Go Back   Badcaps Forums > Motherboards with Bad Capacitors > Other Devices with Bad Capacitors
Old 11-23-2009, 09:48 PM   #1
kc8adu
kc8adu's Avatar
City & State: dayton ohio
My Country: U.S.A!
Line Voltage: 12vdc,120/240vac,480vac 3ph on my bench
Default yaesu ft-101zd.bad caps with a twist.
no surprise to see bad caps in this 70's radio.
but who was the idiot that thought a sticker would fix the hole that was DRILLED in that cap?yes it is shorted and opened up a resistor.
this is the bias/screen supply for the p.a section.no screen voltage=no output!
kc8adu is offline   Reply With Quote
Old 11-24-2009, 03:18 AM   #2
japlytic
japlytic's Avatar
City & State: Rockhampton, Queensland, Australia
My Country: Australia
Line Voltage: 240VAC 50Hz
I'm a: Hobbyist
Default Re: yaesu ft-101zd.bad caps with a twist.
You're right about that sticker covering the hole would not fix the drilled capacitor.
With the 6JS6 (and other) TV horizontal output (sweep) valves, they can have slightly different inter-electrode capacitances between different brands, and may need modifications to the neutralization and feedback circuitry in certain models. This is especially true for this model (any suffix) of transceiver.
See http://www.rfparts.com/tubeinstall.html for more information.
japlytic is offline   Reply With Quote
Old 11-24-2009, 05:56 AM   #3
kc8adu
kc8adu's Avatar
My Country: U.S.A!
this one uses 6146 tubes.i own a bunch of the 101 series.most use the 6js6.
been changing sockets to put 6146's in the older rigs.when you get several hundred milspec ones from drmo auction you use them.
Old 04-12-2010, 03:40 AM   #4
c_hegge
c_hegge's Avatar
Line Voltage: 240V 50Hz
No vents!
I once opened up a radio and found capacitor guts everywhere, the can loose and two legs sticking out from the PCB. The cap had obviously exploded
c_hegge is offline   Reply With Quote
Old 04-13-2010, 12:36 PM   #5
smeezekitty
City & State: Washington, USA
Tubes?
Are you certain its 1970's, not 1960s?
smeezekitty is offline   Reply With Quote
Old 04-24-2010, 04:53 PM   #6
kc8adu
kc8adu's Avatar
My Country: U.S.A!
Originally Posted by smeezekitty
Tubes?
yaesu and kenwood made these hybrid rigs into the early 80's.
