LCD 19" BENQ T905 problems
  • dvorav
    • Oct 2008
    • 43
    Hi folks,
    I possses a 19"BenQ T905 monitor. One day it went blank. (While using strong light, I'm able to see a picture). Guessing, it is backlight fault. It's very common fault for BenQ displays (as I know from Badcaps). As a read several threads, i have decided to openning it. I searched for blown 2SC5707. But found none. All caps seemed good as well. By the way the board is containing lot of SMDs and one IC 52 CJ5YK TL1451A. Finally i found one-way blown IRFU9024N. But now, it will last some time until I get the part. Meanwhile, can someone give me an advice if there is also some hidden fault... maybe the IC? I'll be glad for any advice. Thak you
  • Krankshaft
    • Jan 2007
    • 2328
    Re: LCD 19" BENQ T905 problems
    How did you check the C5707s a visual inspection won't suffice here. You will have to measure for a short across them.
    The reason I say this is because the IRFU FET you speak of usually blows because of a C5707 failure.
    If the C5707s are indeed fine then check the 3 to 5 amp pico fuse and see if it's blown. If it is replace the IRFU and the fuse together and try powering it up.
    • dvorav
      • Oct 2008
      • 43
      Thanks for reply!
      First of all, please, excuse my English. I'll try to do my best.
      I checked the C5707s by multimeter, but none was shorted. That's strange, while thinking of reason why is the IRFU9024N blown (see attached photos).
      Speaking of "blown", from closer look it seems rather fried (see violet color of a heat sink)
      I had also attached photo of whole PCB. Items marked with * i have soldered off. The pico fuse was blown as well.
      I'm wondering if I should replace also the other good IRFU.
      And also questionable is condition of IC (see PCB)... whether is or isn't affected by the event of blowing the IRFU.
      Unfortunately, there aren't any specialized shops in neighborhood, so I have to go to capital (Prague) to get new parts... it will be next week. Meanwhile, thanks for other suggestions.
      • dvorav
        • Oct 2008
        • 43
        Hi 2 All,
        I got the new parts (IRFU9024Ns) recently. So I mannaged to change one 9024N and pico fuse 3.A. Guess what! Monitor is up and running. I'll let it run for a while to see if the fix is permanent. So far it seems that IC 52 CJ5YK TL1451A is good. And I think it will be for some time
        Thanks for reading and replying. I hope this thread will help to someone.
        See ya
        • Wizard
          • Mar 2008
          • 2296
          And replaced the capacitors? These overstress the transistors.
          Cheers, Wizard
          • dvorav
            • Oct 2008
            • 43
            No, I didn't replace capacitors. There is not any leaking, none of them is swollen. I assume that capacitors are fine. But the reason why the monitor failed could be connected with general absence of functional current limiting circuit (see davmax posts in another thread).
            Do you mean some speciffic capacitor from your experience?
            Monitor is running around several hours without any difficulties.
            dvorav
            • Wizard
              • Mar 2008
              • 2296
              They do dry out in hot area where lamp inverter supply is. Even it is not bloated at all.
              Cheers, Wizard
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                the elite caps in these benq units are usually in bad shape even if not bulging.
                i replace them.
                • dvorav
                  • Oct 2008
                  • 43
                  So you mean all 470uF 35V should be replaced, or ALL elite caps are worth replacing?
                  • carphone66
                    • Nov 2008
                    • 1
                    Check also the polyester capacitors at the switching transformers. C824 and C826 (220 nF, 160V) usually have dry solder joint in 90% of the cases due to ultrasonic vibration from the switching current.
                    Chris
                    • dvorav
                      • Oct 2008
                      • 43
                      Thanks for posts!!
                      I appreciate that. So far I have resoldered polyester capacitors. Monitor seem working.
                      Concerning Elite caps, there are obviously several types. Should I replace all of them or would it be enough to replace those 35V @ 470uF near/inside CCFL inverter side?
                      Dvorav
                      • Scenic
                        o.O
                        • Sep 2007
                        • 2642
                        i'd replace all elite caps. pure junk.
                        had lots of LCDs with Elite crapcaps here. no visible signs of damage (bulging, leaking, etc.) but *all of them* were bad. and they smelled like rotten fish when i desoldered them (not to mention that their legs can be ripped out of the can very easily.. it's like the electrolyte in there ate up the terminals where the legs are/were connected to)
                        • Djadjo
                          • Jan 2010
                          • 8
                          Hi all
                          After 3 years..my benq also start to show problems...
                          when it turns on the picture only blinks...and the power on led shuts down..
                          inverter board model : 48.L1J02.A02
                          ok so i changed all (c5707) q809 ,q808,q815,q816..
                          also changed two irf9024n but only one of them have been blown...
