Alienware M17 R3 LA-J521P REV 1.0 Boardview CAD & Schematic
Alienware M17 R3 LA-J521P REV 1.0 Schematic & Boardview
User submitted datasheet, schematic, boardview, service manual, firmware, bios, & software.Tags: None -
Hola a todos,
Solo quería tomar un momento para agradecer sinceramente a quienes compartieron el schematic y boardview del Alienware M17/15 R3 (LA-J521P). ¡Me han sido de gran ayuda para diagnosticar y reparar una placa con problemas complejos!
El nivel de colaboración y generosidad en este foro es admirable. Gracias nuevamente por compartir estos recursos tan valiosos con la comunidad.
Un saludo desde Colombia,
QueReparo
by Jclark87Hey guys I have a buddy that spilled liquid on his Alienware and now when powered on it says it cannot detect the hard drive. I'm sure the circut is shorted I'd like to replace all the components in that circut and get the board all cleaned up.
Its a Alienware m15 R5 Ryzen, P109f002, with motherboard GDL56 LA-K453P Rev:1.0
I really need the board view.. i think i have the correct scematics but if you could also post those so im 100% sure i have the correct ones that would be great!
But board view for sure please and thank you 😊-
by MozwaldHi
Does anyone have
ALIENWARE M15 R3 - LA-J522P - Schematic/boardview
Thanks-
by PacoGThello firends
i search the schematic or boardview
I have this motherboard, but I can't find the schematic or the boardview.
The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
So the computer doesn't turn on, and the 3V disappears after a few seconds.
The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
The new problem arose after removing the bad chip.
3V and 5V remained together,...-
08-19-2025, 08:25 PM -
by hosain0489Hello everyone,
I’m looking for the schematic and boardview files specifically for the AMD version of the HP Omen 16 laptop, model xf0006AX, equipped with the Ryzen 7 7840H CPU.
Most of the files I’ve found are for Intel CPU versions, and I need the exact files for this AMD Ryzen 7 7840H model to assist with repair and troubleshooting.
If anyone has access to these files or can kindly share the boardview and schematic for this particular AMD version, I would really appreciate your support.
Thank you very much in advance!
by re-atariHello all,
Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...-
- Loading...
