Go Back   Badcaps Forums > Motherboards with Bad Capacitors > Major Manufacturers Boards
Old 06-10-2009, 08:38 PM   #1
bgavin
City & State: Orangevale, CA
Default Dell Dimension 8300 VRM
Please see the attached photo.
My daughter's machine has mixed poly and electrolytic caps in the VRM.
All the VRM caps are bulged and/or leaking. 820uF/6.3v.
There are two polymers at each end of the VRM cap string.
Q: should I recap with MCZ or see if I can find more 560uF/4v polys?
bgavin is offline   Reply With Quote
Old 06-11-2009, 09:06 PM   #2
lucky13
City & State: Canada
Default Re: Dell Dimension 8300 VRM
I hear everyone is recommending polys.
Which type you have on hand?
Personally, I am waiting for some polys I had ordered to play with....
lucky13 is offline   Reply With Quote
Old 06-11-2009, 09:11 PM   #3
bgavin
KC8 responded in another thread...
I guess the plan is to pull all ten pieces... four good OSCON 560 and six bad 820 lytics, replace all ten with 820 OSCON.
Old 06-11-2009, 11:12 PM   #4
momaka
momaka's Avatar
City & State: VA
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Student Tech
Are these Nichicon HM/HN? If so, maybe you should pull all of them off the board if they are the ones with the bad date codes. MCZ should probably work fine as a replacement. Polys will be nicer, of course .
momaka is online now   Reply With Quote
Old 06-14-2009, 11:17 AM   #5
bgavin
The defective caps are all MCZ.
Obviously went over temp and burned up.
This is a shitty design case and prone to over heating.
I told the client to throw it out and buy a new machine.
Old 06-15-2009, 08:59 AM   #6
bgavin
I am amazed at how trashed this GX270 is. Nearly all the caps are leaking or bulged, yet it still works.
The southbridge is VERY hot, as is the crappy little power supply unit.
The PSU fan is working.
Hot, hot, hot.
No wonder all these caps popped.
This design is a complete piece of shit.
The only thing of value on this machine is the 3.0 P4 Northwood.
Old 06-15-2009, 09:40 AM   #7
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
Send a message via ICQ to Per Hansson Send a message via MSN to Per Hansson
Haha, I hope you where kidding right?
You know those Core 2 Duo CPU's are basically free with the CPU fan nowdays
Per Hansson is online now   Reply With Quote
Old 06-15-2009, 05:52 PM   #8
Wizard
In that case may I have the 3.0GHz P4? Would be nice for my work at our shop (currently 2.8C).
Cheers, Wizard
Wizard is offline   Reply With Quote
Old 06-17-2009, 12:04 PM   #9
bgavin
Thanks for the chuckle.
Tell that one to a client with a critical socket-478 machine that cannot be replaced with a 775 board.
Old 06-22-2009, 07:29 PM   #10
bgavin
Damn. After all that farting around with my Wai Fong order, I find out I brain-farted and order 10mm polys. I hope I can find a use for 50 of the 820/4/10mm caps.
So... I did another 820/2.5/8mm bulk order from a different source.
Stupid. Dump.
Disassembling this board from the Dell case tray is quite annoying.
The processor HSF bracket ties the board to the tray.
Those old Intel 478 brackets and push-pins really suck.
Old 06-26-2009, 09:32 AM   #11
bgavin
The recap was a success using 820/2.5v polymers.
The leads are indeed a bit thicker, and required more cleaning with the needle.
This machine also had bad caps on the video card.
This was a first for me, and I replaced four popped 1000uF/6.3 with 10v MCZ.
Old 06-26-2009, 03:38 PM   #12
Per Hansson
City & State: ----
My Country: Sweden
bgavin; haha, I was just kidding, take it lightly man
http://cgi.ebay.com/Intel-Pentium-4-...mZ400055076201
Old 06-26-2009, 11:53 PM   #13
ratdude747
ratdude747's Avatar
City & State: New Albany, IN
Line Voltage: 120VAC 60Hz
I'm a: Student Tech
Send a message via Yahoo to ratdude747 Send a message via Skype™ to ratdude747
i got a p4 presscott-a (no ht, 533fsb) emachine for almost free in a trade
all i put in was my old compaq presario 5000 with amd atlon 1.2 ghz
what i got was missing cd drives/hd, pci express 16x port and had charred bestec pos ps
but it had 1.5 gb of ram with it
dang it runs fast with ubuntu
(Insert signature here)
ratdude747 is offline   Reply With Quote
Old 06-27-2009, 03:01 PM   #14
bgavin
No worries.
Ick. A Prescott. Not worth shit, let alone $19.95.
