Hitachi HCG FA Capacitor Date Code?
  • kiwitonita
    • Aug 2009
    • 3
    Hi - do large capacitors have a date code? Just wondering - there are 3 Hitachi 10000MFD 450 VDC capacitors (in parallel) in an Intense Pulsed Light machine which is about 3 years old. The capacitor model number is HCG FA. Also on the front are the markings 2X B7. A stamp on the base of each capacitor says A7088. Is this a date code of some sort? If so, does anyone know what it means?
    I found a Tantalum Capacitor Date Code Table in the Data Sheet with a few date codes but not much help in this case.
    Thanks very much - Tony
  • kiwitonita
    • Aug 2009
    • 3
    Re: Hitachi HCG FA Capacitor Date Code?
    I got a very quick reply after contacting the Hitachi Chemical Co. America, Ltd. via their web site. They said the HCG FA had not been produced for 15 years and after seeing photos confirmed they were counterfeits.
    Dimensions of the black case are 90mm diameter, 170mm high. Terminals are additional height of about 10mm. My simple Fluke digital meter measures the capacitance of each at just under 10,000uF.
    • Nicely1
      • Oct 2018
      • 1
      Hi
      Need help i want to know the date code marking for
      Hitachi HCGF6A 15000MFD 400VDC
      DATE: 25 A7 ?
      Regards
      • redwire
        • Dec 2010
        • 3910
        I suggest contacting Hitachi Chemical.
        There are no documents explaining their manufacturing and lot number codes, that I could find. Also these caps are popular for chinese counterfeits.
        If it's a old DC-link cap, and you need to reform the dielectric, I would follow ABB's advice below; 1hour per year of storage.
        Method 2 is current-limited charging, Method 1 is the drive powered up but stopped.
        • R_J
          • Jun 2012
          • 9543
          Here is some additional information on Hitachi fake capacitors http://sound.whsites.net/fake/hitachi-caps.htm
          • AleXis6
            Manufacturing Date of Electrolytic capacitor
            by AleXis6
            Guys. could you help me please to decode some codes of main capacitor's producers.
            I would like to know the manufacturing date.
            Based on the information from capacitors I have - it seems easy to decode manufacturing date for Rubycon, Nichicon.
            If I understood correctly:
            1. Nichicons marks date of production as (see the attached pictures) H2116
            I don't understand the meaning of first letter - may be it is code of factory.
            21 -year
            16 week
            I bought this capacitor recently.
            another one-
            2....
            10-11-2021, 02:20 PM
            LCD LED TV Service Menu Codes
            ALL LCD LED TV SERVICE MENU CODES
            Service Menu Code with Board Name
            China Universal Board / Jumper Board Service Menu Code
            Changhong Ruba Service Menu Code
            Ecostar LED TV Service Menu Code
            Orient LED TV Service Menu Code
            Haier LED TV Service Menu Code
            TCL LED TV Service Menu Code
            Samsung LED TV Service Menu Code
            LG LED TV Service Menu Code
            Videocon LED TV Service Menu Code
            Supra LED TV Service Menu Code
            Toshiba LED TV Service Menu Code
            Symphony LED TV Service Menu Code
            Veste/ LED TV Service Menu Code...
            10-31-2024, 03:58 AM
          • CdDvdFlash
            Hitachi HTA-DD3W AV Receiver Error Code -Protect-
            by CdDvdFlash
            I have a Hitachi HTA-DD3W AV receiver and when I got it I tested it working fine with speakers but it needed a clean inside because it had signs of moisture in it but it was fully dry with bits of wood chips, I guess this was left in a shed so I fully disassembled it and cleaned it with isopropyl alcohol very carefully, some de-soldering was also needed but now its very clean, luckily there was no rust on any components and all the capacitors are fine with no bulging. When I turn it on I hear a relay switch on then a few seconds later another relay switches on or off and the display has a "-PROTECT-"...
            07-10-2023, 06:05 AM
          • Prolog
            RTX 3080 FE Identifying capacitor
            by Prolog
            Hi people, I hope this is the correct spot to post this, I'm new to the forum.
            I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
            I hope these photos make it clear which component I am referring to:
            (yes, the soldering is a bit botched from removing the blown one, I know)
            I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
            12-01-2024, 08:27 PM
          • chth96
            If I replace with inferior capacitor, Is it No harm to other IC components at all?
            by chth96
            I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
            Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
            It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
            So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
            I know that these capacitor will not last as long as nichicon capacitor...
            12-22-2023, 04:34 AM
