Need Help:Telefunken D32H278A3 / 17MB82S
    i am new in this Forum.I am from Germany.My Problem:
    I have an Telefunken LED TV Model: D32H278R3
    The Motherboard Vester 17MB82 is broken.
    I buy on Ebay an other Board from an Telefunken D32H278A3.
    Now the Picture ist standing on the Head and the Picture ist very Bad.
    Motherboard: 17MB82S
    Power Supply:17IPS71
    Panel:VES315WNDL-2D-N02
    Here some Picture from the TV.
    Ok,it is not the right T-CON Board.Does the right T-CON board work with the VES315WNDL-2D-N02 panel?
    In the service menu one can make some settings but panel does not select. A little at the color and sound.
    An update via USB does not go.USB Stick is detected. File does not go (08_nolu_yazilim_V.084/upgrade_loader.pkg)
    Wong Software?
    A USB log I could make(USB trace.log).
    Or I sell everything back on Ebay.
    I do not know what's wrong with the old board.
    CPU? RAM? Flash?
    Is the Software in the Winbond Chips ?
    Can i flash the Winbond Chips ?
    What can i do?
    Who can help me,please ?
    Greetings from Germany
    Martin
    Re: Need Help:Telefunken D32H278A3 / 17MB82S
    As I said there is no way to recover the FW off these boards and write it to use for the panel as its shared between 2 Ics and the nand. Nothing I can can do unless anyone has the dump saved.
      Didn't we recommend purchasing the correct Main Bd on another Post before?....
        i would put the original tcon board back into the tv and get a replacement mainboard from ebay etc that matches your panel in your tv you can always sell on the wrong boards as you know they work ok.
          I can find you the firmware for 10 euros
            Hi Martin!
            Please send me dump U10/U12 (winbond). May be I help you...
              Can you please explain to me how the F*** you got the dumps off these ? Please please
                Hooray ,
                my TV works again.I solder the old(from D32H278R3) Winbond Chips to the other Board(R32H278A3).Before I soldered I created a dump from the Chips.With Raspberry and Flashron Software.I have wrote new Winbonds and solder it but it works not.I think the CPU from the old Board is dead.Or not?I wrote the new Chips with Images/Dumps from a Polish Board.The Size was correct.
                When anywone needs my Dumps(D32H278R3 and R32H278A3) can i post it.
                Ok,see you next Time
                Martin
                  glad to hear you set is working fine maybe if you have time if you could write a guide on how to use the software etc as it may help a lot of members out i have not read anywhere regarding the use of Raspberry and Flashron Software so very interested in this.
                    Good man
                      Hello, I made the quick a small guide.
                      I hope this help anyone a little bit.
                      CU-Martin
                        CU-Martin
                        Thankyou for taking your time to make that guide im sure it will help members in repairing there sets.
                          Hooray ,
                          my TV works again.I solder the old(from D32H278R3) Winbond Chips to the other Board(R32H278A3).....
                          Martin
                          Hello Martin. Great job! I must say that you helped to repair my TV Telefunken D32H278KT3 too! My original dumps were damaged. TV works fine with your dumps for D32H278R3! ( With dumps from R32H278A3 video rotated and bad.)
                          Thank you very match!
                          Genady
                            Nice, that I could help. I would like to give the Internet or people also something.
                              Hi Martin i have D32H278KT3 . My original dumps were damaged
                              please send me your dump D32H278R3
                              original dump D32H278R3 bad and rotated
                              tnx
                                tnx
                                  Ciao Martin ho D32H278KT3. Le mie discariche originali sono state danneggiate per
                                  favore mandami il tuo dump D32H278R3
                                  dump originale D32H278R3 cattivo e ruotato U10 and U12
                                  tnx
                                    thanks
                                      Could i get a copy of these files please
                                        Hello, here you are
