Replacement of Chemi-Con KZG with Rubycon ZLJ
  • blub0815
    • Jan 2021
    • 7
    is the replacement possible? There is a difference of factor 2 between the ESR/Impedance.
    The caps are located on a motherboard.
    KZG:
    https://www.digikey.at/htmldatasheet...zg-series.html
    ZLJ:
    https://cdn.badcaps-static.com/pdfs/...a472c7fe84.pdf
    BR
  • RukyCon
    A Fake Rubycon
    • Jan 2017
    • 816
    Re: Replacement of Chemi-Con KZG with Rubycon ZLJ
    In terms of ripple current, they're pretty close, almost exact, though the impedance is almost double with the Rubycons. They might still be fine, as the impedance is already pretty low, but I would wait for someone more qualified than me to chime in.
    Now since the caps are being used on a motherboard, it might be possible/easier to go with 'solid polymer' electrolytic capacitors. Since they're pretty common now and don't cost that much more than standard electrolytic capacitors.
    I'm not a expert, I'm just doing my best.
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      For any of the KZG and KZJ that filter power for the CPU VRM or any other buck regulator output, then you might have to find replacements with ESR closer to KZG and KZJ. ZLJ will likely "work" too, but the ripple & noise may be higher, which may or may not be an issue (particularly with overclocking, higher-power CPUs, or large capacities of RAM.) So it depends on what the KZG and KZJ caps were filtering before. For example, the CPU VRM is buck-regulated, and so should be recapped with caps that have ESR that is closer to the originals. Since high-capacity low ESR "motherboard grade" electrolytic caps are not available for sale anymore anywhere, the common remedy is to go with polymers, as RukyCon suggested. Polymers usually come in smaller capacitance, though. However, it's generally OK to drop the capacitance up to 1/2 of what the electrolytic caps were (i.e. 820-1000 uF polymer in place of 1500 uF electrolytic and 1500-2200 uF polymer in place of 3300 uF electrolytic.) Polymers also tend to be more easily found for lower voltages (such as 2.5V and 4V.) With that said, for any "large" capacity 6.3V KZG and KZJ caps right next to the CPU heatsink - these usually filter the CPU VRM. So if you use polymer replacements for these, you can usually drop the working voltage down to 4V or even 2.5V (exception: if the KZG/KZJ caps had 16V rating, DO NOT drop the voltage rating - keep it at 16V.)
      Now, you may not need to replace every KZG/KZJ with polymers. Again, it depends where they are all located and what they filter. Any KZG and KZJ that are near or are electrically connected to an inductor or toroid of some sort - these will likely filter a buck-regulated rail, so you can use the same method as when recapping the CPU with polymers (but usually, it's better not to drop the voltage rating for these, unless you know the voltage of the rail the polymer caps will go on.) Otherwise, for the rest of the board (i.e. caps between PCI / PCI-E / AGP expansion slots, caps near USB headers, and small-medium caps close to I/O port area), ZLJ should be just fine. If available, I think ZLG, ZLH, and ZLS might offer slightly better ESR spec. Panasonic FR, FM, and FS, along with Nichicon HV and HW are good alternatives too, if those can be found easier where you are.
      What motherboard do you have, BTW?
      • blub0815
        • Jan 2021
        • 7
        Thanks for the elaborate answer!
        The motherboard is a GA-K8NXP-SLI. This is very rare and hence I want to be sure with the replacement caps.
        • DXseekerMO
          Failed UCC and Rubycon replacement on a Dell XPS410, equivalent?
          by DXseekerMO
          Hello, I'm working on an old Dell XPS410 with burst capacitors. I'm trying to source either an equivalent replacement, or a replacement that will work. It's been suggested to me to use Poly caps as a replacement, but I have no idea what to order or what will work.
          If anyone has a link to where I can buy what I need that would be even better.
          These are the caps that have burst:
          Board location: C8BV, C26BV, C43BV
          Brand: United Chemi Con
          Series: KZG
          Size: 10mm dia X 25mm height
          Impedance: (ohms max/20c, 100kHz) .012
          Ripple: 2800...
          02-04-2022, 04:48 PM
        • beogeek
          Need replacement advice for surface mount electrolytic capacitor
          by beogeek
          I have a faulty monitor, the surface mount electrolytic capacitor 33uF 100V needs to be replaced, now I can't seem to source them locally, so my question is can I replace it with a through-hole electrolytic capacitor of the same value? Or has someone got a better suggestion?
          Cheerio...
          03-17-2022, 01:43 PM
        • burom
          Xbox 360 Xenon Modern Capacitor Replacements
          by burom
          I found my old Xbox 360 in storage and opened it up to see if there was anything that broke since it was built in 2006 (launch era Xenon revision, never red ringed, never been serviced) and didn't want to find out by releasing magic smoke. Upon moving the dust bunnies out of the way I was greeted by a bunch of capacitors with crud coming out of the top; it doesn't seem to have leaked onto the board so at least I have that going for me.
          I'm posting here because I want to try to source replacement caps myself from Mouser or Digikey instead of braving eBay or waiting for places to have...
          06-07-2024, 05:10 PM
        • omon
          Please help find a replacement for Rubycon A0817 6.3V 1000uF 105C MBZ
          by omon
          I was hoping to get some help in identifying a replacement capacitor for a PET Rubycon A0817 6.3V 1000uF rated for 105C temp, MBZ series.
          This is to replace one bad capacitor on a DELL 530 motherboard DG33M03 (manufactured by Foxconn, DELL part # FM586).
          I'm attaching the pictures of the bad cap.
          Thank you so much!...
          04-28-2021, 05:43 AM
        • reformatt
          by reformatt
          07-31-2025, 08:37 PM
