Deep Well Pump Control Box - Start & Run Capacitors & Relay - CB20412CR
  • JuniperSprouts
    Solder Soldier
    • Aug 2010
    • 119
    Trying to help a small hospital in Haiti...
    Is it possible to test the relay without it being hooked up to the pump motor? It is the normal 5-1-2 configuration, as far as I understand it.
    Any tips for testing large start/run capacitors of this size and nature?
    • Jul 2011
    • 6024
    Re: Deep Well Pump Control Box - Start & Run Capacitors & Relay - CB20412CR
    This is very similar to a Freon compressor start relay one general rule is if the start capacitor is open or exposed then more than likely it is bad and should be replaced the run capacitor needs to be checked also to make sure that the UF value is correct and not low in value
    If everything is good and the motor still not start and runs then either the motor is faulty or the start relay is faulty and should be replaced
    Also need to check with a amp clamp on meter that your starting current is only momentary and that your running current does not exceed the current rating on the data plate
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8672
      agreed should be able to test each component individually. The start/run caps have to have their rated capacitance and their DC leakage value needs to be low, usually an ohmmeter is sufficient for the latter.
      I've heard a lot of techs in the past just use leakage as the sole metric for testing motor capacitors (and the pulse behavior of capacitors at DC). Not sure how accurate this is, but these are metrics that must be sufficient for a working capacitor, and hence motor.
        • Jul 2011
        • 6024
        I would check these devices and make sure that they have a good connection and that they work properly you do have to stall the motor to check the over current one the starter one should not stay on for more than a few seconds at the most
        • Dannyx
          Remote pump control ideas.
          by Dannyx
          Good day folks. A task was given to me to redesign the control system for a pump system in a remote location. The idea is that there's a tank which has a float or some sort of switch/sensor to detect when it's full/empty and this runs some pumps accordingly. The trouble is the pump and the tank are like 4km apart, from what the chap who inspected them on our behalf told me, so the way this currently works is by using some unknown boards based on SIM cards (see the pictures). From what I can assume, when a contact closes at the "client side" (the tank), it calls up the "server side"...
          09-11-2020, 04:10 AM
        • jm1234
          9V relay temperature 40C
          by jm1234
          Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
          I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
          05-09-2024, 03:03 AM
        • edugimeno
          Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
          by edugimeno
          Hi everyone!
          I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
          I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
          This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
          To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
          I respected the polarity, positive to cathode of protecting diode
          So provided all...
          04-18-2024, 01:15 PM
          ZD-915 vacuum pump motor mount service alert
          by sam_sam_sam
          If you have this Desoldering Gun Station there is something you should be aware of the two screws that hold the motor to mounting for pump can come loose and make raddling noise
          One note this unit has been repaired already once because of switching power supply regulator ic chip failure
          Now this with the vacuum motor mounting issue yes I give this Desoldering station a very hard work out and use about every weekend to do some type of project
          The fix is taking the vacuum pump assembly out and take the metal cover off and you will see the two screws on it
          09-19-2021, 02:15 AM
        • Yanleb
          LG 60PK550 Logic Control Board EBR63450301
          by Yanleb
          Hi all, I just want to share the repair of my 60PK550-UA TV set.
          The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
          But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
          All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
          C57: 3.30V
          C61:...
          07-20-2023, 12:38 AM
