Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Troubleshooting Computer Displays
Old 02-09-2009, 04:53 PM   #1
baileyboy
Post Hanns-G 19" turns off. PSU overheated and bad caps
I have a Hanns G 19" inch monitor i bought it second hand form a car boot. When I got the monitor home I plugged it in and the monitor worked for about 5 mins. Then it went blank. So I turned the monitor off and on and it then work for about 30 secs and then went blank again. So I took the monitor apart and saw that the power supply looked like it had got very hot as the metal around it was brown. I don't know if this is normal in a monitor. The power supply is 200-000-170DTL1 Version:A+. Also I have noticed that the 220uf 25 v capacitor is gone. What should I do, should I change the capacitor?
baileyboy is offline   Reply With Quote
Old 02-09-2009, 05:13 PM   #2
EGuevarae
EGuevarae's Avatar
City & State: Chiriaco Summit, CA - near the AZ-CA Border
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
Lightbulb Re: Hanns-G 19" turns off. PSU overheated and bad caps
That Mirage PSUs tend to run hot, or so I've heard around here in the forums.
I have a bad experience with one of those in a Proview 700P (Sylvania CL-722). You should change the bank of caps in the yellow marked areas as a first step. They will be Teapo, Elite or CapXon, if not worse.
  • ASRock P43DE
  • Dual Core E6300 2.8GHz
  • 8gb DDR2-1066
  • 4 1TB SATA2 WD HDDs (2 mirrored volumes)
  • 22x SATA DVD+RW
  • Windows 7 Pro x64
  • GeForce 8500GT PCIe
    2 x Vewsonic VP2130 21"
EGuevarae is offline   Reply With Quote
Old 02-09-2009, 05:15 PM   #3
EGuevarae
EGuevarae's Avatar
Question Re: Hanns-G 19" turns off. PSU overheated and bad caps
By the way, exactly what model is your Hanns-G?
Old 02-09-2009, 05:23 PM   #4
Harvey
Harvey's Avatar
Default Re: Hanns-G 19" turns off. PSU overheated and bad caps
Looks to me like a combination of heat and cigarette smoke, does it smell of nicotine?
Harvey is offline   Reply With Quote
Old 02-09-2009, 05:28 PM   #5
kc8adu
kc8adu's Avatar
City & State: dayton ohio
My Country: U.S.A!
Line Voltage: 12vdc,120/240vac,480vac 3ph on my bench
looks like someones ashtray filter.
recap it.
then wash your hands.
that thing would need a bath before i could tolerate it in my home.
yechhh.
kc8adu is offline   Reply With Quote
Old 02-10-2009, 11:39 AM   #6
baileyboy
I don't know what model it is as the case doesn't say and It didn't come in the orginal box. The caps are Hec. What would be the best make to replace them with? Thanks for the help
Old 02-10-2009, 11:46 AM   #7
EGuevarae
EGuevarae's Avatar
Panasonic FC series, SamXon, Rubycon, Nichicon. I've used a few Panasonic FCs (as per forum members suggestions) and no problems so far. Just watch out for the correct size. And in the back of the case/shell there should be a sticker with the model info, serial, etc.
Old 02-10-2009, 12:12 PM   #8
baileyboy
Also the big 400 v 100uf cap looks like it has been very hot as the borad under it has gone browner with the heat. Should I replace it?
Old 02-10-2009, 12:19 PM   #9
glen65
City & State: Ohio
Line Voltage: 120
Yes, replace all of the lytic caps.
glen65 is offline   Reply With Quote
Old 02-10-2009, 01:14 PM   #10
Krankshaft
Krankshaft's Avatar
City & State: New Jersey, USA
Man the heatsink design on the PSU must be horrid in order to cause visible signs like that.
From your pics the hot offenders look like the main switching transformer, the heatsink over the HV inverter transformer (an extremely stupid move IMO), and the switching FET heatsink.
