MXM Graphic card Nvidia Quadro K1000m /K2000M schematic or value of capacitor C55 capacitance and voltage from laptop HP8570w
  • Quadro1000
    • Dec 2025
    I had a MXM graphic card type Nvidia K1000m from laptop HP8570w which had a broken capacitor.
    The ceramic capacitor seems was broken and makes a short circiut. The laptop goes off because of the short-circuit. But it seems currently that only the capacitor C55 was broken on the graphcic card.
    Because after I have desoldered it, the laptop runs with the card. But currently without this capacitor.
    So to have full functionality and no instabilities I want to replace it with a new one.
    So I need to know the value and voltage of C55 to replace it. See in the picture.
    As I have correctly seen in the internet, the board could be identically to the bigger type the Nvidia Qudro K2000m, so a schematic / info from that I think is also possible.
    Also I think the that the C51 near to the broken one is the same type, but this is only theory at the moment.
    So would be fine if someone can help with this info or a schematic to replace the capacitor.
    Board P/N: 010176C00-600G
    VELMA_MV_MXM_(Q1)_V1
    Thanks!
    Click image for larger version  Name:	grafik.png Views:	0 Size:	4.27 MB ID:	3785871
  • Quadro1000
    • Dec 2025
    ok I have identified the IC next to the C55 it's a CSD97370Q5M from TI.
    If I look into the datasheet I found some PCB design recommendation that says for this C's on Vin it's recommended to use
    10μF size 1206 25V ceramic capacitors (TDK Part # C3216X5R1C106KT or equivalent)
    As it's a flat type I would say not more than 0,85-1mm ideally.
    datasheet CSD97370Q5M from TI
    https://www.badcaps.net/download/?id=e1487a82
    datasheet capacitors TDK
    https://www.badcaps.net/download/?id=81f56d38
    But would be nice if someone could confirm this info with schematic.
