A bulge necessarily equals a bad capacitor?
  • Trigo
    • Nov 2005
    I have an Intel D865PERL motherboard that only sees light (office) use, without overclocking, gaming or anything.
    I've recently noticed that one of the caps is bulging but hasn't shifted from 90° or anything. It's just got a bulgy top.
    Does that mean I have a bad capacitor?
    I'm asking bacause right after I first installed Windows in it the computer was very slow and hung all the time (no crashes or BSoD though). I proceeded to install all the drivers and everything was fine again, so I blamed it on the large SATA HDD (I installed WinXP SP1 which I was told didn't handle SATA all too well) and the amount of system tray utilities that needed to be loaded.
    I also installed SuSE Linux 9.3 and later 10.0 - the computer was never even slow running linux, which reinforced my initial belief in poor driver support in Windows (it was the original XP - not even SP1 - so I need install SP2 later).
    But now I'm reading about bad capacitors on Slashdot and elsewhere, and there's that bulgy cap, and Intel mentions D865PERL as one of the affected MoBos... (my brother who's into IT says it's "slightly" bulgy and that I shouldn't worry, but it looks just like the bulgy caps in badcaps.net "bad" pictures)
    I'll post a photo as soon as I get home but in the meantime... Does bulge equal bad??
  • linuxguru
    • Apr 2005
    • 1564
    Re: A bulge necessarily equals a bad capacitor?
    A domed/cracked top is always indicative of a capacitor that will fail. However, very slight bulges are sometimes present even in premium capacitors at the time of manufacture - I have a bunch of new Panasonic/Matsushita caps that have a tiny, barely visible bulge.
    • Chris1992
      • Apr 2005
      • 561
      And what capacitors are they? Intel boards are famous for using almost always good caps.
      The great capacitor showdown!
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        the only likely candidates for failure on a Intel D865PERL would be the nichicon HN(M) or HM(M) series or in some cases the little yellow fujitsu caps (have an F symbol on them) can cause a problem. the rest of the caps would be rubycon, other nichicon series or united chemicon which are good.
        for your installation issues, i have no idea, not cap related though. perhaps a different bios might have helped? my D875PBZLK doesnt supply enough voltage to the hyperx ram to run it at the proper agressive settings. they implemented vdimm adjust in a later version of the board
        anyway check for HN HM and tell us which cap is bulging. a pic would be nice.
        • Fatal0E
          • Jan 2004
          • 252
          Built many security camera DVR systems with this board, and the 845epil, they are all coming back in with blown nichicon HNN caps, tall skinny ones next to the cpu. Intel fixes them for free with chemicon and oscon caps.
          • einhverfr
            • Nov 2005
            • 11
            Just for the record in order to help people who may read this later.
            A domed/bulging capacitor always indicates a capacitor that needs to be replaced. And this may occur for reasons other than manufacturing flaws.
            Electrolytic capacitors have one issue as a group. They have a liquid in them (the electrolyte mixture) which can boil when the cap overheates. To prevent uncontroled explosions, these caps are "vented" on the top usually with stamped lines in the aluminum foil casing. This means that this area will be the first to fail under pressure. So bulging capacitors indicate ones that are overheating under current use. They should be replaced.
            Most of the discussion on these forums centers around bad electrolyte mixtures that boil at low temperatures (within the expected operating temperature of the cap). However, all electrolytic capacitors can fail/overheat if voltages are reversed, if a voltage spike occurs, or if other heating problems are present. So the fact that these are otherwise good brands of caps provides no guarantee that an individual cap will not fail. I would therefore suggest that if the cap is overheating and is an otherwise known good brand that you might want to consider replacing it and monitoring it, and if the second one starts to fail, replace your motherboard before something bad happens.
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              Was installing a NIC in a Intel D865PERL board, saw two bad Nichicon HN(M) caps between the CPU and RAM... No pics because I was unable to take a good pic with his digicam...
              http://www.intel.com/cd/channel/rese...tes/193414.htm
              • arneson
                • Sep 2005
                • 1267
                This is good advice but the monitoring may be difficult for a machine that's not in your possesion.
                Very good post, you kind of summed up my feelings nicely.
                Jim
                • willawake
                  Super Modulator
                  • Nov 2003
                  • 8457
                  • Greece
                  what was wrong with the onboard nic?
                  anyway you wanna get RMA on the board. hopefully you will get back a late revision which will be kickass.
                  i wish my D875PBZLK had badcaps to get me a late revision
                  • willawake
                    Super Modulator
                    • Nov 2003
                    • 8457
                    • Greece
                    nobody has any comments on that?
                    • PeteS in CA
                      • Aug 2005
                      • 3581
                      • USA, Unsure of Planet
                      [Basso profundo]You rang?[/Basso profundo] Hmmm ... well, if you simply heat a lytic, not connected to a circuit, they start to swell at around 140C-150C (ambient, case, and core temp). When I torture caps, their core may reach that temp when I start to see swelling, but I suspect another mechanism may be at work - in my tests and in the MBs these forums focus on. I think it is very likely that the ripple current (in my tests and on the MBs) is causing the cathode foil to be formed, which generates hydrogen gas and can cause swelling and venting.
