Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Power Supply Design and Troubleshooting
Old 10-15-2009, 04:08 PM   #1
370forlife
Large Marge
370forlife's Avatar
City & State: Kalamazoo, MI
My Country: United States
Line Voltage: 0-120VAC 60Hz
I'm a: Hobbyist Tech
Send a message via AIM to 370forlife
Default HEC Orion HP585D
A freebee. Usually $30 on newegg, lets crack her open and see what she's made of...
Oh dear. Not that good. Those are the tiniest input caps I have ever seen! They are only 18mm diameter! No way they are 680uf. At least that is a decent actual 35 sized transformer. I can't remember the primary's part number, but it is in single forward rated at 600v, 10A continuous, 36A pulse (mode used here,) with a copper plate to help with heat. Fans are by Young Lin Tech, so not totally skimping here.
Chart shows no combined power, just the max for each rail. Hmm....
Hello, anybody home? And what the hell is that, is that supposed to be a bridge rectifier. I've only seen ones like these used in audio amps. No provision for heatsinking, and is rated at 4A, 600V. 480W is not near 585W, and this is rated at 75% efficiency.
Teapovision. All the secondaries consist of teapos, except for the small ones for the -12v and -5v, which are su'scon. Super group regulation. All three rails on one coil. Ugh.
Secondary heatsink components. One on the right is a 30A, 45V part on the 3.3v (rated at 36A). Middle is a 40A, 45V part for the 5v rail (rated at 36A). On the other side of that, not visible due to the transformer, is a lone 20A, 40V part for the 12v ("2" rails, even though all 12v come from same holes, with one at 19A, one at 20A, no combined rating).
Originally Posted by JFK
The American, by nature, is optimistic. He is experimental, an inventor and a builder who builds best when called upon to build greatly
370forlife is offline   Reply With Quote
Old 10-15-2009, 04:20 PM   #2
370forlife
Large Marge
370forlife's Avatar
Default Re: HEC Orion HP585D
There, now a full input filter, 6A 600v bridge rectifier, and a full input filter with 2 panasonic .33uf X caps, 1 .1uf teapo X cap, 2 2200pf Y caps, and 2 coils. Also, those new Nichicon 680uf, 200v caps. Yay.
New secondary silicon. 3.3v now utilizes a 60A, 45V part. 5v uses a 70A, 30V part, and the 12v now has a 60A, 45V part. Much yays were made.
I elected not to recap it for 2 reasons. 1. teapos aren't that bad in psu's, and 2. They are all 10mm and 8.5mm sizes, which I don't have any 8.5mm caps near their ratings, and no 16v 10mm caps.
Old 10-15-2009, 04:33 PM   #3
Toasty
Toasty's Avatar
City & State: East Coast, USA
Line Voltage: 220-221
Send a message via Yahoo to Toasty
A 12 minute makeover!!!!!!!!!!!!
HOLY CRAP!!!
Toasty is offline   Reply With Quote
Old 10-15-2009, 05:22 PM   #4
ratdude747
ratdude747's Avatar
City & State: New Albany, IN
Line Voltage: 120VAC 60Hz
I'm a: Student Tech
Send a message via Yahoo to ratdude747 Send a message via Skype™ to ratdude747
that is one POS PSU!
free, but shitty as hell. glad you could fix it.
(Insert signature here)
ratdude747 is offline   Reply With Quote
Old 10-15-2009, 06:39 PM   #5
370forlife
Large Marge
370forlife's Avatar
Really not that bad of a unit. No 2 transistor 5vsb, medium grade caps from the start, wouldn't be so bad if it wasn't for two things. One being advertised as Intel 2.01, while the PCB is dated for 08/07/2008 and marked as Intel 1.2, and the other is the super group regulation, as well as the transient filter.
Single forward primary switcher is a more efficient design, but not really viable for higher wattage units, although the primary switcher in this one is capable of about 450W. Secondary heatsink is thicker than most delta units I have used.
Old 10-16-2009, 03:01 AM   #6
kc8adu
kc8adu's Avatar
City & State: dayton ohio
it will still go BANG! if loaded to the label ratings.probably ok for most home pc use though.
the mfr counts on the fact that very few pc's will need that 585w!
kc8adu is offline   Reply With Quote
Old 10-16-2009, 03:57 AM   #7
370forlife
Large Marge
370forlife's Avatar
Some tests of the HP585D have shown that the OCP trip point is just above 430W.
Not surprising, this is the same unit used in those thermaltake XP550 430W psu's without the transient filter, which can do 430W in spec.
Old 10-16-2009, 05:05 AM   #8
kc8adu
kc8adu's Avatar
the fcc logo and ul are forged.
no way it will pass either spec.well maybe now that you added a bunch of parts.
did you use x and y rated caps ?
Old 10-16-2009, 01:19 PM   #9
370forlife
Large Marge
370forlife's Avatar
That is compucase's ul number. Fake UL logo is correct, same with the FCC logo.
Yup, the X caps are X2, Y caps are safety series X1 Y1.
Old 10-16-2009, 10:00 PM   #10
Newbie2
Newbie2's Avatar
City & State: Halifax, NS
My Country: Canada
I'm a: Complete Noob!
Doesn't look like a bad power supply now that you've added better components to it.
Well done 370forlife!
