#21 |
City & State: USA
Ya I have starting searching for PlainBill's posts also and can't thank him enough. I will have to check out the electronic's for dummies. Thank you for sharing your info with me.
#22 | |
City & State: Canada
I found this youtube channel good for beginners interested in TV repair. He has 10 tutorials.
http://www.youtube.com/user/GrantsPassTVRepairs He goes through a lot like how to test such and such. I have watched each more than once and it is starting to sink in now. Quote:
#23 |
City & State: USA
Awesome man, thank you for the link!
#24 |
City & State: USA
I just replaced all but 2 small caps (which I will order and replace) and the same problems still exist as in the original post. Upon boot up of the computer the wavy text and flickering gets better over time (75% of the time)
I am also now hearing a hissing sound coming from the rear of the monitor? Any ideas? Also, when I minimize a full screen window the sound makes a different noise from the rear of the monitor. Last edited by nuhhht; 06-15-2010 at 02:54 PM.. |
#25 | |
City & State: Phoenix, AZ
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist
The other problem may be a bad cap on the logic card. It's ESR is dropping as it heats up. Possibly carefully check each cap on the logic card to see if one seems warmer after a few minutes. (It's a long shot). PlainBill
For a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored. Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic. |
#26 |
City & State: USA
If I remeber correctly the inverter and the power supply were
the only compents with caps on them. I will take it apart and double check. Why would the bulbs all the sudden start going out? Colors and contrast seem fine. |
#27 | |
I'm a: Hobbyist
PlainBill |
#28 |
City & State: USA
I used 60/40 lead/tin. I will double check all the connections
#29 |
City & State: USA
Here are some quality photos of the power supply board. I did find some cold solders that I will have to redo.
Can you guys spot anything unusual or give me a direction to check next. The green boxes on the caps are the ones I've replaced and the red's are the ones I haven't (yet) If you guys want more pictures let me know. |
#30 |
City & State: Tucson, AZ
nuhhht
Just wondering if you got this figured out yet? I have the same monitor but mine just turns black after about 10 sec, and the power light stays on. Doesn't matter if I hook it up VGA or HDMI, to a pc or a blu-ray, all the same. I tried the flashlight trick and its pitch black until I power off the monitor then I can see the light????? This was not a cheap monitor to just toss in the trash and replace. I have fixed other monitors before but this one has me stumped. Please lmk your progress. Thanks |
#31 | |
I'm a: Hobbyist
PlainBill |
#32 | |
Thanks Bill, I will give that a shot. I did end up testing the caps on the logic card with a ohm meter and the small ones dont seem to be working correctly. Im going to replace them today and get it put back together to check if the ccfls are on or not when the screen goes black. |
#33 |
answer is the logic card had same problem so i bought a new hannsg hg281d. and tested by doing switch so power supply is good but when i put the new logic card then the flickering is gone and wont turn off wont go to sleep mode like it did before .now it work great so i order a logic so the problem is not power supply
dude to many people will get you confuse so the power supply look good by looking at the caps dont mess with its you need a new logic card winch cant be fix only hannsg got it in stock [QUOTE=nuhhht]Hey guys, I have a Hanns G HG281D 28" 1920x1200 5ms monitor that has recently started to show symptoms of a bad inverter ie: the screen would show grey lines of brightness (flickering kind of) the icons on the desktop would look as if they were being shaken. Also, randomly the screen would turn off but the power led light would stay on. |
#34 | |
Where can I order a new logic card? Thanks [QUOTE=josesantiago1983;115014]answer is the logic card had same problem so i bought a new hannsg hg281d. and tested by doing switch so power supply is good but when i put the new logic card then the flickering is gone and wont turn off wont go to sleep mode like it did before .now it work great so i order a logic so the problem is not power supply dude to many people will get you confuse so the power supply look good by looking at the caps dont mess with its you need a new logic card winch cant be fix only hannsg got it in stock Quote:
#35 |
did anybody try to get power board anywhere online that would be easy fix just put new board and done instead changing capacitors or some other parts.
#36 | |
I'm a: Hobbyist
PlainBill |
#37 |
Grumpy Old Fart
Line Voltage: 120V 60Hz
Replacement cards usually get you fresh BAD caps.
Mann-Made Global Warming. - We should be more concerned about the Intellectual Climate. - Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind. - Dr Seuss - You can teach a man to fish and feed him for life, but if he can't handle sushi you must also teach him to cook. - |
#38 |
So I had the same problem with the backlight turning off and squiggly lines. At first I re-capped the power board which did not fix the problem. Then I found two 100uf 16v by the two power transistors that were bad. Problem fixed after I replaced them.
#39 |
As a NEW member ,the posts are great with the exception of all the values of the caps are given but not the circuit location such as C1,C2 etc. They are all marked for the circuit reference and if quoted will make it easier to get to the correct caps . The 22/450v cap is the start up
#40 |
City & State: WA
Sorry to resurrect a old thread, but I was having this issue too and replacing all 3 of 100uf 16v caps on the logic board fixed the issue for me. I salvaged some caps from an old usb2 pci card, so with a little extra work, it cost me $0.00. woot!
| Thread Tools | |
| Display Modes | |