                      While I agree that the electrolyte is a vulnerability in a lytic cap, that electrolyte is also the true cathode of the capacitor (the cathode foil simply makes the electrical connection to the outside world possible). As such, the electrolyte is necessary for there to be capacitance, and the electrolyte also conducts the ripple current.
                      PeteS in CA
                      • linuxguru
                        • Apr 2005
                        • 1564
                        There may be multiple mechanisms at work:
                        1) Direct electrolysis giving rise to H2 that is not fully neutralised by (possibly inadequate or missing) depolarizers - this is directly related to high ripple current.
                        2) Basic pH of faulty electrolytes directly attacking the aluminium foil due to the failure of Aluminium oxide barrier layers - this can explain the failure of some caps like YEC that have never been in-circuit, leave alone powered up.
                        3) Impure foil containing 2.5% copper that causes local galvanic action and foil corrosion, leading to failure (this is related to 2. above, in that it can happen without any voltage applied to the electrodes).
                        4) Overheating due to ripple current and/or proximity to the CPU that causes trapped moisture to evaporate to steam - this is probably the dominant failure mode in the small yellow Fujitsu polymer SPAs on the Intel motherboards (this could also be considered to be a design flaw by Intel, rather than a quality issue in the capacitors).
                        The chemistry is fairly complex as numerous materials are found in a modern electrolytic, so there are probably additional mechanisms at work. As a general rule, if the rate at which it fails increases exponentially with a rise in temperature, there is a chemical (Arhenius) mechanism in play; if it increases linearly or not at all with temperature, there is a pure physical mechanism (like phase change or dissolution) at play.
                        Both kinds of mechanisms are always at work - but in a good capacitor, the rate of reaction is vanishingly small over the entire range of conditions it is specified for, giving a long lifetime.
                        • arneson
                          • Sep 2005
                          • 1267
                          Sounds like a description of my Liver, which I hope will give long life.
                          Jim
                          • willawake
                            Super Modulator
                            • Nov 2003
                            • 8457
                            • Greece
                            did you get extended warranty?
                            nice post by linuxguru btw
                            • ribcage
                              D865PERL has low 1.5 V
                              by ribcage
                              Hi, could anyone tell me where on this board is 1.5 V generated? Looking at it's reading from the monitoring chip, it seems to have dropped over time, and is often at 1.406 V, while the datasheets for the chipset say the minimum is -5% or 1.425 V, if I understand them correctly. Maybe this is the cause of ocassional crashes for me.
                              07-10-2025, 06:24 AM
                            • kotel studios
                              Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
                              by kotel studios
                              Finally got time to fix this board up.
                              At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
                              Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
                              04-22-2025, 05:08 AM
                            • ribcage
                              Can I substitute these capacitors on a D865PERL motherboard?
                              by ribcage
                              Hello, I'm repairing an old Intel motherboard D865PERL and I wonder if I can substitute capacitors in this way:
                              Nichicon VR(M) 470uF 10V 6.3x11mm B0341 85*C (red in picture)
                              and
                              Nichicon VR(M) 100uF 25V 6.3x11mm B0341 85*C (green in picture)
                              with Suncon "low impedance" 330uF 6.3V 6.3x11mm 105*C
                              Nichicon VR(M) 470uF 16V 8x11.5mm B0311 85*C (blue in picture)
                              with Suncon "low impedance" 560uF 6.3V 8x11.5mm 105*C
                              These are the most similar I can find of a reputable brand. I don't...
                              10-18-2020, 03:44 AM
                            • Hobby-Schrauber
                              MSI GE67 (MS-15451) 16GB VRam Upgrade
                              by Hobby-Schrauber
                              i have a MSI GE67-12UGS Notebook (MS-15451 mainboard) and i want to make a 8GB too 16GB Upgrade for the 3070 TI. It is possible because this notebook was also available with a 3080 TI 16GB version. The problem is that i dont know where the straps are located and what are there configuration. The 12UHS version with the 3080 Ti is useing 8x Samsung K4ZAF325BM-HC16 2GB chips, the 3070 Ti has 8x Samsung K4Z80325BC-HC14 1GB ones. Can anybody help me too find the strap positions an there configurations?
                              By the way, there were MSI notebooks with similar motherboards...
                              06-27-2025, 05:09 PM
                            • TrisHCl
                              LED TV Boot loop - UE40F6500SB
                              by TrisHCl
                              First post...
                              I have this TV, which was working, then suddenly would not turn on. It would get the clicking relay then flash up the screen for less than a second, off for a second then on again. Removing the plug the relay continues to click on and off for a few cycles, which I don't think it did before.
                              Left it a few months, then finally got round to taking the back off, and it worked as it should. So I tested various bits and all was well. Then turned it on again, and back to the clicking relay.
                              I disconnected the main board from the power...
                              02-06-2025, 08:42 AM