My gaming PC:
AMD Phenom II X6 1090T Black Edition 3.2GHz six-core processor (Socket AM3)
16GB G.SKILL Value Series DDR3-1333 RAM (4x4GB dual channel)
ASUS M4A77TD motherboard
XFX AMD Radeon HD6870 1GB GDDR5 PCI-Express x16 2.1 video card (HD-687A-ZHFC)
1.5TB Samsung EcoGreen F2 HD154UI SATA-II Hard Drive
Antec HCG-400 400W ATX12V v2.3 80 PLUS BRONZE Power Supply
Microsoft Windows 7 Ultimate SP1 64-bit
Antec Three Hundred mid-tower case
Newbie2 is offline   Reply With Quote
Old 10-16-2009, 10:33 PM   #11
momaka
momaka's Avatar
City & State: VA
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Student Tech
This is indeed the same power supply as the Thermaltake XP550-NP 430W, minus the input filtering. According to xbit-labs and hardwaresecrets, the limiting point for these power supplies is about 350 watts. Anything after that will overheat the primary switcher (from xbit-labs tests that is). There is OCP on these units, though, which puts them somewhat above regular gutless units.
Here's the two reviews if anyone is interested
http://www.hardwaresecrets.com/article/332
http://www.xbitlabs.com/articles/coo...oundup_18.html
As far as regulation, 3.3v rail is derived from the same transformer pins as the 5v rail. The reason you see only one coil is that the 3.3v rail is regulated with a voltage regulator rather than a saturation coil.
Now I have a curiousity about this power supply, though - how many ICs are there on the PCB, 2 or 3 (ID numbers would also help)? I'm wondering because I have the Thermaltake XP550-NP 430W version of this power supply, and I want to know how the 5vsb rails generated and regulated - wheather it's a 2-transistor desing or something else. Mine's still under warranty, so I don't want to open it just yet.
By the way, 370forlife, you did some great work on this power supply!
Should be pretty reliable now. I know that mine has stable voltage regulation (12v is a little high at 12.36v, but all other rails are nearly perfect).
Old 10-17-2009, 11:19 AM   #12
370forlife
Large Marge
370forlife's Avatar
Well, not counting the three little 4 pin IC's near the 5vsb transformer, there is 1 8pin welltrend wt751002 930 j48a1g
The three little 4 pin IC's near the transformers, if they are even IC's, are all cosmo 1010 817 J18 C's.
I was thinking of getting some polymers for the secondary caps, as the highest uf 10mm 16v electrolytic cap I could find are all 1500. I was thinking of getting some nichicon 16v, 10mm, 820uf caps, but I don't think the ultra low esr of them would help any.
Old 10-17-2009, 12:25 PM   #13
Toasty
Toasty's Avatar
(4 pin) They're the opto's.
http://www.cosmo-ic.com/object/products/K1010.pdf
The Weltrend is a supervisor chip. (The iMac supplies use the 7512)
http://pdf1.alldatasheet.com/datashe...S080WT-12.html
Toast
Old 10-17-2009, 12:28 PM   #14
momaka
momaka's Avatar
City & State: VA
My Country: U.S.A.
I'm a: Student Tech
Thanks for the info.
I noticed there is one more IC behind the input caps. Probably a UC3842/UC3843 or some other similar variant. Unless this IC is something else, then it's very likely that this power supply uses a 2-transistor 5vsb design (The Welltrend wt751002 is similar to the TPS5310, and nither of those offer 5vsb monitoring/protection). The 3 4-pin ICs in the transformer area are optocouplers, like Toasty said. If there was 5vsb protection, there should have been one more optocoupler and maybe another IC somewhere (like the Bestec ATX-250 12Z).
With that said, it's probably a good idea to keep an eye out on this power supply (and definitely change the 50v, 10/22/47uF 5vsb cap if you find it).
Old 10-17-2009, 12:34 PM   #15
370forlife
Large Marge
370forlife's Avatar
Opps, missed that IC behind the caps. 8pin ST UC3843B.
Don't know which cap is the 5vsb cap. There are many 50v 10uf and 4.7uf, and one teapo 6.3v, 2200uf cap next to the 5vsb transformer.
Old 10-17-2009, 01:27 PM   #16
Toasty
Toasty's Avatar
That Teapo is a common failure. Every one I've seen in that position across various PSU makes and models is bulged. Some less than 2 years old.
Re: Polys in output - You'd need to double them up to get the oomph! provided by the higher capacitance of the regular lytics. Yes, ripple would be super low, but as soon as something drew current for an instant, the voltage(s) would sag to far. It's not something you may readily see with a meter, but on a scope you'd see the blip.
Think of it as trying to start the car with lawn tractor battery vs. a truck battery. Both may do the job, but the lights won't dim as much with the truck battery.
Toast
Old 12-24-2011, 11:36 PM   #17
qw3r7yju4n
so any how to's? - would love to spend little money and upgrade my PSU - I have a little DC/AC knowledge. Witha quick walkthrough I would be a PRO
qw3r7yju4n is offline   Reply With Quote
Old 12-24-2011, 11:39 PM   #18
qw3r7yju4n
and how are you allowed to sell a fake logo? was this dated before there were laws?
Old 12-25-2011, 07:26 AM   #19
everell
everell's Avatar
City & State: Williamsburg, Virginia
I have recently acquired a Thermaltake TR2-430W. PC board looks just like yours - except it already had the line filtering parts. GBU806 bridge diode. I think Bestec is better built.
everell is offline   Reply With Quote
