Try our new boardview, bios, & schematic search. Over 1.3 million files for download!
nichicon LKS for psu to replace the nippon SMH
    No photos found.
  • DrewPhillips
    Capacitor Diarrhea - Nichicon PL Series
    by DrewPhillips
    Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
    The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
    03-02-2025, 10:18 PM
  • sdancer75
    Replace an LG 49UH850V cracked diffuser
    by sdancer75
    This specific model, LG 49UH850V, is 3D. The problem here is that the diffuser has been cracked at the bottom, where the LED strip is installed, due to the heat from the LEDs. This is a common problem for many LGs and Samsung TVs.
    The questions here are
    1) Can I replace the diffuser from a non-3D LG TV with the same size (exact fit)?
    2) If I replace the diffuser with the original part, do I have to replace the LED strips also? They work as expected, but some technicians recommend replacing them together.
    Regards,...
    02-05-2026, 01:08 AM
  • spiros.p
    replace nichicon HE series 2200mf 16v with vishay BC 136 SERIES 2200mf
    by spiros.p
    i have replace nichicon HE series 2200mf 16v with vishay BC 136 SERIES 2200mf.measuring the nichicons sean on meter 2550mf and zero esr.i measure and the new vishays and sean 2080mf and near zero esr that looks normal.the nichicons numbers is normal so far from label data?and what about vishay 136 any infos from other users here?
    09-27-2021, 06:12 AM
  • spiros.p
    EV dsp,replace the nippons lxz with nichicon fw ?
    by spiros.p
    Hi guys.I have two EV dsp processors and before two years i do full recap to both. The units have before recup thousands hours running.On output input coupling caps (16 pieces) i solder nippon lxz series 100mf 63v (this time i don't have other stock) i know is low esr caps.Last week have found and order nichicon fw standard audio series.Is a good reason to replace the nippons lxz with nichicon fw ? The units get better sound? Or get worse?Thanks for any advice.
    12-19-2023, 12:26 AM
  • nick3092
    Mid/late 80's Nichicon Yellow Caps
    by nick3092
    I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
    08-28-2022, 03:56 PM
