Abit BX133 - Guess What..........
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Bad caps..............Big surprize!
    After recapping! Those are some PERTY RUBIES!
    I also modded the BIOS for this board. I used the most recent OEM version and implemented the latest Highpoint RAID firmware, so the board can utilize HDD's larger than 137gb on the RAID controller. I'll upload that soon, with a linky for downloading.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • iro
    • Dec 2006
    • 11
    Re: Abit BX133 - Guess What..........
    Hello.
    Can you send me link to bod bios.
    Thx.
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16956
      Download <-- for board revision 1.2
      Download <-- For board revision 2.0
      Team : 49813
      Join in!!
      Team Stats
      • Rainbow
        • Aug 2005
        • 1374
        BX133-RAID uses the same BIOS as BE6-II v2.0
        BTW. I recapped BE6-II v1.2 two days ago and was surprised that even the latest Abit BIOS has extremely old HPT370 BIOS - v0.95b So I put a new one inside (along with ABIT EPA logo).
        • gastorgrab
          • May 2007
          • 320
          Hello, my first post here.
          I have a BX133 board that i plan to recap and the revision sticker says "BX133-RAID v1.0".
          Is the modified BE6-II v2.0 firmware intended for this board or is there a BX133 version 2.0.
          BTW, it's pretty nasty;
          When is it too late to consider recapping? This board still works but is really unstable.
          --edit--
          I've already had success using info from this site.
          Thank You!
          EPoX 8RGA
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            if it still posts it has a 99.9% chance of survival.
            • gastorgrab
              • May 2007
              • 320
              These seem to be the locations of the capacitor on the board in front of me.
              The sticker says "BX133-RAID V1.0" but i suppose there could be variations depending on the date of release.
              • gastorgrab
                • May 2007
                • 320
                Here are a couple of pics of the almost completed re-cap of BX133.
                The only problem is that i completely ran out of flux cleaner. Before i power this board up i would like to have an unobstructed view of the solder joints.
                Will the posted firmare work with this board?
                --edit--
                The light blue are leftover UCC LXZ's from the first board i did. The rest are Rubycon MBZ, and MCZ.
                • gastorgrab
                  • May 2007
                  • 320
                  OK, i finally talked my sister into getting a power supply and everything is up and running.
                  The fan headers don't work!
                  They didn't work before but i assumed it was a bad capacitor problem. This was a common complaint with this and the BE6II if i remember correctly.
                  I flashed the modified bios too but havn't had a chance to play with it yet.
                  BTW, i'm now told that this board would't post at all before the cap change.
                  To BadCaps.net.
                  Thank You.
                  • Rainbow
                    • Aug 2005
                    • 1374
                    Non-working fan headers are caused by a damaged transistor. It's probably located near one of the headers.
                    • gastorgrab
                      • May 2007
                      • 320
                      Could this be it? I'm no good at all with this surface mounted stuff and this is the only thing in the vicinity that could be a transistor.
                      The only problem with it is that if you include the tab there are 4 legs to this device.
                      If this the bad part then there is no way i'm touching it or any other surface mounted component.
                      It's fixed enough for me.
                      I remember when i first started to question the fan headers. The CPU was getting pretty hot and wondered if the fan was going bad since it was only turning at half speed.
                      I eventually settled on the same fix you see here.........well after lapping the heatsink that had warped.
                      I could still take the tachometer pin out and put it in its own connector.
                      • gg1978
                        • Dec 2004
                        • 431
                        That's still a 3 terminal device.. The tab at the top should be connected to the middle pin.. It's just a better way of mounting a device like that has to dissipate heat without having t heatsink it separately..
                        That could be Vtt for the DIMM's or the VR for the FSB clkgen.. The little guys right by the headers look like they may be transistors too..
                        • Rainbow
                          • Aug 2005
                          • 1374
                          I guess that the offending transistor is one of the tiny 4 that are near the fan headers.
                          • Logistics
                            • Apr 2007
                            • 721
                            It's too bad Panasonic doesn't make a cap comparable to the MCZ so you could recap the board and yell "THOSE ARE SOME PRETTY PANNY'S!"
                            Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
                            • Gaucho
                              • Apr 2008
                              • 3
                              I just got one of these beauty BX133-RAID.
