A Saturday a few weeks back, my ADSL routermodem froze up completely (I've had short "hiccups" on the line for a while before that, but thought nothing about it), and as I bent over to to power cycle it, my eyes fell on the capacitors half visible through the vents. I thought two of them looked like bulging. After opening it up, I sure found two bulging Capxon 6.3v 1000uF KF-series. There were also five 35v 470uF of the same series that were not visibly bad. I pulled them, and the ESR was in the range 0.10 to 0.15. I decided to replace them also, but physical size (16 mm hight) would be a problem with almost all 35v's of the same capacitance. I measured the voltage across them, and that was a little over 24v. I therefore replace the five 35v with 25v 470uF Panasonic FMs, and the two 6.3v's with 6.3v 1000uF Rubycon MBZ'. The result; not a single "hiccup" or freeze since the recap. The unit wasn't more than about 20 months old when I recaped it. Before and after pictures enclosed. The quality isn't great, as they are from my mobile phone camera.
Speedtouch 546 T2 v6 ADSL routermodem
Re: Speedtouch 546 T2 v6 ADSL routermodem
I know someone who has a Speedtouch modem which keeps restarting from time to time. But I haven't yet opened the modem to confirm bad capacitors.
Also, I've seen a few Speedtouch modems at a local junk shop.My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics. -
I have read on the Whirlpool forums that the Speedtouch modem/routers are very good units. They are relatively unknown and hence not used that often get sold for next to nothing.
These routers lack many of the advanced features in the web interface when comparing them to other routers. However most of the advanced functionality is available through the CLI. That is a pain in the ass in a way because it takes a lot of effort and time to familiarise oneself with the CLI. Basically you have to know what is going on, you can not just tick a few boxes and write a few numbers and see if it works.
The main complaint against them is heat, apparently they run quite warm so I am guessing that is why these modem/routers have capacitor problems (along with using crappy ones).
I will be testing these claims soon. I bought a brand new Speedtouch 536v6 from Ebay for $15.Comment
Originally posted by shadowI have read on the Whirlpool forums that the Speedtouch modem/routers are very good units. They are relatively unknown and hence not used that often get sold for next to nothing.
Originally posted by shadowThe main complaint against them is heat, apparently they run quite warm so I am guessing that is why these modem/routers have capacitor problems (along with using crappy ones).------------
Be a menschComment
After swapping the 546 with the spare I opened up the one that that seemed faulty and I found two bulging 1000uF 6.3V. The 470uF 35v seem ok so I have ordered some replacement Panasonic Caps from RS Components.
Getting the size right is difficult especially when you find the right one and it's out of stock because it's a new model. Anyway will recap the board when the caps arrive. I've ordered RS Stock Nos. 628-3920 and 365-4098 if anyone is looking for the same caps. The have a projected lifetime of 2000 hours but this under 105 degree conditions so should last longer. They are both 10 x 16 mm packages with a lead pitch of 5mm. Will post further after delivery and recap.TimComment
So far so good. Have recapped both 546v6 routers, just the power supply caps of 1000uF 16v, 2 each, and no CRC errors over two short 15 min tests. Replaced the bad CapXon caps with Panasonics, originals were 6.3V have replaced with 16v caps to allow plenty of headroom. Now to test for a week each, am hoping this is a permanent fix.TimComment
I have 2 speedtouch 546v6 , sometimes they work perfectly over hours , but then they start rebooting over and over without stop .
I spoke with my ISP and they told me to replace the modem at their store with a new Speed Touch TG585 without any charge .
I love the 546 because internet show me a lot of tweaks for this model , and also this model can maintain my speed at 17Mbit download .
Right now i am using a dlink modem with an Australian firmware , this dlink only allowed 8Mbit down/1mbit up , but with the Australian firmwave it can go up to 14mbitdown/1mbit up .
I will give a look at my speedtouch modems , and replace the capacitors in order if i can fix this issue , in mean while here it his some HD photos from the interior of the modem .Last edited by SMDFlea; 07-22-2020, 11:39 AM.Comment
I had one of these it had AC (cant remember volts) and DC 22v listed as its power supply, and with its original power supply it ran for awhile and stopped, repeat, I replaced it with a 30v dc adapter from an old printer I had laying around and it worked great for 2 years nonstop, untill I stopped using adsl.
I wouldn't recommend you do the same, safety issues and all, but just saying it worked for meComment
by dahmplease need me tenda v12 ac1200 modem bios dump 8mb
Channel: Troubleshooting & Designing Networks
by Hornnumb2Is it just me or does it seem like the routers just dont last anymore. It seems like about 1 1/2 years mine starts dropping signal and losing connections. I am not buying the cheapest but middle of the road around $100. Any suggestions for one that will last? Thanks Michael
by rbvndonhHello,
I had factory installed Ericcson modem. It was working, but later was changed into Dell 4G modem. It was working good.
Now, after BIOS repair (to the same which was rapaired in past in this machine) it shows 1802 error.
Does somebody have whitelist or know how to correct it or proper no-1802 tool or solution for this board?
Thank you -
by playitut300r2u modem,link light stays on forever no matter if if dsl phone wire connected or not.i dint mess with any firmware ,it started to be like this for past few months until it stopped all together to work anymore,so learned that flashing might help, need dump file for this modem, i have only ch34a1 programmer.so i erased and flashed with few bin or ras files i got from internet but nothing worked.so further reading let me know that have to flash a whole full dump .if any idea, pls share, thank you.
by TheQuentinccHi,
I have an issue with a 7710 motherboard, nor Wifi card/slot (8260AC and 3160AC) and LTE modem/slot (EM7455) are detected in bios/OS, the strange thing is that the wifi card is a wifi/bt combo and the BT is recognized in bios and working.
Since BT is working I think the power for these card is present, I already tried a few bios for the motherboard (asked on another thread) but only one is working, I got the board with a bricked bios and it's not a thunderbolt version.
I believe there is either a signal that disable the M.2 slot (all enabled in bios) or wireless...07-29-2022, 01:40 AM - Loading...
- No more items.
