AMD Radeon RX 5500 XT (5500XT) Schematic & Board View
    AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
    The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...
    10-01-2024, 12:46 PM
    AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
    The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
    10-01-2024, 01:07 PM
    AMD Radeon RX 470 / RX 580 Schematic & Board View
    The Radeon RX 470 is a mid-range graphics card by AMD, launched on August 4th, 2016. Built on the 14 nm process, and based on the Ellesmere graphics processor, in its Polaris 10 PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 470. The Ellesmere graphics processor is an average sized chip with a die area of 232 mm² and 5,700 million transistors. Unlike the fully unlocked Radeon RX 480, which uses the same GPU but has all 2304 shaders enabled, AMD has disabled some shading units...
    10-01-2024, 12:52 PM
    AMD Radeon R7 340 / R7 430 Schematic & Board View
    The Radeon R7 340 OEM was a graphics card by AMD, launched on May 5th, 2015. Built on the 28 nm process, and based on the Oland graphics processor, the card supports DirectX 12. Even though it supports DirectX 12, the feature level is only 11_1, which can be problematic with newer DirectX 12 titles. The Oland graphics processor is a relatively small chip with a die area of only 77 mm² and 950 million transistors. It features 384 shading units, 24 texture mapping units, and 8 ROPs. AMD has paired 2,048 MB GDDR5 memory with the...
    10-01-2024, 12:36 PM
  • diamon
    Changing model number 5500 to 5510
    by diamon
    I would like to place a Dell Latitude 5500 (black color) motherboard into a Dell Latitude 5510 (silver color) chassis .
    How can I change the model number of this laptop?.
    When you're entering the bios (F12), you see in the left corner Latitude 5500, I would like to have this changed into Latitude 5510
    I have already edited the 5500 bios bin file with HxD, and changed the 5500 into 5510, but after re-flashing and soldering the chip back, the name in the left corner is still Dell Latitude 5510 (have entered the ServiceTag of the 5510 chassis).
    Have uploaded the original...
    06-19-2025, 03:25 PM
