#1 |
I have a 26" benq monitor/tv Model: dv2680. It has 8 ccfl's backlights and one is bad. In lieu of replacing it, can someone tell me how to fake it out or bypass it. Its viewable with 7 of them working...Thanks
#2 | |
![]() Second, use a more descriptive thread/topic name. Third, look around for Dummy Load. I think PlainBill would be able to help you in that topic, as I do not have enough knowledge to serve you ... ![]()
#3 | |
City & State: Phoenix, AZ
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist
I mentioned those because I'm not going to infer a relationship between those names and what you are trying to do. In general, here is the theory. Measure the voltage across and the current through a working CCFL. Calculate the equivalent resistance and power dissipation of the CCFL. I.E. If there is 780 V at 8.3 ma through a good CCFL the equivalent resistance is 94K ohm. 100K ohm is close enough. It was dissipating 6.5 watts, better use a 10 Watt resistor. Now the problem is your typical DMM won't accurately measure the voltage or the current. The best solution is to pick up a range of 10 Watt resistors and try them until you find the highers value that works, then go down 10%. Of course, by the time you have done that you will have spent more than you would pay for a new CCFL, and you won't have to be annoyed by people asking why there is a dark band across the screen. PlainBill
For a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored. Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic. |
#4 | |
#5 |
Yes this is what is done to load test the lamp inverters. Even in few service manuals spells this out.
and 96K is too low, I recall around 120K and yes use 10W sand bar because of high KV. Cheers, Wizard |
#6 | |
I'm a: Hobbyist
PlainBill |
| Thread Tools | |
| Display Modes | |
