bad aluminum in the can.
                      Electrolyte that is or becomes acidic.
                      Some acidic residue between the can and sleeve.
                      - Dr Seuss
                      • AstutePauciloquent
                        Requesting Help Identifying tiny Aluminium electrolytic
                        by AstutePauciloquent
                        Hi wonderful people. I have a MS-6315 P3 motherboard with very tiny Aluminium electrolytic capacitors. I've made an attempt to identify them from what ive learned so far they might be
                        Aluminium Electrolytic
                        G = Series
                        10 uF
                        16 = Volt
                        104 Date code 2001 April? (not really important, but interesting)
                        Please help to confirm or correct if i am wrong. Thank you
                        10-20-2023, 06:29 AM
                      • Adenitz
                        Replace electrolytic cap with bipolar one
                        by Adenitz
                        can I use this cap:
                        https://www.tme.eu/en/details/ues1h4...tors/nichicon/
                        Capacitor: electrolytic; bipolar; THT; 47uF; 50V
                        to replace this capacitor: Electrolytic Radial E 47uF/50V 6.3x11 RM2.5 105°C Jamicon
                        What exactly I can expect to install bipolar electrolytic cap instead a regular one?
                        Thanks.
                        02-02-2022, 07:44 AM
                      • ten-d
                        Nippon Chemi-con 100uf 100v BP electrolytic cap
                        by ten-d
                        Hi all!
                        I just bought a pair of ADS L810 speakers, which I've heard are some of the best speakers from that time (late 70's) into the early 80's. I was super excited to test them out and hooked them up and I was very underwhelmed by the treble. The treble was awfully muffled. I've been doing some restoration work on 70's stereos and a couple of speakers here and there so I am really just a beginner. I do know that capacitors in speaker crossovers filter out the lows to allow only the highs up to the tweeters and mids. Inductors filter out the highs to allow the lower frequencies to...
                        01-30-2024, 05:18 PM
                      • Perry Babin
                        How do organic polymer caps compare to liquid electrolytic for reliability
                        by Perry Babin
                        I have a situation where a power supply is commonly abused and the 12v supply caps take a beating. They don't commonly fail but they run hot. I was thinking about going from a liquid electrolytic (Panasonic FC and Nichicon HE) to an organic polymer. The values have been 330uF. I typically use a higher-than-needed voltage to get a lower ESR. The supply is operated from 12v.
                        If not organic polymer, what would be the caps that could take the most abuse?
                        08-18-2025, 04:04 PM
                      • gamer87
                        Question electrolytic capacitor from 1990`s
                        by gamer87
                        I have electronic devices from 1990 and I know that these devices that have not been used for a long time cause faults and depolarization in the electrolytic capacitors, is it necessary to use these devices in the interval of 1x a month to preserve the electrolytic capacitors from failing due to disuse? are used electrolytic capacitors manufactured since 1990 and assembled in electronic circuit
                        09-28-2021, 01:06 PM