                              1) what are the best caps for me to recap it? Panasonic? Rubbycon? UCC?
                              2) Is there any difference between BIOS for rev1.02 and for rev2.0? Actually the stick on the ISA connector slor on mine says rev 1.01. So I was wondering wich BIOS should I put on it....
                              Thanks. (if someone knows where to find good caps for this board in Brasil, please let me know).
                              • gdement
                                • Jan 2007
                                • 690
                                I recapped one of these a long time ago. I used Rubycon MBZ for the 8mm 1500's and UCC KZE for the 1000's, but this was only because of availability. They worked out well anyway. The hardest part is the 1500's, which need to be 8mm diameter in order to fit properly, so you may have trouble finding those. There aren't many series that will fit there, but MBZ and MCZ are 2 of them.
                                • linuxguru
                                  • Apr 2005
                                  • 1564
                                  Panasonic FJ is comparable to the MCZ, but only time will tell if it is equally durable. 1500/6.3/8 mm is available in low-ESR Panasonic FK, but not sure about the ultra-low ESR options. Nichicon HD is good but 10 mm, and UCC KZG is 8 mm but failure prone.
                                  • PeTTs0n
                                    Abit BX133-RAID odd issue, bad caps?
                                    by PeTTs0n
                                    I just bought a bundle with a Abit BX133-RAID, a 866MHz P3 (SL4CB) and a 256MB PC133 SDRAM stick, that the seller claims were working fine together.
                                    After building a rig out of it, with a known working PSU (Seasonic S12II 520W, for its good 3.3V and 5V rails), I get a good startup screen, but as soon as I try to enter the BIOS, it locks up with a blue bar across the bottom of the screen.
                                    I have seen one thread from 2010 about this issue specifically on Vogons, and the consensus there was that bad caps may very well have something to do with it, and although I can't see any...
                                    09-04-2020, 02:44 PM
                                  • tbalint3
                                    Abit ST6-Raid repair
                                    by tbalint3
                                    Hello All,
                                    I am trying to repair an old Abit ST6-R motherboard.
                                    The symptoms are the following:
                                    I got it in a non-working state. I was told that it sometimes turned on, but many times just the CPU fan was spinning and no other signs of life, the board didn't POST, and now it doesn't POST at all.
                                    It was full of bulged electrolytic capacitors, so I replaced all of them with new Low-ESR ones, but it didn't solve the problem.
                                    If I install a CPU in the S370 socket, only the fans are spinning and no POST. There are no beep codes even if the RAM DIMMs...
                                    09-01-2024, 10:03 AM
                                  • canadaboy25
                                    Drive SMART status not showing up through RAID controller?
                                    by canadaboy25
                                    Hey guys,
                                    I have an Asus M5A99FX Pro R2.0 motherboard with AMD RAIDXpert. I set up a 1000GB RAID1 array on it. This was about 8 years ago. Every once in a while, a power outage or something would knock one drive offline and degrade the array. After a reboot the drive would be back online and it would rebuild just fine.
                                    Recently, a drive dropped offline and the array became degraded. I figured it was no big deal and rebooted then set it to rebuild overnight. The next morning I took a look and both drives had dropped offline at 70% rebuild. Uh oh.
                                    I rebooted...
                                    09-24-2021, 01:56 PM
                                  • canadaboy25
                                    ABIT KT7 RAID only POSTs every other time
                                    by canadaboy25
                                    Hey guys, I have an ABIT KT7 RAID motherboard that will only POST every other time I try it.
                                    When first powering it up, all the fans and drives spin up but I get no display and no beep. If I then turn the switch off on the power supply while it is running and wait for everything to stop and try again, it boots up just fine and works great until I shut it off.
                                    It doesn't matter if it has sat for a while or if I was just using it, it always takes exactly 2 tries to get it to POST.
                                    Rebooting from windows also doesn't work as it just hangs in the exact...
                                    08-08-2020, 07:38 PM
                                  • Foetuss
                                    Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
                                    by Foetuss
                                    Hi all
                                    Hope this is in the correct place.
                                    I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
                                    Could use some double checking to see if I'm not doing something stupid .
                                    Pictures of the boards are attached.
                                    What I will be replacing with what : (planned)
                                    Soltek Golden ::
                                    4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
                                    6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
                                    01-18-2025, 11:44 AM