                          ok so i start the monitor and voila the picture is back...but after minute or two...9024n (q812) gets so hot and burns....another (q805) 9024n is normal cold...and dont overheat when monitor is working...
                          only q812 as soon as i start the monitor gets rapidly hot...
                          ok so i change it with irf9530n (100V 12A) and that one too burns/dies...
                          i looked the high volt trafos...and everthing of components around or in that circle....i desoldered it and than look on multimeter...everething else is good...
                          the micro fuse is ok...never blown...
                          can i suspect the TL1451A or something else...
                          thnx to all
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            Just to clarify, did you desolder the transformers? I can't understand what "it" is.
                            --- begin sig file ---
                            --- end sig file ---
                            • Djadjo
                              • Jan 2010
                              • 8
                              sorry, I didnt said exactly what have i desolder...
                              ok i have desoldered next components : T801,802,803,804..they all have same instrument readings..the c824 c826 have exact values on lcr metar...
                              i have changed c821 elco (470uF 35V) the coils l801 and 802 apears normal too...I didnt touch annything on input part of the board..(the 220V to the mosfet q601...put him out and measure..and seems ok....
                              Djadjo
                              • Djadjo
                                • Jan 2010
                                • 8
                                repaired the monitor few seconds ago....
                                mos q812 (9024n) burned when i lit monitor...but it was my fault...after first testing i didnt re-measure c5707 again...so i burned two in total 9024n...and than realize that c5707 died tru first test...
                                after that it was easy...changed two c5707 and put new 9024n...and monitor works..without any overheating or any problem..
                                Thanks 2All
                                Djadjo
                                • capullaco
                                  • Aug 2010
                                  • 40
                                  Hi, I got the same TFT with the same problem.
                                  One day I was browsing youtube and suddenly the screen was fading to black.
                                  Now I cant see anything, but the led turns on normally.
                                  Could it be the inverter? Where is it? Which model/type is it (to order a new one)?
                                  I dissassembled it as far to see the PCB, but I cant see the inverter bar (never seen one outside internet guides btw).
                                  Im also a noob for electronic stuff, I got a tester but I dont know how to check the items on it.
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    Post pics after reading this FAQ on pic posting.
                                    https://www.badcaps.net/forum/showthread.php?t=1868
                                    Do you get the screen for 2 seconds and then to black? Or do you get no flash or display at all?
                                    • capullaco
                                      • Aug 2010
                                      • 40
                                      No,no display at all, not even the BenQ logo, but the led turns on right.
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        Benqs are notorious for blown picofuse, shorted transistors, and poorly solder transformers. I believe you will have one or all 3 of the above if you get no display or Benq logo, but have the power led on.
                                        Post a pic and we can suggest test points.
                                        • ohren
                                          What problems could this blown cap cause in a Marantz SR5400?
                                          by ohren
                                          I'm looking at a vented C513 in a Marantz SR5400 (photo included), in the FR section on page 24 in the service manual (https://audiocircuit.dk/downloads/ma...400-avr-sm.pdf).
                                          R533 right below it in the photo is charred, but measures the correct value.
                                          1. I'm not familiar with amplifier circuits (at all — don't know the difference between classes, etc.) so I was wondering what problems would manifest from a supposedly non-operational C513? I didn't hear anything odd when testing the output channel with a speaker. Is there a simple test that can be done...
                                          10-21-2025, 09:02 AM
                                        • Caspar
                                          BENQ GW2780-T power board blown
                                          by Caspar
                                          Hi all, I am looking for some help in ID'ing some parts in an attempt to fix a power supply from a GW2780-T monitor. The power supply PN is 715G7300-P02-006-0V3R. I have been looking around for the PN and it appear the board was used by other OEMs as well (ASUS, Viewsonic). If anyone has a schematic, it would be helpful.
                                          Quick look on the underside of the board, I can see:
                                          -D905 is blown - ? value
                                          -R920 is open - 1Ω ?W
                                          -R927 is open - 20Ω ?W
                                          On top side, I see:
                                          -R931 open - 0.68Ω ?W
                                          Metered short:
                                          -P9NK65ZFP...
                                          06-01-2022, 05:16 PM
                                        • jean luc ferre
                                          laptop hp g72 b52sf screen problems
                                          by jean luc ferre
                                          on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                                          the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                                          i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                                          i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                                          06-07-2025, 03:27 PM
                                        • drscoot
                                          HP X360 convertible battery blown fuse error, not charging
                                          by drscoot
                                          HP Modelnumber: 14-dh0061nb​
                                          This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                                          The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                                          I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                                          And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                                          All these 3 batteries are charging...
                                          12-15-2023, 05:54 AM
                                        • Hondaman
                                          USB problems?
                                          by Hondaman
                                          Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                                          (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                                          I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                                          08-12-2024, 03:26 PM
