#21 |
City & State: suburban atlanta
From the NESDA-Ohio site, one of their recent Speaker articles was about manufacturer provided training. I wrote down the names of manufacturers that do actual training for the independent repair crowd.
If they respect their product enough to provide training on its repair and maintenance, they are likely to be in business next year, and have parts available, and maybe even schematics and repair manuals. Here's the list of trainers: LG Mitsubishi Philips/Funai(!!!!) Samsung Sony Toshiba You don't see vizon, vison, Panasonic, Polaroid, etc showing up. The companies that play the odds with minimal warranty and 'ship it back if it dies' repair policies will likely take the money and run. You may be left with a pretty doorstop when the smallest of parts fails and cannot be found. Oh, and be careful cleaning the LCD and bzzzt brain fade - electronic screens. They are easily damaged - PERMANENTLY. Be sure to read the mfg recommendation. tom |
#22 |
You got that right. Samsung and Philip did run us by on training sessions so that's consistent.
We USED to do Panasonic/Mitsubishi/Toshiba till they just put us under their heel and not train at all, hassling us for any warranty stuff paperwork, all the works. Then finally dropped us. Same with JVC (which I regard as another excellent TV to have). Cheers, Wizard |
#23 | |
City & State: San Diego, CA
#24 |
WLG,
You're right. Panny was put there by mistake on my part. Brainfade comes more often as you get older. I am not a fan of their TVs, but they do have a decent rep, so far. tom |
#25 |
ive replaced the bad caps on the power supply board of my samsung dlp hl50a650c1f 13 mo old tv. two of them were samwa 470uf@200v,three others also samwa2200uf@25v.one other on the ballast board 47uf@450v which was leaking a brownish substance out of the top which i could wipe off.this was done over two hours ago and everything seems to be working fine.i will not bash samsung everyone else is doing plenty of that. i will only say that i buy products according to the service i get and leave it at that.thank you for your forum i dont thik i would have attempted this repair without it, also thanks to digi-key who supplied me with good caps at a total of a little over $12.00.thanks again.louald
#26 |
Good service. I don't care what others have spurned the brands for various reasons but I like Samsung for service and their TV line especially series 4 and up is excellent for picture processing is not too bad excepting the tuner side. I do have very specific reasons for other brands that we have hard time with.
Cheers, Wizard |
#27 |
I paid $450 about 6 months ago to fix the very same problem on my Samsung LNT5271FX/XAA model--at that time, I did not think to go on the internet to research problem--Service tech came out to my house and said he had to "Replace the entire board" due to bad capacitor. (TV was about 14 mos old--just out of warranty.)
Then two days ago the same problem appeared on my other Samsung (LN26A450C1D). Went on line to find ALL KINDS of issues with bad caps--also to find out that the caps can be replaced--entire board does not have to be replaced. I am not handy and would not even PRETEND to think I could open up the TV and replace (God forbid resolder!) caps back on, but at least when I take it to get repaired, I know it should not cost $450 .... Thank you for your informative posts. |
#28 | |
City & State: Phoenix, AZ
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist
On a scale of 1 to 10, with 1 being soldering two 18 gauge wires together, and 10 replacing a 244 pin IC, replacing these caps would rate about a 2. The tools would run under $20, the caps under $10. The feeling of accomplishment - Priceless!!! PlainBill
For a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored. Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic. |
#29 |
I just stumbled upon this site as i was researching about the apparently common issues with the Samsung LCD TVs. My particular model is the LN46-650.
I took the unit apart (it was already out of warranty) and examined the caps and there were a total of 4 for my particular model. There were two 1000uF 10V rated caps and two 1000uF 25V rated caps. The two 25V had noticable swelling at the top. My question is, should i replace them all with higher voltage caps or just replace them with better quality caps, same voltage? I was gonna solder two 35V caps to replace the 25V caps and then two 25V caps for the 10V. Is there anythign else i should pre-emptively replace. I don't want to have to spend about 20 minutes taking this thing apart again! Thanks in advance for the help guys! |
#30 | |
City & State: Canada
You can go higher in voltage or stay the same. If you go higher in voltage, make sure the diameter and height fit on your TV. Higher voltage caps are sometimes bigger. Use high quality low ESR caps like Panasonic FM/FC series or Rubycon MCZ. |
#31 | |
I'm a: Hobbyist
Again, the general rule of thumb is to replace all caps from a known bad manufacturer. In the case of mine, I checked all the caps and did not replace those that tested good. PlainBill |
#32 |
Banned
Hi everyone,
I work for a law firm that is investigating Samsung LCD and plasma TV power supply problems. We have spoken with several Samsung TV owners who have similar experiences to the ones described in this thread. If you would like to share your story with us to help with our investigation, SNIP! Thanks, John Last edited by kc8adu; 01-04-2011 at 07:03 AM.. Reason: contact info removed.you will not troll for customers here! |
#33 | |
I'm a: Hobbyist
PlainBill Last edited by kc8adu; 01-04-2011 at 07:04 AM.. Reason: contact info removed.you will not troll for customers here! |
#34 |
City & State: Alberta
My Country: Canada
Line Voltage: 120VAC 61Hz
I'm a: Hobbyist Tech
How the eff did a lawyer get in here?
36 Monitors, 3 TVs, 4 Laptops, 1 motherboard, 1 Printer, 1 iMac, 2 hard drive docks and one IP Phone repaired so far.... |
#35 |
I'm a: Hobbyist
They're like cockroaches. Scuttle around in the dark, feed on waste, generally foul anything they come in contact with, and make a delightful crunching sound when you step on them.
Perhaps I'm being too harsh. Cockroaches do have fill an important ecological niche. PlainBill |
#36 | |
Also, if anyone has some advice on negotiating with Samsung, I'll appreciate that also. Thanks |
#37 | |
City & State: dayton ohio
these sort of class actions rarely help the injured parties.no benefit except lining the pockets of these bottom feeding scum.go back to chasing ambulances!
![]() ![]() ![]() ![]() ![]() :gt fo:![]() Quote:
#38 |
Hi, I've just joined the forum after searching the web and drawing a blank for an answer to my particular problem. I'm not a technician but it sound's like this thread might have identified the problem with my TV. I have a Samsung WS-32Z306V which keeps switching to Standby. It is approx 4 years old from new. There is no pattern i.e. it happens at different times but it will switch on again straightaway. If bad caps are the problem, coulds someone please me help me by telling me which caps specifically will need replacing.
Many thanks, Paul (UK) |
#39 |
o.O
City & State: Duisburg
My Country: Germany
Line Voltage: 230VAC 50Hz
Samwha and Sam Young caps are usually what's in those Samsung LCD Monitors and TVs.
if you see any of those 2 crapcap brands, replace all of them.. (the Rubycon in the pic is just to keep the blue Samwha from rolling away ![]() ![]()
The USA have Barack Obama, Bob Hope, Stevie Wonder and Jonny Cash. We have Angela Merkel, no hope, no wonder, no cash.
#40 | |
City & State: Prague, 50°4'52.22"N, 14°23'30.45"E
My Country: CZ
Line Voltage: 230 V/50 Hz
| Thread Tools | |
| Display Modes | |