The inverter transformers are already working at high voltage and high frequency you don't need to be throwing any more heat out at them. Not to mention the extra stress that this heat is putting on the winding insulation.
The secondary cap bank looks to be generating the least heat out of all three due to the lighter color.
Even if none of them look bulged any bad cap would be toasted in this heat. The tiny cap towards the front left in your pic looks bulged from the pic.
Panny FCs all the way on this one if they can't survive here no cap can.
Krankshaft is offline   Reply With Quote
Old 02-10-2009, 01:27 PM   #11
Scenic
o.O
Scenic's Avatar
City & State: Duisburg
My Country: Germany
Line Voltage: 230VAC 50Hz
hmm..
http://cgi.ebay.com/4-Nippon-ChemiCo...742.m153.l1262
just a thought lol
125C High temperature
The USA have Barack Obama, Bob Hope, Stevie Wonder and Jonny Cash.
We have Angela Merkel, no hope, no wonder, no cash.
Scenic is offline   Reply With Quote
Old 02-10-2009, 06:16 PM   #12
baileyboy
Where is the best place to buy caps online?
Ps. I live in the UK
Old 02-10-2009, 07:24 PM   #13
Krankshaft
Krankshaft's Avatar
Here is one place:
http://uk.farnell.com/
Farnell In One in the UK.
Old 02-10-2009, 08:16 PM   #14
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
City & State: Phoenix, AZ
Line Voltage: 120V 60Hz
I had a Hanns-G 19" opened up today with an FSP PSU/Inverter but it didn't look like the photo's in the thread here.
Screen is model HC194D, is a 2006 model but brand new, still in box and plastics.
PSU/Inverter is: FSP043-2PI01.
Every cap in it is Capxon KF series. [Nearly exact match to Panny FC.]
Caps:
2x 1000uF 10v 10x16mm
3x 470uf 25v 10x16mm
1x 470uF 10v 8x11.5mm
1x 22uF 50v 6x11mm
1x 100uF 400v 18x35mm
[Last two are not in that can size in the data sheet.]
Main/Graphics board caps:
5x 330uF 16v Teapo SC , 8x11.5mm
1x 220uF 16v Teapo SY , 8x11.5mm
2x 100uF 25v Teapo SC , 6x11mm
1x 22uF 25v Teapo SH , 6x11mm
4x 10uF 16v G-Luxon SX , 4mm (on 6mm space)
Mann-Made Global Warming.
- Dr Seuss
PCBONEZ is offline   Reply With Quote
Old 02-11-2009, 08:24 AM   #15
baileyboy
Would these caps be good enough or should I get some better ones?
http://cgi.ebay.co.uk/1000UF-25V-105...1%7C240%3A1318
Old 02-11-2009, 08:53 AM   #16
Scenic
o.O
Scenic's Avatar
My Country: Germany
uhm... no brand.. nothing.. o.O
if you're going to buy them on ebay (with paypal) i'd suggest this shop here..
Old 02-11-2009, 11:12 AM   #17
baileyboy
Is samsung a good brand of caps?
Old 02-11-2009, 03:16 PM   #18
EGuevarae
EGuevarae's Avatar
Thumbs up Re: Hanns-G 19" turns off. PSU overheated and bad caps
Good choice.
Old 02-11-2009, 05:15 PM   #19
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
-> No
Look for:
Rubycon, Panasonic, Sanyo, Chemicon, Nichicon, Elna, Hitano, NIC Components.
Brand is only about 1/3 of what matters.
You need to get good enough 'grade' too. [ESR and Ripple ratings.]
Also stay with caps that are rated for 105 degrees C.
Panasonic FC series is easy to find in many sizes (without going to eBay and in or outside the US) and are good enough grade.
There are several dealers on eBay that sell counterfeit caps.
Counterfeit Sanyo, Chemicon, and Rubycon are not uncommon.
Old 02-11-2009, 05:22 PM   #20
baileyboy
Where would you recommend getting caps?
