Go Back   Badcaps Forums > General Topics > General Capacitor Questions & Issues
Old 11-03-2009, 12:58 AM   #1
didyman
Default High voltage Capxon LP failing issues
Dear members! I have a blog about these craps and finally i feel the time right to post here too.
The story and possible background is described in details in hungarian. If needed, i will translate all of them. The basics in short:
So many FSP and OEM power supplies built around the CM6800 controller, commonly named as "green line", "Bluestorm II" and "Epsilon" suffering this. Symptoms are clear: PSU failing with low load, or even no load, buzzing noise. These are the least worries, but some of them failing with the PFC coil totally burnt without failing the PFC FETs, or even the FETs are in short. After the significant rise of these unusual problems with FSP PSUs, it's clear that the primary capacitor has some kind of faliure. But this not as straight, as these caps may show exactly good parameters with a multimeter or even an ESR meter! Only a part of them may show no capacity at all, or even very high ESR. So afterall, i decided to take a closer look inside.
Devastating. The anode conductor has totally pulverized, some kind of corrosion is in effect and contact is loose, unstable, sometimes shows spikes have arisen.
Collected data show these commons:
-All Capxon LPs are affected with date 2005-2006, seems that 2006.10 is already OK
-The affected voltage rating is 400V. 450V models seem OK, but sample is too low.
-180uF..330uF values are surely all affected.
-There are some of these replaced as a preventive action, showing nothing unusual in use, but disassembled and clearly affected (that makes the problem even risky)
-No bulging, no vent
With conjunction of some collagues, we believe that a failing manufacturing process may be the primary reason, but the use of active PFC may also helps, as with the use of active PFC, the ESR value of the primary capacitor surely gets into brighter sight.
The blog is here: http://logout.hu/cikk/kapacitasproblemak/teljes.html
We (the prohardver forum) have also contacted FSP about this issue and awaiting answer from them.
didyman is offline   Reply With Quote
Old 11-03-2009, 05:54 AM   #2
kc8adu
kc8adu's Avatar
City & State: dayton ohio
My Country: U.S.A!
Line Voltage: 12vdc,120/240vac,480vac 3ph on my bench
Default Re: High voltage Capxon LP failing issues
seeing the same thing in apple g5 psu's and even in industrial stuff.
on the one i autopsied the lead foils to the terminals were gone.
kc8adu is offline   Reply With Quote
Old 11-03-2009, 09:02 AM   #3
Wizard
Could be the nanosecond long too high spikes is so high or incorrect electrolyte?
Spikes means bad design or unique to specific PF IC controller or PF circuit itself.
Cheers, Wizard
Wizard is offline   Reply With Quote
Old 11-03-2009, 10:46 AM   #4
didyman
Cheers, Wizard
Capxon LH series, and the Ost isn't affected, aswell younger Capxon's don't show any sign of beginning corrosion. Despite of that, CM6800 and its former L4800 counterparts have some issues regarding the PFC, maybe just requiring better qualty caps to work flawlessly.
Old 11-12-2009, 07:36 PM   #5
moxy
wait until you soon lose American made
Panasonic foil
soon to be only capxon next year
maybe somebody could stop that
I hope
moxy is offline   Reply With Quote
Old 11-21-2014, 11:42 AM   #6
CapSwapper
City & State: CA
Capxon is GARBAGE.
CapSwapper is offline   Reply With Quote
Old 11-21-2014, 12:12 PM   #7
stj
stj's Avatar
City & State: Europe
thanks for the reminder.
Old 12-05-2014, 06:08 AM   #8
japlytic
japlytic's Avatar
City & State: Rockhampton, Queensland, Australia
My Country: Australia
Line Voltage: 240VAC 50Hz
I'm a: Hobbyist
When I tested my collection of 400/450V electrolytics, I found two which had no capacitance at all.
Could it be a bad weld or electrolyte corrosion between the foil and the leads?
japlytic is offline   Reply With Quote
Old 12-05-2014, 08:00 AM   #9
stj
stj's Avatar
open them and find out.
Old 12-05-2014, 09:53 PM   #10
CapSwapper
City & State: CA
you have a collection of CrapXon? The only place they should be collected is in a landfill.
Old 12-05-2014, 10:18 PM   #11
stj
stj's Avatar
DELL like capxon, i have a dead psu here that was killed by one leaking.
Badcaps.net Technical Forums © 2003 - 2017
